Had these flat shoes for a while, but not done all that many miles. The padding hasn't compressed much except for a big dent under my big toe. This is also where I get a blister if I run a long way.
I must be putting a lot of force through my big toe. Seems weird though - anyone else get this? Where else do you get them?
Not overly worried as my running lately seems reasonably effective, but the pain and blister is annoying.
Got my Brooks after a gait analysis and so far haven't suffered any blisters. On my third pair now. The dent under the toe does sound weird though. Is it just in the one shoe or both?
if they're blistering, then I relegate them to gardening duties TBH. did you dent it on a rock maybe?
Under-pronation?
Do you get a similar thing in day to day shoes? If not then the trainers are not for you.
Find a pair that feel like slippers, that's all you need to do.
Are you trying to grip the shoe by clenching your toes ?
Just one foot? Shoes slightly too big? Laces not tied properly?
Just cut the toe off. Problem solved.
Rachel
Both feet. Has also happened in normal shoes, IIRC a pair of DMs I had as school shoes for several years. Maybe because of the way the sole is on those or because I was running around in them.
Dunno - I think I must be pushing off with my toe quite hard but I really don't know I'm doing it.
Sounds like a long shot but try a lace lock (google shows how) shoe is firmly gripped around ankle and may remove need for your toes to want to try and grip the shoe if your foot is sliding forward slightly.
Shoes feel very secure, more than most.
Doesn't everyone push off with their toes?
No. google Pose or chi running.
Just get a pair of Nike Pegasus like the majority of runners.
This. Got mine in 2007, still going strong, never had a problem.
Probably because they don't get anywhere near as much use as they should 😳
I don't run (well not for a LONG time), but yes that happens to me in my biking shoes and (back when I still played) my Table Tennis shoes. I never got blistered there, but did build a HUGE callus.
Hardly a surprise in the TT shoes given the demands of the sport, but never understood it in the bike shoes.
Perhaps it is a core stability issue? You are correcting balance by putting too much pressure on the front of your feet?
Don't you live in the valleys? Suggests running uphill a lot, maybe your leaning forward and putting more pressure there. The alternative is to lean back and fall over more 😀
I live in Cardiff, but round by me there is almost no flat ground, everything's up and down.
I get a black middle toe-nail on one foot from running hills, not really sure why but the skin has hardened around it too. I'm going to change the lacing method to try and stop the trainer moving even if i don't realise it is.
