Powertool help
[Closed] Powertool help
9 Users
I need a couple of new power tools (drill and angle grinder). I recall seeing somewhere once a battery drill, but with an optional mains adapter which plugged into the battery slot, and had a curly flex to plug into the mains. It seemed a cool way to have a cordless drill with corded option for prolonged use, especially if said adapater could also plug into the grinder. Most of the work I do would be using the mains cable, but having the battery option would be really handy.
I can't remember who it was made by, and google isn't helping much. Does anyone know what I'm talking about?!
Cheers!
Posted : 07/09/2015 1:26 pm
try www.dibranto.co.uk
But I don't think what your after exists.
At least the chaps above are the cheapest for power tools I've found.
Posted : 07/09/2015 1:56 pm
It does exist, I've used one! Thanks for the link, will check it out. I wonder if I could bodge a dead battery and a mains transformer... 😈
Hilti do a similar thing which allows the battery to be carried on a belt:
Posted : 07/09/2015 1:58 pm
How long are you likely to be using these tools for in one go?
If you get a tool with a couple of batteries and a quick charger then as long as you get enough life out of a battery that the other one can recharge ready to be used then mains isn't needed (you'll get no more power from a mains adapter).
So if you can get, say, 40 minutes 'working time' (this is not 40 minutes of continuous drilling, it includes thinking, measuring, marking etc) from a single charge and have a 40 minute charger the next battery will be ready to use by the time the first is discharged (and so on).
Posted : 07/09/2015 2:10 pm
That's fine in theory. In the past I've struggled with two batteries, but to be fair they were not brand new, and the charger wasn't particularly fast. I was looking at Milwaukee 18V which might perform a bit better than the old cheap Dewalt I had before.
Cheers,
Posted : 07/09/2015 2:23 pm
Makita 18v 3.0amp batteries claim a 22min recharge time with their official charger. haven't timed it but they are pretty rapid to recharge.
Posted : 07/09/2015 2:27 pm
My Dewalt impact driver has 2 batteries that charge quickly enough to keep you going, even during a proper session of rattling in 100's of decking screws.
Posted : 07/09/2015 2:29 pm
No need fora corded drill with modern drivers and batteries. I suspect going for something gimmicky like you describe you'll end up with a poor quality unit or spending more than buy 2 drills. Just get something like a makita lxt with the fast charger (which really is fast). You could get a bare grinder pretty cheaply too although I've not found the cord to be a problem on a grinder (might be handy if you are bike thief)
Posted : 07/09/2015 2:41 pm
[url= http://www.amazon.com/Greenlee-EAC18120-120-Volt-Adapter-Cordless/dp/B004I0Q5PC ]Greenlee[/url] do one in the US, is this what you saw?
As above, modern batteries and chargers are very good
Posted : 08/09/2015 7:02 am
Batteries may be good these days but you can get powerful mains tools dirt cheap. I think I paid 25 quid for mine and it's so much more powerful than my older cordless.
Posted : 08/09/2015 7:08 am
Yes, the price difference for corded is massive. Hadn't realised it till I started looking, but it certainly outweighs the benefit of batteries. I think for the grinder I may go with [url= http://www.toolstation.com/shop/p57085?utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=sQINeRy51_dc&pcrid=46329942863&pkw=&pmt=&gclid=CJjXx9Lx5scCFSkYwwodQtEAIg ]this[/url] one, and [url= http://www.dibranto.co.uk/Milwaukee-M18BPD-421C-M18-18v-Compact-Combi-Hammer-Drill-(1-x-2.0ah)-(1-x-4.0ah)-pid-11593-pType-Package ]this[/url] drill.
Timba - that's the one, thanks. No wonder I was struggling to find it! Price is a bit eye watering as well.
Posted : 08/09/2015 7:14 am
A big problem is battery units operate at low voltage, high current but a mains unit operates at high voltage, low current.
To run a battery drill off the mains you will need a fairly hefty step down adapter which won't be cheap (for something reliable) nor particularly compact.
Posted : 08/09/2015 8:37 am
