Radiators fed from ...
[Closed] Radiators fed from the top...
7 Users
I want an 'upside down' radiator, where the two pipes to feed it can come down from the ceiling.
Obvs a conventional rad would require pipes chased into the wall or exposed and I don't fancy either.
Does what I want exist? If so anyone point me at some?
Posted : 04/10/2018 9:59 pm
Err......so you want to feed two water pipes to a radiator from above, but you don't want to see them, and you don't want to hide them?
Electric radiator?
Posted : 04/10/2018 10:03 pm
If the hot water goes into the top the rad will never get hot.
Posted : 04/10/2018 10:10 pm
What the captain said.
Bring the pipes down  behind the radiator and in at the bottom.
Or just go electric.
Posted : 04/10/2018 10:15 pm
If such a thing exists I assume the rad would have integrated channels cast in so ultimately the water would go in the bottom.
Err……so you want to feed two water pipes to a radiator from above, but you don’t want to see them, and you don’t want to hide them
I don't want them running from top to bottom of the room. Obviously I'm happy with 50cm or so at the top.
Posted : 04/10/2018 10:16 pm
 Bear
Purmo Kos V vertical rad can be fed into the top, there will be other vertical rads that will do the same.
Posted : 04/10/2018 10:17 pm
Thanks Bear, that looks ideal, I'll see if I can meet the conditions:
"Note,with top connection one must turn the radiator around and a minimum water column head of 3m is required for the radiator supply, and this with a minimum flow rate of 150 l/h"
https://www.purmo.com/en/products/vertical-design-radiators/kos-v.htm#tab-technical-data
Posted : 04/10/2018 10:29 pm
In my doctors surgery they have what looks to me like a conventional rad turned 90 degrees.
it looks bloody daft.
Posted : 04/10/2018 10:49 pm
I like the ones you see installed diagonally at the bottom of the stairs 🙂
Posted : 05/10/2018 6:30 am
