Putting a tv arial ...
[Closed] Putting a tv arial in an attic help please
4 Users
Continuing with my refurb of the attic flat.  I want to put a TV aerial in.  How do I get the cable from the outside in?  Its a roof with full sarking boards - you cannot see the slates from the back. There are no vents in the roof. I only have velux windows and while it could be brought in thru them it would both damage the window and be very untidy as the cable would ( even if a small distance only) have to be run down the wall.  I have easy access to the roof,  easy access to the eve space.  I want to put two points in one on each side of the room.  Running the cable round yhe eves is fine but how do I get it outside to connect to the arial?  I just cannot fathom a way and I am sure I am missing something simple.  I have no vertical external walls - the whole flat is in the roof space.
Help a bewildered old man please.
Posted : 02/06/2018 6:17 pm
Through the fascia, soffitt or barge boards?? Leave a U-shaped loop of cable below the hole so that rain drips off rather then along the cable and in
Posted : 02/06/2018 7:31 pm
Could you put one in the eves space and use a booster? I have this set up and it works well. We are on top of a hill though.
Are there any ventilation bricks to the eve space?
Posted : 02/06/2018 7:34 pm
Should say eaves above.
I was also thinking of the gable when I typed the second sentence, is there space boarded off below the ridge tiles?
Posted : 02/06/2018 8:08 pm
No soffits / fascia / barge boards - the sloping roof runs down to a leaded gutter then a stone parapet outside of the gutter.  georgian stone bulding
No ventilation bricks - its slated roof down to the gutter.  No stonework or external walls - all slated roof or flat roof
Its a flat roof on top - sloping slated roof down the sides  Putting it in the eaves is not a bad idea - might try that - we are indirect line of sight of the transmitter - I can actually see it around 20 miles away
Posted : 02/06/2018 8:24 pm
You should be fine with it in the eaves, given your line of site to the Fife transmitter
Posted : 02/06/2018 9:28 pm
Put the booster next to the aerial, if needed and you will only have minimal extra cabling.
Posted : 02/06/2018 10:02 pm
