Raw image adjusting...
[Closed] Raw image adjusting in PS Elements
4 Users
I used the RAW plugin for the first time the other day, and I've got a fair few severely under-exposed shots that I want to fix. There's an 'exposure' slider in the raw editor dialog that comes up when you open a raw, and if I slide it all the way I can see the image but it seems very saturated.
Is it possible or easy to recover a normal looking image from something that's drastically underexposed? Or have I lost image information for good?
Posted : 15/06/2010 9:46 am
Can we see the photo? Before & after? RAW's generally allow a little bit of playing with, before you hit the end of the information.
Have you tried playing with exp, contrast, brightness, fill light, blacks, etc?
Posted : 15/06/2010 10:05 am
No "saturation" adjustment in RAW?
Do the best you can for exposure/levels, then go into normal PS to reduce saturation. There's nothing wrong with a "two stage" workflow, major adjustments in RAW followed by fine tweaks in PS.
Probably yes, you won't get a perfect result but don't give up yet.
Posted : 15/06/2010 10:16 am
There is a saturation adjustment, but it still looks odd. I would have assumed that the exposure compensation slider did its best with saturation adjustment too.. but I suppose there's no substitute for the human eye.
I can do a series of pics I suppose later.. not at work tho :0
Posted : 15/06/2010 10:41 am
Nikon RAW?
If so then my advice is try CaptureNX and never look back.
Posted : 15/06/2010 11:41 am
Olympus.
Posted : 15/06/2010 12:00 pm
