Rapha science.
[Closed] Rapha science.
14 Users
Just came across this from Cylclist magazine. In the context of wearing a base layer when it is hot.
From Graham Raeburn lead designer, Rapha.
" Sweat accumulating on your skin needs to be removed-by wicking- to help keep you comfortable and regulate body temperature ..... Wicking sweat and therefore taking heat away from the body to keep the wearer cool and dry."
Now I'm no expert, but I rather thought the purpose of sweat was to cool the body by evaporation, that is why evolution blessed us with it. Doesn't sell extra expensive base layers , of course.
Posted : 25/07/2013 11:12 am
 Solo
[I]Now I'm no expert, but I rather thought the purpose of sweat was to cool the body by evaporation, that is why evolution blessed us with it. Doesn't sell extra expensive base layers , of course. [/I]
Nor me, but you're pretty much spot on. Evaporation is the change in state. This requires energy, in this case, in the form of heat.
Posted : 25/07/2013 11:15 am
... I guess the premise is that if it doesn't 'wick' it can't evaporate. But that's mostly monkey bollucks.
Posted : 25/07/2013 11:17 am
think once you are soakeed in sweat it cannot evaporate like in high humidity so some merit to the argument
That said i cannot see how another layer keeps you cool just wear ONE wicking top or unzip the thing surely
I almost never wear a base layer in winter so ther eis no chance for summer
Isn't the point of the base layer etc to present a larger surface area for evaporation than skin alone.
And the wicking is to draw moisture away from the skin as the sweat on the surface of the garment evaporates.
they still cool the body as evaporation takes place and just more effective than skin alone?
Posted : 25/07/2013 11:19 am
I used to wear a string vest style base layer in the summer - but that was mainly because of the theory that in a crash as you were scrubbed along the road one layer of fabric rubbed against the other rather than your skin and you got less friction burns.
I don't road race now so I find myself sucking tarmac far less frequently than in the past.
Posted : 25/07/2013 11:26 am
Rapha are a big joke are they not? Set up to find out how much people are willing to spend on stuff. No one actually uses Rapha kit apart from Team Sky surely.
Posted : 25/07/2013 11:33 am
Gary Kemp does. It's why he cycles.
Posted : 25/07/2013 11:44 am
No, they are the law, or so it seems as every bike sold near StAlbans comes with a Rapha jersey and reflectors.
The base layer in summer is a bit of a conundrum. When it's hot a single good quality technical jersey does the job. When I've tried a technical vest under a jersey in the heat I get damp. The science of having a wicking jersey under a wicking jersey needs explaining properly to me.
The time I use a summer vest most is in the late evening when I know the temp might drop. Or on long off roads when the temp can be variable, but as a rule an extra layer of any kind is mainly used to add warmth.
Posted : 25/07/2013 11:50 am
anagallis_arvensis - Member
I'm guessing you weren't being serious but in 2011 Rapha's turnover was in the region of £13million. So I guess some people like it.
You are not obliged to.
Matt
Posted : 25/07/2013 11:52 am
Yup, but a bead of sweat will take a while to evaporate as the enegry input is confined to a small area of skin, and the evaporation is over a similarly small area. 'wick' it into a bt of cloth and it'll go really quickly.
What evaporates quicker, 2l of water in a bucket or 2l of water soaked into your laundry when you hang it out?
Posted : 25/07/2013 11:55 am
[i]in 2011 Rapha's turnover was in the region of £13million[/i]
Crikey, 13 shirts sold 🙂
I am no fan of Rapha (although i do have some of their kit) but I would agree with the base layer in summer thing
I usually/always ride with a merino under my jersey
Even in 40 degree heat on a HC climb last month
😀 Living just outside the place I can confirm from the stream of cyclists each Sunday morning this is 100% fact.
Posted : 25/07/2013 12:01 pm
I suppose it depends on what sort of jersey you're wearing? A good skin tight top should do the job on it's own.
I used to see a lot of pros sporting vests, but the recent tops are almost see through.
Posted : 25/07/2013 12:02 pm
I often wear a base layer in summer but I don't wear anything over it. If I'm carrying anything on my back then there doesn't seem any advantage to wearing a cycling jersey with pockets. They're also often easy to find cheap.
Posted : 25/07/2013 12:07 pm
I ride out to Redbourn most weeks, it's the outermost point on a little 100km I do on a regular basis, I stop at the Hub in winter. You near there?
I got seriously miffed one Sunday every group that came the other way from Redbourn to Studham had someone wearing Rapha, then a small group let the side down.
Posted : 25/07/2013 12:08 pm
Nah. Been past the hub a few times. But I'm north of St Albans, just outside Wheathampstead. Judging by the tops, Team Sky seems to do a lot of training round here too 🙂
Posted : 26/07/2013 4:28 pm
