PSA -Dualit 4 slice...
PSA -Dualit 4 slice toaster £135
30 Users
100 Reactions
Following on from the other toaster thread, if you're in the market for a fancy one for much less than MRP Costco have a short-term deal ATM if you are someone you know has membership.
£135 - free delivery
https://www.costco.co.uk/Appliances/Small-Kitchen-Appliances/Kettles-Toasters/Dualit-Classic-4-Slot-Toaster-With-Sandwich-Cage-Polished-Stainless-Steel-40590/p/405901
Posted : 22/02/2024 8:47 am
flyingpotatoes, convert, a11y and 5 people reacted
I'm not sure in what world a £135 toaster is a deal
Posted : 22/02/2024 9:20 am
droplinked, funkmasterp, dissonance and 21 people reacted
I’m not sure in what world a £135 toaster is a deal
I'd love to think that the toast is 350% better than my current toast
Posted : 22/02/2024 9:23 am
Does it talk to you?
Posted : 22/02/2024 9:25 am
This world. It will last 20 years, made in the UK. Fantastic even toast compared to the vast majority of toasters.
Imagine a world where people pay £1,000 for a push bike!!
Posted : 22/02/2024 10:31 am
blokeuptheroad, supernova, akeys001 and 7 people reacted
I would definitely buy - if I didn't already have one.
Posted : 22/02/2024 10:54 am
Simon and Simon reacted
Thats a good deal, i bought it at 169, which including cage was already a good deal. Coctco must sell loads at that price, expect to replace elements after 20 years
Posted : 22/02/2024 10:58 am
Imagine a world where people compare toasters to push bikes!!
Posted : 22/02/2024 11:04 am
At the very least.
Posted : 22/02/2024 11:06 am
...some people spend £500 + just to chop-up coffee beans! Fools! 🙂
Posted : 22/02/2024 11:09 am
the-muffin-man Full Member
I’m not sure your opinion is unbiased…
Posted : 22/02/2024 11:30 am
thebunk, tall_martin, thebunk and 1 people reacted
hes shilling for Big-Dough, wake up sheeple!
Posted : 22/02/2024 12:33 pm
towpathman, thebunk, tall_martin and 5 people reacted
I shouldn't rise to this but it's worth the dough.
Ours is 15 years old and still works perfectly. They can be repaired too if there is a problem. Over a 20+yr lifespan you'll probably buy 5 or 6 cheap toasters so it's not that crazy.
Posted : 22/02/2024 12:38 pm
convert, kevt, tall_martin and 3 people reacted
"Imagine a world where people compare toasters to push bikes!!"
Fortunately no one has done that here.
What's relevant is that £135 might be an obscene amount of money for a toaster for someone who doesn't think £1,000 is obscene for a push bike. Or vice versa.
The Dualit at £135 is probably cheaper than a £30 toaster which will need replacing enough time to make it poor value.
Posted : 22/02/2024 12:56 pm
Over a 20+yr lifespan you’ll probably buy 5 or 6 cheap toasters so it’s not that crazy.
Interesting research you've done there. 😂
Posted : 22/02/2024 12:57 pm
Whilst I own one, and really value the way it's made and the fact it is basically a 'toaster for life' and think more stuff should be manufactured to be repairable AND I think it makes great toast....I still chuckle at us for this PSA being a peak STW!
Posted : 22/02/2024 1:00 pm
We’re in the market for a new toaster as the one we have is failing. £135 you say?
Think I’ll check the other thread.
Posted : 22/02/2024 1:14 pm
I'm pretty sure I've never spent more than £10 on a toaster
And I also don't remember ever having to replace one apart from when it didn't fit the decor
I have also never complained about the quality of the toast coming out of the toaster
Don't get me wrong, i'm a fan of toast.....
Posted : 22/02/2024 1:49 pm
funkmasterp, Duggan, funkmasterp and 1 people reacted
Mines 30 yrs old and a design classic.
Posted : 22/02/2024 1:53 pm
We're on our third toaster in 30yrs... the first one died, the second got passed on... third and current one was £2.70 second hand about ten years ago (bought it because it's predecessor didn't have a lifter for getting crumpets and small bits of bread out... which turns out to be essential... and the Dualit also has).
Buy a Dualit if money no object... they look ace and work well... I'd gladly have one... there's no maths that makes them anything other than very expensive though. But don't let that stop you!
Posted : 22/02/2024 1:58 pm
It's an old model on PSA though. The newer ones have the enormously important bagel setting so I'd splash out for a full price direct from Dualit if I were you.
Posted : 22/02/2024 2:04 pm
now if someone had mentioned Bagels.......
I'm assuming if the new model can do bagels it can do hot cross buns without involving the smoke alarm?
Posted : 22/02/2024 2:14 pm
Our £2.70 toaster has that as well... and it's really useful... unless you like your bagels either over toasted on the outside, or under toasted on the inside.
Posted : 22/02/2024 2:18 pm
Some of you want naan of this poshery, what a pitta the thread took such a turn.
Posted : 22/02/2024 2:50 pm
Well done sir, peak STW ;->
The newer ones have the enormously important bagel setting so I’d splash out for a full price direct from Dualit if I were you.
Posted : 22/02/2024 2:51 pm
I'm a big fan of the classic toaster but can't get my head around Dualit as a company. The USP for the toaster is that it's basically a simple design that can do the job and can be repaired easily when it eventually breaks. It's basically just a durable shiny box (that you can scrub up clean if you want to), a simple clockwork timer, a simple lever to raise/lower the toast/bagel whenever you want to check how its doing and some heater elements that are easy to replace when they eventually burn out. They seem to sell pretty much any part as a spare.
All great stuff and I'm a big fan of our classic toaster. Big enough that I bought their kettle and hand mixer. The kettle does boil quickly and the web page says that the element is both replaceable and repairable. Only they don't actually list it as a spare part so I'm not sure how you are supposed to do this. It does match the toaster nicely though 🙂 The mixer is just a plastic hand held mixer like any other really though and again there aren't any parts listed. They could develop a good USP by making everything repairable and supplying all the parts, but other than the toaster they don't.
Posted : 22/02/2024 3:06 pm
My cheap old toaster has that as well. I should have paid more.
The thing with the Dualit range is... lots of the newer stuff is unrepairable... only a few long standing models really are still fully strippable with replacement parts available... they're going backwards on reuse and repair, sadly. Pick carefully...
Posted : 22/02/2024 3:17 pm
If you buy XTR, buy a Dualit
If you're a Deore kind of person, don't
We got a six slot (wife's choice, because of all the kids apparently) and I'm not sure it makes toast better than a cheap one but certainly looks nicer. Only annoying thing is that if it isn't plugged in / switched on at plug then you can go through the motions of making toast and find you still only have bread.
Posted : 22/02/2024 3:42 pm
When it comes to how *other* people spend their money, STW always deliver on the chip on shoulder / reverse snobbery front.
Posted : 22/02/2024 3:51 pm
I'm a 2011 SLX and 2022 GRX600 kind of guy but I've got a Dualit toaster
My life is suddenly meaningless
Posted : 22/02/2024 4:04 pm
When we tried to get our dualit kettle repaired it was cheaper to buy a new one (in a sale) than the repair service fee plus postage.
Toaster, (well 2 slot), the mrs (*who marketing people the world over will love) thinks it looks great, I think that it toasts unevenly, you have to flatten/crush our rather delicious local bakery teacakes (and other thick things), cut down oversized ‘boutique’, loaves, wasteful (doesn’t stop when you pop), if you forget the grandchildren have been it often just acts as a cold whirring timer.
Posted : 22/02/2024 5:16 pm
kelvin and kelvin reacted
Our Dualit toaster that we got as a wedding present 14 years back is on it's 2nd set of heating elements but still works perfectly so we don't need a toaster. T
However they also have the Dualit Classic kettle for £75 (They're £145 on John Lewis) so I've snapped one of them up as our current kettle is slowly dying.
https://www.costco.co.uk/Appliances/Small-Kitchen-Appliances/Kettles-Toasters/Dualit-Classic-17L-Polished-Kettle-72815/p/728150
Don't mind spending money on stuff that's made to last and which I use everyday.
Posted : 22/02/2024 5:19 pm
I feel as if I should've been already aware of Dualit toaster's before this thread?
is it like those fancy vacuum cleaners with the headlight that the sales people would actually come into your house to demo?
an urban folklore thing?
Posted : 22/02/2024 5:21 pm
You're probably reading just a little bit too much into it Alan.
Posted : 22/02/2024 5:30 pm
just don't say Dualit three times whilst looking in the mirror (or the lovely polished surface of the Dualit toaster)
Posted : 22/02/2024 5:37 pm
Toaster? How vulgar. Surely you use the hot plate on the Aga? Peasants.
Posted : 22/02/2024 8:14 pm
funkmasterp, goby, kelvin and 3 people reacted
However they also have the Dualit Classic kettle for £75 (They’re £145 on John Lewis) so I’ve snapped one of them up as our current kettle is slowly dying.
Don’t mind spending money on stuff that’s made to last and which I use everyday.
That's the one I was moaning about earlier in the thread 🙂 It's a lovely kettle in many ways. Looks good (especially sat next to the Dualit Toaster), boils quickly and even sounds good. But it's nothing like the Toaster really. Despite claiming that it is repairable they don't seem to supply any spare parts for it, so (unlike the toaster) you can't actually repair it  yourself.
Ours has developed an annoying fault with the persistence switch not connecting so the button just pops back up when you push it down unless you jiggle it just right. No spare parts available so I'll have to try to bodge a repair.
In truth it's just an expensive kettle. Nice, but no better than any other expensive kettle really.
Posted : 23/02/2024 8:46 am
That kettle looks like it's a bad pourer.
Why do people design tea pots and kettles that don't pour very well. It's a tea pot's one job to do. A kettle has two jobs but it's still crap design.
Posted : 23/02/2024 9:14 am
Put me in the "for a ****ing toaster?" pigeonhole. Our Tefal Toast N Egg cost £35.61 in 2016, and I thought that was expensive.
Posted : 23/02/2024 9:22 am
Does it boil eggs as well?
Posted : 23/02/2024 9:24 am
Never had any problem with the kettle pouring to be honest. I tip it up, the water goes in the cup, what more do you want 🙂
Posted : 23/02/2024 9:25 am
Wow, looked it up. I think that beats a Teasmade.
 Rio
As a PSA to the OP’s PSA, they’re slightly cheaper in store. Picked up the kettle yesterday for £71 at Costco in Watford.
Posted : 23/02/2024 9:37 am
It does, perfectly consistently, for about £99 less than a Dualit (Tefal Toast N Egg @2016 prices, Dualit @ 2024 PSA prices). 🙂
We used to but I eventually persuaded Mrs Door that it needed to go as it was a hateful 1950s hunk of iron that was only good for toast but was on 24/7, drinking oil like I was a Saudi prince. Replaced it with an induction range that, shock horror, you can actually switch off when you're finished.
I'd rather have a decent toaster that looks good, lasts many years and is repairable, than buy cheap buy twice and contribute to the evergrowing problem of defunct stuff going to landfill.
YMMV
Posted : 23/02/2024 9:39 am
As for...the kettle looks like it's a bad pourer - what does that mean?
Unless you've used one any comment about functionality is redundant.
Posted : 23/02/2024 11:10 am
Looks nice if you can afford it. Bit too pricey for me. Our toaster cost about £20 and is going on for 15 years old.
Posted : 23/02/2024 11:25 am
Bought a Breville 4 slice toaster more than 15 years ago cost approx £35 still going strong.
I have probably jinxed it now.
Also it does'nt boil eggs or talk to me for which I àm truly thankful
Posted : 23/02/2024 1:08 pm
As for…the kettle looks like it’s a bad pourer – what does that mean?
it means that it looks like it’s a bad pourer
Posted : 23/02/2024 2:06 pm
I absolutely love toast and toasting things. I support UK industry where I can and purchase items that make long term financial sense.
I do not understand the love for the Dualit toasters.
Every time I've used one the mechanism tends towards "trap and fold" rather than "eject". Anything squishy, like Lakeland Plum Bread, or Malt Loaf, or even lightly toasted split tin loaf just buckles sideways into the mesh.
Vertical ejector for the win!
Posted : 23/02/2024 2:58 pm
Every time I’ve used one the mechanism tends towards “trap and fold” rather than “eject”
My children manage to eject it onto their plates.  Doesn't work with all bread, but it does fire it towards you.
I am sure at some point the leve will snap
Posted : 23/02/2024 3:13 pm
I bloody love toast, and I was chuffed when my SO let me get the dualit. I have yet to test the claimed 160 slices an hour (maybe worth checking that precise figure) but ambition is everything.
Posted : 23/02/2024 5:22 pm
