question for mcmoon...
[Closed] question for mcmoonter or other wood types!... wood for outdoor structures
7 Users
Hello!
Having admired the many posts from mcmoonter, stoner etc im after some advice please..
Looking to make a simple 'cover' to attach to the carport to store things like bikes and other bits of kit. This will be a wooden structure anchored to the paving slabs and fixed to the carport itself. The idea is wooden framework and then clad with a light coloured metal (corrugated or the like) to make it inkeeping with the neighbourhood.
The question is for the wood - do you ask for treated wood at the merchants? Is it easy to find? Or do you treat after the build?
ok thanks in advance,
Posted : 30/08/2013 12:50 pm
Lately I've been using 4x4 fence posts from my local timber merchant. You can get them in ten foot lengths, which allows you to bury them a couple of feet down and still have eight feet above ground to work with. I expect the posts are treated in some way.
I usually build off them with 4x2s. That should be plenty strong enough for your needs.
Posted : 30/08/2013 12:58 pm
merci beaucoup
Posted : 30/08/2013 1:20 pm
scotia - if you're anchoring to the paving slabs you can use a post shoe that can be bolted to the slab - use a resin.
http://www.fencestore.co.uk/fencing-accessories/post-supports/powapost/bolt-down-shoe-100x100mm-post-support
They are sized perfectly for x100mm square treated/dipped 4" posts from your builder's merchant as mcmoonter suggests. Save's digging holes and allows for easy removal. <10' are much cheaper per metre too.
Posted : 30/08/2013 2:34 pm
100mm is too chunky for what you need, so get the 75mm version.
Personally I wouldn't use them, I would buy 100 x47mm timber and afix to the slabs using metal 'L' brackets which could be invisible from the outside and cover with material mentioned.
Posted : 31/08/2013 8:16 am
Use tanalised timber.
Posted : 31/08/2013 8:25 am
ta guys, good advice. Yup i was thinking of connecting to the paving slabs with a bracket. Just in the middle of designing the sliding door..!
Posted : 31/08/2013 9:12 pm
First sign of a good wind and it'll rag the slabs clean up!
Posted : 01/09/2013 7:43 am
If it's built using substantial timber it'll be fine. My 12x10 shed just sits on a concrete base, and it hasn't blown away yet.
Posted : 01/09/2013 8:24 am
