Quick Car Tyre size...
[Closed] Quick Car Tyre size numpty question (numpty content)
12 Users
205 60 r16 is the current tyre, need some seriously budget front tyres, what other sizes could i get and keep the "size" the same... can i drop down to 15's , and if so what should the other number be?
Posted : 04/03/2014 8:45 am
You can't get 15s as the size of your wheel is 16". To be honest, I can't imagine a tyre of that size being expensive anyway surely.
Posted : 04/03/2014 8:53 am
part worns if you are that bothered about price.
Posted : 04/03/2014 8:59 am
You will need 205 60 R16 size tyres.
Posted : 04/03/2014 9:00 am
ok thanks all.
Posted : 04/03/2014 9:02 am
You can vary a little and keep a totally usable tyre- for instance you can often go slightly narrower but with a higher aspect ratio, or wider and lower, to get a tyre the same height and therefore rolling radius, and there's a range of tyre fitments allowable for each rim size.
Some folks say this causes insurance problems if you deviate from the OEM fitment but I've never found that (in fact some people say that if you fit any tyre apart from the original, that's a "modification" but I've never found that either) There are tyre size calculators available online.
So, I can't remember offhand the sizes but on my Focus, I switched to a marginally different size that ended up being about £15 less a corner, and was functionally the same. And frankly my experience suggests that you can buy tyres from 2 different manufacturers of the same claimed size, and get a bigger difference than you get between 2 sizes from the same manufacturer.
Posted : 04/03/2014 10:53 am
 sbob
16" is a crap size for price, 15" or 17" are normally much cheaper as they are far more common.
Posted : 04/03/2014 11:04 am
I've never found that, loads of family size cars (Mondeo, Vectra, Passat) have most of their models with 16" wheels. The 60 profile is probably less common than the 55 though, and 55 would probably be OK on a room that takes 60.
Posted : 04/03/2014 11:14 am
 sbob
Certainly used to be the case.
I could get four new 17" tyres and wheels cheaper than four new 16" tyres for my old Jag.
Posted : 04/03/2014 11:20 am
 DrP
New tyres for our octavia, all Kuomo ku31s..
17" rims = £85ish
16" rims = £65
I prefer the look of the old bigger rims though 🙁
DrP
Posted : 04/03/2014 11:25 am
Perfect thread, perfect timing. I have 2 tyres in the garage that have 215/55 R16 97W
What the hell do these numbers mean?? 🙂 For info i am just about to order new alloys for the car so just trying to make sense of it all. Ta
Posted : 04/03/2014 11:53 am
 sbob
215 is width in mm
55 is the profile as a percentage of the width
R16 is the wheel radius
97 is the load rating
W is the speed rating
I think.
Posted : 04/03/2014 12:00 pm
Some of the measurements can be a bit notional but AFAIK it's
Width/height as %age of width, rim diameter, load rating. So 205/55 will be a slightly lower profile than 205/60.
Edit: Or what he said except it's diameter not radius, but less neat and I forgot the speed rating!
Posted : 04/03/2014 12:02 pm
Someone who doesn't understand tyre sizes obviously,
But thanks for playing 😉
Lots of other sizes will also fit without any problems at all, as mentioned above.
The 215/55/16 offered above being a perfect example.
Posted : 04/03/2014 12:07 pm
Cool, cheers all 🙂
Posted : 04/03/2014 12:20 pm
Here check this link [url= http://www.tyresave.co.uk/tyresize.html ]Tyre Size[/url] It will help you work out how to change the R16 for a R15 but not mess up your speedo too much. As long as you keep the % difference under 5% you should be ok but the closer you can get it the better.
Posted : 04/03/2014 12:35 pm
 br
Based on the questions you've asked, please just go to a reputable garage and ask for new tyres.
And be very aware that if you replace a quality tyre with a budget tyre you may find that if you don't compensate for this while driving you could easily end up in a ditch...
[i]Here check this link Tyre Size It will help you work out how to change the R16 for a R15 but not mess up your speedo too much.
[/i]
What, like new wheels?
Posted : 04/03/2014 12:38 pm
Yup, get some cheap steel wheels, or MyTyres.co.uk will sell you tyres on wheels, Steel wheels only.
Posted : 04/03/2014 12:41 pm
Yes, I do actually know how tyre sizes work thank you very much.
He wanted to keep the size the same, not something you can do when fitting a DIFFERENT size tyre.
Thank you for playing 😉
Posted : 05/03/2014 8:20 am
read the OP again, and notice he asked....
what other sizes could i get and keep the[b] "size"[/b] the same...
Everyone else knew what he meant by putting "size" in inverted commas
Did you not ?
Posted : 05/03/2014 10:44 am
Hence the 😉
Posted : 05/03/2014 10:48 am
Do you put one of those at the end of every post just in case.
Insurance policy in case you need a get out.
Posted : 05/03/2014 10:50 am
Yeah, better be safe than sorry!
Different one this time... 🙄
Posted : 05/03/2014 10:58 am
