PSA - Award winning...
PSA - Award winning (T3) Nespresso machine with 100 caps for £52
34 Users
144 Reactions
Philips LM8014/60 Machine and 100 L'or capsules for £60 (including free shipping) from their website with up to 16% cashback available from Topcashback making is ~£52.  That's 25p per coffee INCLUDING the machine!
lorespresso.com
Available in a variety of colours (black, red and white) - the black machine alone is £76 at John Lewis and the red one is over £100.  Take normal Nespresso capsules and even takes BIG Nespresso style capsules if you want a big cup of coffee.
Posted : 04/09/2024 9:18 am
bigginge, a11y, a11y and 1 people reacted
Wow, great price! This machine is really good (as are the L’or capsules IMO). Obviously I’d never use it at home but I got one to put in the van for post-ride espressos 🙂
Posted : 04/09/2024 9:27 am
There must be a catch. Where's the catch?  This might make my wife quite happy.....I need a catch to justify the 'no', but i don't want another machine in our tiny kitchen.  Is there a catch?
Posted : 04/09/2024 9:29 am
Is there a catch?
1) the inherent waste that comes with capsule coffee machines
2) the cost of the pods compared to loose coffee
Posted : 04/09/2024 9:43 am
hightensionline, ads678, leffeboy and 13 people reacted
I know those!  It's my basic reason for resisting.
Posted : 04/09/2024 9:48 am
 rone
Is this just a Nespresso machine - cos that never tasted that good to me when I had one or is it something else?
flyingpotatoes, matt_outandabout, kelvin and 3 people reacted
I have had one of those since May and it's been very good.  Used once or twice a day by one of the kids and for my midday pick me up (I drink a gallon of filter coffee first thing).
I paid £80 including 200 capsules and came to the conclusion that the machine was in effect free. So that price is very very good.
The only slight issue I have had with it is that it doesn't seem to work with some compostable Nespresso Capsules.
Posted : 04/09/2024 9:52 am
Merak and Merak reacted
Is this just a Nespresso machine – cos that never tasted that good to me when I had one or is it something else?
yes - but how good it is, is all down to the particular capsule. My local artisanal roasters make their own which are IMO much better than standard Nespresso ones, and also fully compostable!
Posted : 04/09/2024 10:13 am
flannol, Superficial, flannol and 1 people reacted
Each capsule uses less coffee than a traditional Espresso 14g vs 18-22g which is good for the environment.
Many capsules are recyclable.  We use a pod crusher which squeezes the coffee out and into a composter and the flat aluminium goes to back to Nespresso.
You can also buy refillable capsules which use espresso ground coffee, so less waste and less beans.
It's not as simple as you make it out to be.  I have a Sage Barista, but my wife uses this.
Posted : 04/09/2024 10:26 am
flannol, Kryton57, Kryton57 and 1 people reacted
Thanks for the PSA! My wife said she should get me a machine for my B'day/Chrimble/just because to save me pinching the work one when were away. The boys at the factory will be grateful! With 100 pods the machine is very cheap indeed.
Posted : 04/09/2024 10:30 am
It’s not as simple as you make it out to be
Yes it is. I should flipping hope the capsules are recyclable, but that really doesn't offset the fact that pod machines are inherently wasteful. 6g of coffee is not equivalent to the carbon cost of producing, shipping and recycling (or sadly in many cases putting into landfill) pods.
Reduce > reuse > recycle in that order.
Posted : 04/09/2024 10:31 am
hightensionline, leffeboy, zomg and 11 people reacted
finbarFree Member
Yes it is. I should flipping hope the capsules are recyclable, but that really doesn’t offset the fact that pod machines are inherently wasteful. 6g of coffee is not equivalent to the carbon cost of producing, shipping and recycling (or sadly in many cases putting into landfill) pods.
So, you're making my point for me?  Reduce comes first, right?
https://www.theguardian.com/environment/2023/feb/10/single-use-coffee-pod-environment-impact-better
The paper (and others) which this report links to show that there's substantially less C02 production and water use per coffee for capsules than for Filter coffee.    Whilst waste (assuming not recycled) is a problem, from a CO2 PoV, it is better.
Posted : 04/09/2024 11:06 am
manmurray and manmurray reacted
 zomg
The comparison to filter coffee is likely a deliberate contrivance as it involves more paper use and is a less usual coffee brewing method. An Aeropress might be a closer coffee brewing comparison in quality and budget.
Posted : 04/09/2024 11:35 am
flannol and flannol reacted
And many aren't. And of the ones that are, what proportion of those actually do get recycled? And what about the transport of pods vs the transport of loose coffee, as pods are clearly less space-efficient packaging wise.
Surely the valid comparison is 'traditional' espresso maker?
Posted : 04/09/2024 11:45 am
chrisdw, matt_outandabout, kelvin and 3 people reacted
That explains why I need to use 2 capsules! There's a newer variant of Nespresso that can actually hold enough coffee to make a double shot in one hit... but most machines don't take them, so they're not as readily available.
Posted : 04/09/2024 12:02 pm
Ioneonic and Ioneonic reacted
I think it's because it's North America based research and due to their low voltage, filter coffee machines and Nespresso machines are more common than a proper espresso machine.  The other research in the linked article covered espresso.
But a Nespresso capsule has 5-7g of coffee (normal or lungo) - and a typically double espresso is 18-22g.  So 4-15g is the range of coffee savings.  At 2x coffee a day that's 3-11kg of coffee saved per person, which equates to needing 2-5x as many coffee plants to produce it.  Water, land area, etc.
Posted : 04/09/2024 12:05 pm
Sounds like greenwashing bullshit to me.
Posted : 04/09/2024 12:11 pm
crossed, chambord, leffeboy and 9 people reacted
ALL coffee is damaging and it's a question of how you equate that damage.  Just to say, I don't use a Nespresso, I have a single double espresso every morning from a Sage Barista Pro Touch, and that's me done for the day.  My wife (who does recycle her capsules) has 3 coffees per day from her Nespresso, but she uses less coffee than I do.
We use one of these:
https://www.hotelchocolat.com/uk/podcycler.html?gad_source=1&gclid=Cj0KCQjwiuC2BhDSARIsALOVfBIA3dn6kE5K7e0DAKP2WDWhSeSqzkTvglusxwvWaD1DMX9p2tP5G7caAibMEALw_wcB
And then these:
https://www.nespresso.com/uk/en/order/accessories/original/recycling-bag
And only buy aluminium capsules.
Posted : 04/09/2024 12:15 pm
kelvinFull Member
Then you might want to educate yourself on full lifecycle analysis before passing judgement.
Posted : 04/09/2024 12:19 pm
montymeister, theotherjonv, theotherjonv and 1 people reacted
I've got one of these, also on the £80 with 200 pods. It arrived with a number of bags for recycling the pods. I drop them off at the local recycling centre on my way to work. They do both alloy and plastic pods.
While it might not make the best coffee it certainly makes the best coffee I have the skills or inclination to make. Give me a £4000 machine and it'll still be average!
I get my pods from Kafekapslen in Denmark. They do one trip a week to the UK and sort all the import faff out for you. Huge range of pods, XL, hot choc, etc.
Posted : 04/09/2024 12:26 pm
Anyway - I thought it was a good PSA, perhaps this is the wrong crowd.
MODS - please feel free to delete if it's deemed to be greenwashing, unethical or temper tantrum causing.
supernova, fatbikeandcoffee, wheelsonfire1 and 15 people reacted
There’s a newer variant of Nespresso that can actually hold enough coffee to make a double shot in one hit
yes… this one lol
Posted : 04/09/2024 12:30 pm
supernova, kelvin, supernova and 1 people reacted
£59 for me but great PSA thanks!
Lol at the usual STW descent into petty squabbling/hand wringing 🙂
Posted : 04/09/2024 1:14 pm
I bought one!
Great PSA, I’m well chuffed, been umming and arring for ages but our Eurocamp cabin had one last week and we were pretty impressed with it.
Posted : 04/09/2024 1:25 pm
More a tamper tantrum.
Good price, tempted to replace the Tassimo.
Posted : 04/09/2024 1:41 pm
dc1988, a11y, kelvin and 3 people reacted
It is. Good machine. Let’s not pretend using pods is saving the planet though.
Posted : 04/09/2024 2:28 pm
leffeboy, zomg, zomg and 1 people reacted
There’s a newer variant of Nespresso that can actually hold enough coffee to make a double shot in one hit… but most machines don’t take them, so they’re not as readily available.
That and Nescafe still having a patent on the design, something that long expired on the originals.
If you like long coffees these are good as LOR make XL pods and Jacobs make double filled normal sized ones that Kaffekapslen.co.uk sell. This may be a repeat of what's already been said but I ain't venturing back into the thread.?
Posted : 04/09/2024 3:23 pm
kelvin and kelvin reacted
There's seemingly a couple of those on this thread.
Nice PSA, not for me but I've passed it on to a friend who might be interested.  Ta.
Posted : 04/09/2024 3:36 pm
supernova, leffeboy, squirrelking and 5 people reacted
Cougar, that's the best line I've heard on here for a long time. Bravo
Posted : 04/09/2024 4:06 pm
Applauds Cougar
Posted : 04/09/2024 4:16 pm
Here all week, try the coffee. (-:
Posted : 04/09/2024 4:28 pm
ALL coffee is damaging and it’s a question of how you equate that damage.
But can’t that argument be levelled at everything that we eat and drink? Unless everyone only eats and drinks what they themselves consume, then where do you actually draw the line?
Personally, I’m not much interested in coffee or whizzy machines like these, I’m perfectly capable of putting a coffee bag in a mug and adding hot water, for all I actually care about it, I always drink tea, either regular tea in a bag with milk, or green tea, also in a bag for ease of preparation; I can’t be arsed to make a pot, it’ll have gone cold before I finish the first cup!
Posted : 05/09/2024 1:28 am
 rone
Yep. My coffee prep is a right process involving flushing, cleaning, paper towels, some discarding, beans that have travelled miles etc.
Clearly anything you do has an impact.
I reckon making coffee at home ought to be allowed in this crazy day and age.
Whereas going to Starbucks ...
Posted : 05/09/2024 6:16 am
Surely the less coffee thing is countered by the fact that any sane person ends up using two pods for their coffee......I know I do when I'm at the in-laws because 1 pod makes a pitiful amount of coffee.
Posted : 05/09/2024 6:48 am
 a11y
It is. Thanks - ordered. I'm happy with my decision. Also ordered a Podcycler and supply of bags, although I'll double-check with my local council as apparently aluminium pods can go in one of our recycling bins.
Saved the Kaffekapslen link for future.
And *applauds* Cougar.
Posted : 05/09/2024 8:35 am
mwab65 and mwab65 reacted
Just to add, Discount Dragon usually have cheap coffee pods, for example.
https://discountdragon.co.uk/product/10-x-mild-everyday-coffee-nespresso-pods/
Which appear to be the Kaffekapslen brand mentioned above.
Posted : 05/09/2024 8:48 am
rOcKeTdOg and rOcKeTdOg reacted
Great PSA, thank you. Usually use an aeropress in the house and will continue to do so, but this was so cheap it means I can give one a whirl to see how it goes in my office/garage where I have no running water
Posted : 05/09/2024 9:19 am
But a Nespresso capsule has 5-7g of coffee (normal or lungo) – and a typically double espresso is 18-22g. So 4-15g is the range of coffee savings.
So it makes a smaller coffee.  That's like saying my pint of beer emits less CO2 than yours because it's in a 500ml glass not 568ml.  Now *maybe* Nespresso claim that they use the coffee more efficiently and extract every last drop of flavour and caffeine out of what goes into the pod.  But it never feels like that when I've had them - an 18g double espresso from my machine at home is enough for me, but even having two pods from a Nespresso machine I'm left wanting more*
Convenience wise they're great. Small, no mess, pretty much foolproof. But I've never been convinced for everyday home use.
*this is not 100% scientific.  Nespresso is only ever when on holiday/hotel/b&b.  it may be influenced by alcohol consumption previous night or long slow breakfasts. It could be even the best Nespresso pods I've used are less to my taste than the coffee I buy at home.
Posted : 05/09/2024 10:33 am
 Yak
Smaller espresso? Not convinced.
Normal espresso at home (no pod) and a moka pot on small stove if out. Not sure how a moka pot/gas stove stacks up energy use wise, but certainly less waste/ manufacture of pods etc. I could improve things by switching to a small wood stove for outside use though.
Posted : 05/09/2024 12:01 pm
Whereas going to Starbucks …
Should be a hanging offence?
Posted : 05/09/2024 12:12 pm
 Haze
Cheers for the PSA, snapped one up as I've been considering moving on from instant for some time, but not yet ready for the rabbit hole of bean to cup...
Posted : 06/09/2024 2:45 pm
bubs, trail_rat, bubs and 1 people reacted
to be pedantic (this is STW), b2c only gives you marginally more control than Nespresso! It's when you start worrying about separate grinders etc that you need to be concerned 😉
Posted : 06/09/2024 2:54 pm
Haze and Haze reacted
 Haze
Yeah got that, meant from beans rather than bean to cup machine!
Love the idea and will maybe head that way when time and disposable funds allow...
Posted : 06/09/2024 2:57 pm
@Daffy - thank you for the PSA - I've plumped for a red one - obvs red is faster.
Going to get a pod crusher now.
Looking forward to trying it out now 🙂
Posted : 06/09/2024 3:18 pm
Great PSA thanks! Only drink coffee occasionally and even then no more than one a day so never been able to justify one of these. Handy for guests and kids looking forward to trying hot chocolate.
Posted : 07/09/2024 1:15 pm
Mine arrived today so hoping to get it firing up later. Thanks ?
Posted : 07/09/2024 7:00 pm
https://en.m.wikipedia.org/wiki/Controversies_of_Nestlé
Surprised nobody has left this here yet...
Posted : 07/09/2024 10:11 pm
leffeboy and leffeboy reacted
I don’t believe either Philips or L’or have anything to do with Nestlé
Posted : 08/09/2024 8:47 am
Surprised nobody has left this here yet…
why?  L’or is part of Douwe Egberts and I can’t see any links with Nestle from a quick google.
Posted : 08/09/2024 9:08 am
But the "nes" presso ? The machine is under license but the pods are now - nestle failed to uphold the licensing in legal battles.
Hence why they developed virtuo to try and recapture the licensing.
Posted : 08/09/2024 1:48 pm
Got this and it is great, thanks for the PSA.
Question from a pod machine newbie. What is the difference between pods which are recommended for ristretto/espresso/lungo? Is it just blends or roasts which someone deems more suitable for a given drink type? Ground size?
If I make a lungo from a ristretto pod, will I die? Will it be disgusting? Will I not notice?
Posted : 08/09/2024 10:37 pm
There’s more coffee (7g vs 5g) in a lungo pod vs a normal one so you can extract more coffee from it.  If you try to extract too much from a pod (or espresso for that matter) you’ll end up with a worse tasting coffee.
Posted : 09/09/2024 12:40 am
I’ve got a fully working Vertuo machine in good order I’m trying to offload if anyone wants it.
Posted : 09/09/2024 7:52 am
Picked one of these up. The instructions are pretty sparse but wanted to check something with those that have one.
The ristretto and espresso buttons, with a single press, deliver the listed volume of coffee
The lungo button however, seems to require it to be pressed again to stop it. Basically I can't press it once and it'll deliver 80ml or whatever the listed amount is.
I can see something in the manual about a custom setting where you hold the ristretto button for 4 seconds, and it'll keep on pouring out until you press it again.
Does mine sound faulty or am I missing something
Posted : 25/09/2024 2:52 pm
I convinced the missus to move away from Nestle because #<edited because it beat the swear filter, but it's Fnestle>, but it appears Douwe Egberts is part of Mondelez. Not saying they're as bad as Nestle, but...
https://en.wikipedia.org/wiki/Mondelez_International#Controversies
Posted : 25/09/2024 3:00 pm
@boardingbob
If the Ristretto button is the one on the far right of the machine I just press it and it dispenses a given volume the same as the others
Posted : 25/09/2024 3:40 pm
 a11y
The lungo button however, seems to require it to be pressed again to stop it. Basically I can’t press it once and it’ll deliver 80ml or whatever the listed amount is.
That doesn't sound right. I'm working through the included pods and prefer a long coffee (annoyingly few lungo pods included relative to the ristretto and espresso sizes). One press of my lungo button and it delivers the correct 110ml (or 220ml for XXL pods) without needing to press the button again to stop it. I had a play around with dispensing volumes via the 4-sec press process, but didn't think it improved things so reset it back to the standard volumes for all 3 buttons.
Has anyone found a pod recycler/crusher thing that works will for the XXL pods? I bought the Dualit EcoPress but it's only meant for regular-sized pods and not the XXL ones - it does them, not doesn't always extract all (or even most) of the coffee and occasionally buggers it up completely.
Also, I'm enjoying the Double Lungo Profondo XXLs but struggling to find alternatives in this XXL format. I'm aware this machine is the only one that takes these XXL size but I thought there'd be more choice in these pods. Anyone got suggestions or links for other XXL long coffees?
Posted : 25/09/2024 3:42 pm
 Haze
@boardinbob press and hold the lungo button until it flashes rapidly, releasing and quickly pressing again should cause the machine to carry on pouring until it reaches the minimum amount for a lungo…50ml for a regular pod, 100ml for a double…
https://www.philips.co.uk/c-f/XC000017092/how-to-adjust-the-coffee-amount-of-my-lor-barista-coffee-machine
Same process for the other styles.
Hold all 3 buttons simultaneously to reset to default.
Posted : 25/09/2024 10:16 pm
Has anyone found a pod recycler/crusher thing that works will for the XXL pods? I bought the Dualit EcoPress but it’s only meant for regular-sized pods and not the XXL ones – it does them, not doesn’t always extract all (or even most) of the coffee and occasionally buggers it up completely.
I had exactly the same problem, I found that stabbing an "x" into the flat bit of the big pod with a knife will help it burst when pushed inside out, and then it works pretty well.
Posted : 25/09/2024 11:23 pm
a11y and a11y reacted
