Hi,
My synthetic walking boots have spring a leak.
Any methods to re-waterproof them?
Thanks
Chris
Are they Gortex lined?
If they are, then the membrane has probably cracked and split. AFAIK it can't be repaired.
Thanks.
I think they are the HiTec proprietary lining.
Weren't expensive as I got them in the sale. They both started leaking on the same day. Had hoped a Nikwax or something might make them useable again.
Thanks
Treatments will only help stop the fabric from wetting. Actually water penetration is down to the liner, which now sounds like it's compromised.
The other possibility is that dirt is stopping them membrane from breathing and so condensation collects in the boot but I'm guessing it's more a single point leak issue.
Thanks. Sounds like my liners are knackered. As per the pic above...it's pretty significant leaking!
Treating them might be worth a try. My winter boots have a slight leak but when freshly proofed the water runs off the outer witbout soaking in. Doesn't help with standing in puddles but solves road spray and wet grass.
Yeah if the membrane has holed then there's nothing to be done, having said that I have had some success soaking my boots in nikwax wash in but it won't stop water getting in once the fabric is inundated.
All the boots I've had that failed have gone together on the same day or very very close.
Sealskinz socks, CJR - then the boots don't need to be waterproof.
Thanks all. Will try Nikwax and then leave them as summer walkers
