pressure washers
pressure washers
39 Users
6 Reactions
Hi all
I'm in need of a pressure washer to clean my mums patio then for general household duties, cars, van, bikes etc. Halfords have the Karcher K2 on offer for about £100 is this decent or should we spend more? go for a different brand. no need for cordless or bike specific.
any tips advice gratefully received.
thanks
Posted : 04/04/2023 1:27 pm
Don't buy a Karcher!
Nilfisk are worth a look.
Posted : 04/04/2023 1:32 pm
There was a decent pressure washer thread a month or so ago. Karchers weren't the pressure washer to choose if I remember correctly.
Posted : 04/04/2023 1:33 pm
I was told not to buy a Karcher so bought a Nilfisk (?) instead. Absolute garbage. 2 went back under warranty and still ended up with the same symptoms. Gave in and bought a Karcher K2 instead thinking it couldn't be as bad/unreliable as the Nilfisks I had and its been spot on for the last 3 or 4 years I've had it.
Posted : 04/04/2023 1:35 pm
ok will have a look for that, i tried a search but everything seemed to be from a few yrs ago.
In contrast my Nilfisk is head and shoulders better than my old Karcher.
Posted : 04/04/2023 1:38 pm
stumpyjon reacted
I've had Kärcher and Nilfisk. Kärcher was fine, no complaints, I stupidly left it stored outdoors during a heavy freeze and the internals burst. Still worked but leaked horrendously.
Had the Nilfisk for 3 years... it did just stop working end of last summer. Could bring myself to bin it with an eye on repairing. Plugged it in a few weeks back and it mysteriously just worked.
So if it keeps going, it's fine!
Posted : 04/04/2023 1:45 pm
https://singletrackmag.com/forum/topic/pressure-washers-recommendation/
TL;DR - Nilfisk factory outlet.
Posted : 04/04/2023 1:50 pm
I started this ^^^ thread recently. Lots of helpful info in there on this subject
Posted : 04/04/2023 1:56 pm
Had that happen to the previous one and not yet tried the current one after our -10C freeze over winter!
Old one split a piece of plastic inside:
[url= https://live.staticflickr.com/65535/50134186747_d18597804b_c.jp g" target="_blank">https://live.staticflickr.com/65535/50134186747_d18597804b_c.jp g"/> [/img][/url][url= https://flic.kr/p/2jobP58 ]Karcher K3.80[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
I pulled it apart to repair, then lost interest and just bought a new one in the end....
I normally run them dry to try and remove all the water inside before putting away, but can't remember if I did last time....
I suspect it might be dead.
Just purchased a new jet wash after 10+ years with my old Karcher. Made the mistake of leaving lance pipe on for 1st time in 10yrs whilst it was freezing temps. Split the internals 🙁 Otherwise i was confident of another 10 years.
Did my homework on another Karcher. They do a basic version of the K2 which doesnt have the same casing. Its smaller in size but same output etc. Its £60 at B&Q at the moment. I bought that and then spent £18 on a 15m karcher specific hose on ebay. The one that goes to the lance, not the hosepipe. When i use a jetwash its much handier for me to have a really long hose than a handle to carry the karcher about. I set it up and can now walk around without having to bother with the unit.
Posted : 04/04/2023 1:59 pm
binman reacted
I've got an Aldi one that does fine. As good as my old Karcher which was 14 years old before it died
Thanks picked up that other thread now and lots of info there. still no clearer and seems a total gamble but i'll take a punt on something!
cheers
Posted : 04/04/2023 2:44 pm
I picked up a Karcher K2 from Halfords the eve before the first lockdown, still running fine now for patio and cars, do the cars every 3-4 months x 2.
Only issue is the K2 isnt compatible with some 3rd party things like short triggers or foam spray guns. Its the baby of the Karcher range so not as powerful as other models, but hasnt stopped it working fine for me.
Posted : 04/04/2023 3:00 pm
Key thing is to get the patio attachment which makes it so much quicker and cleaner to do
Posted : 04/04/2023 3:31 pm
If you mean the round head thing, found that next to useless. Have to use a narrow lance and blast the lichen etc off cm by cm, which for a 20m2 patio, is very tedious....
Posted : 04/04/2023 3:33 pm
Footfalls, Wet and forget after cleaning, makes it much easier next time.
Nilfisk all the way Karcher are cheap and nasty internals.
Posted : 04/04/2023 3:55 pm
No issues with Karcher here. Got mine from Karcher outlet a few years ago.
Works great and if you're cleaning a patio use a t-racer attachment. Cleans really well and no splashbacks.
If patio is really grubby suggest using something similar to patio magic before and brush in the the Karcher will easily remove it all.
Posted : 04/04/2023 3:57 pm
One year I did coat the whole thing in Polyurethane sealant, after cleaning it (Stoner's recommendation), however, made bugger all difference the next year.
I think the problem is concrete paviers, they have a rough, porous surface, so make it very easier for dirt, lichen etc to get attached....
Before
[url= https://live.staticflickr.com/2003/32085771213_81ed264afe_c.jp g" target="_blank">https://live.staticflickr.com/2003/32085771213_81ed264afe_c.jp g"/> [/img][/url][url= https://flic.kr/p/QTiXVX ]Cleaning patio[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
Several hours later..
[url= https://live.staticflickr.com/3894/32746898672_10a47c6604_c.jp g" target="_blank">https://live.staticflickr.com/3894/32746898672_10a47c6604_c.jp g"/> [/img][/url][url= https://flic.kr/p/RTJq6f ]Cleaning patio[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
Posted : 04/04/2023 4:20 pm
Toolstation have the Karcher K2 and attachment for £100
Karcher Bundle
@footflaps that's a clean patio!
Posted : 04/04/2023 4:26 pm
https://avastore.co.uk/product-category/pressure-washers/
Pricey but seem a lot better built than karcher washers
Posted : 04/04/2023 6:06 pm
If you mean the round head thing, found that next to useless. Have to use a narrow lance and blast the lichen etc off cm by cm, which for a 20m2 patio, is very tedious….
I'd be interested to hear more about this. There's an attachment for my Nilfisk and was wondering whether it was a worthwhile purchase. I don't have a patio but I bought the washer to de-green the concrete backyard and it takes bloody ages (and I dislike looking like Swamp Thing when I've finished).
Posted : 04/04/2023 6:20 pm
 baxy
Bought this one at the weekend. It was £120 but seems to have gone up now. It did a decent job on our path. Longevity yet to be tested.
https://www.screwfix.com/p/titan-ttb2200prw-150bar-electric-high-pressure-washer-2-2kw-230v/165kh
Posted : 04/04/2023 6:43 pm
There’s an attachment for my Nilfisk and was wondering whether it was a worthwhile purchase
All depends.
Basically it spreads the water jet over a line, so the intensity is reduced.
I can barely get our paviers clean using the finest needle lance, so the Tracer head thing or whatever it was called just ended up in the wheelie bin.
Your patio might clean a lot easier, it which case I can see the attraction.
Posted : 04/04/2023 7:05 pm
 cb
The circular attachment is what I use to clean our patio and paths. Really stubborn stuff might need a quick blast with the lance but otherwise the patio head thing saves hours! Obviously the type of stone has an impact - smooth stone really easy, rougher stuff takes more effort because of the friction.
Posted : 04/04/2023 7:12 pm
You might want to spray the patio with some sodium hypochlorite first. The posh word for bleach, it’ll kill the growth without dissolving the stone and it’ll make the job a whole lot easier and quicker.
Posted : 04/04/2023 8:26 pm
 stox
Another Nilfisk recommendation here.
This is worth a look. I bought my dad one from here and it’s been great. Think I paid an extra fiver to extend the warranty.
https://www.nilfiskoutlet.co.uk/products/subcat.asp?mID=Pressure-Washers&sID=Compact
Posted : 04/04/2023 9:05 pm
kayjay reacted
The patio cleaners bundled with pressure washers are usually cheap plastic tat. If you buy a separate one for £40 or so they do a great job
Posted : 04/04/2023 9:39 pm
@footflaps.
When the blocks have dried out, don't forget to brush Kiln Dried Sand all over.
You need to fill the gaps between the block to keep them 'locked' together. You will hsve washed all the sand out by pressure washing.
Posted : 04/04/2023 9:44 pm
 irc
Karcher K2 for £88 via a 20% code at Martin Lewis.
https://www.moneysavingexpert.com/deals/karcher/#54785
Posted : 04/04/2023 9:56 pm
I use Nilfisk with a round patio cleaner. The first patio head quickly broke as it picked up some stones and smashed itself, Nilfisk couriered a larger version to me as a replacement. Over the years it's got less powerful, so I took a closer look last week and realised it was leaking and needed a handful of new o-rings out of the selection box I have. It now goes really fast and is many times quicker than the Lance, and it doesn't spray crap everywhere.
I would never try and clean more than a small area without a patio head
Posted : 04/04/2023 10:10 pm
+1 Nilfisk from the outlet. Just got a refurb'd Titan 120 for £62, barely more than it'd have cost to buy the accessories. I don't think it's really possible for anythng else to compete. They even included a free patio cleaner, apparently when they have orphaned accessories with no packaging they just get rid of them by sending them out with customer orders.
(had a C110 before, also a refurb- it's gone wobbly after about 3 years of living outside in Scotland, it still basically works and I could replace the pressure sensor but it's just not worth it, when the "new" one is so cheap and comes with all the toys)
Posted : 04/04/2023 10:24 pm
The emerging consensus is my experience too;
Wet & Forget > wait a few weeks > Nilfisk with patio head.
Posted : 05/04/2023 12:25 am
Posted : 05/04/2023 6:13 am
I bought one (just for occasional car and decking washing), only used it a few times but seems fine to me. I could see the point it getting something pricier if I were using it a lot or wanted something with more pressure but it's fine for my needs.
Posted : 05/04/2023 7:52 am
There's an ocean of 3rd party adaptowidgets available for karcher washers.
bikes
Gotta love the sound of rusty bearings that have had the grease blasted out of them... Personally I never found the jetwash any use for bikes. Too much exposed mechanics.
Posted : 05/04/2023 9:25 am
Another Nilfisk (Core 140) owner, I found the round patio cleaner to be fine, it give a more consistent wash (no streaks) than just the lance and doesn't have you blasting shit everywhere. I've used a better patio cleaner (more jet inside the hood) on a petrol powered pressure washer, but for home use the Nilfisk one works fine.
I use 'Patio fresh' to kill the algae and mould first, as it's 100% pet friendly
I also got a 3rd party short trigger gun and snow foam attachment to encourage me to wash the car more too.. it's kinda worked
Posted : 05/04/2023 9:51 am
 wbo
If you're going to use the patio attachement you need one with a fair amount of puff, and more than the basic Karchers or they just aren't strong enough. Also, wait till it's been raining so you don't have to fill the pores in the terrace stones up with water, and then before you start soak the lot with prewash.
Posted : 05/04/2023 11:34 am
I'll go against the grain and recommend the Bosch 135 from B &Q. had it for a good few years but only gets pulled out twice a year to do the driveway.
In fact its a job for next week, so you watch....it wont work.
Posted : 05/04/2023 11:42 am
Life is too short to be tackling a patio without one of the round spinning attachments. Saves your back, blasting crap all over the place and lots of time. I've got a middling Nilfisk. Couldn't tell you how old it is, I've had it so long. Has comfortably outlived the similarly priced Karcher and Halfords own brand washers it replaced.
Posted : 05/04/2023 12:01 pm
TBH it depends what you're shifting, when I moved into this place I did the entire (massive, ugly) patio and paths with the spinny nilfisk head on a 110, and just used the spray end for really stubborn bits and for blasting out cracks and gaps. But that was normal person patio dirt. Next time I'll be shifting spilled oil, paint overspray, and general car and bike gunge and the spinny thing probably won't touch that, it'll be chemicals and full power narrow blast. But it'll still be ace for the tidyup.
Posted : 05/04/2023 5:26 pm
Worth checking what Titan ones Screwfix has on offer. Last time I looked the Titan one was a lot more powerful for the same money than a Karcher at the same price range, plus easy to use Screwfix warranty if needed.
There are obviously much better commercial options for more money.
Yup, you can get a 25L drum from farm suppliers for about £20, can dilute as required. Much cheaper and very quickly effective compared to patio cleaners. Over psray will obviously bleach anything else.
Posted : 05/04/2023 5:37 pm
My Karcher K2 packed in after many years use. I replaced with a Titan (refurb from eBay). Only had it a couple of months but so far it's doing well.
Posted : 05/04/2023 7:04 pm
I got a Karcher k2 a couple of years ago - small thing with wheels. I think they do a non wheeled version.
I got a kit that came with the basic patio cleaner. It works great on the rough concrete bits that make up part of our driveway and paths down the sides of the house.
I used Screwfix no nonsense patio sealer afterwards and there's barely any re-growth so far.
I think the pricier Karchers have a better patio tool that is larger and has a brush strip around the edge to keep spray in, while also keeping it quieter on the ground.
The more expensive ones also have better ways of attaching detergent bottles, than a pull out hose with nowhere to stash the bottle which is the way you do it on the K2.
I`ve got a Karcher K4, great bit of kit, got a longer hose for it and the lance with the little spinning ball is excellent for cleaning the drive.
Posted : 05/04/2023 8:24 pm
Our Kärcher has been fine. Stopped once due to clogged input filter, and never let it freeze.
Probably 5 years old now.
Posted : 05/04/2023 8:58 pm
I've had one for 4 years , used regularly for customers drives/patios. Would definitely recommend and buy another when it eventually dies.
Posted : 06/04/2023 7:46 am
