Re the fuel economy, 30mpg isn’t much different to the real world economy of the vans a lot of MTB folk tool about in.
20mpg towing is pretty good.
We used Greta for last weekends bank holiday to tow T@batha to a small campsite, we were the only caravan there along with a few tents. Was nice but the weather was rubbish and didn't take any pics.
But anyway.......MrsRNP was out today so tinkering time!
I could hear a clicky bearing in the aux belt area.
Replaced the water pump, tensioner and idler pulley. Noise gone👍 Fully flushed cooling system and refilled.
Then turned my attention to the rear....
The reverse parking sensors have never worked and the chrome boot floor/bumper protector had an annoying dent in it. Replacement was sourced from the Porsche breakers for a few quid. Bumper cover removed and trim replaced, parking sensors removed for further fettling tomorrow
Surface rust ground away from two small areas. The corrosion protection is good and there isn't much rust on the body shell for a 19year old car). The affected areas will be epoxy coated.
[url= https://i.ibb.co/gvLC3nQ/IMG-8123.jp g" target="_blank">https://i.ibb.co/gvLC3nQ/IMG-8123.jp g"/> [/img][/url]
[url= https://i.ibb.co/tDZP6Kr/IMG-8125.jp g" target="_blank">https://i.ibb.co/tDZP6Kr/IMG-8125.jp g"/> [/img][/url]
[url= https://i.ibb.co/YDzc6FF/IMG-8129.jp g" target="_blank">https://i.ibb.co/YDzc6FF/IMG-8129.jp g"/> [/img][/url]
[url= https://i.ibb.co/MGY8PSj/IMG-8131.jp g" target="_blank">https://i.ibb.co/MGY8PSj/IMG-8131.jp g"/> [/img][/url]
[url= https://i.ibb.co/Cwy5cry/IMG-8132.jp g" target="_blank">https://i.ibb.co/Cwy5cry/IMG-8132.jp g"/> [/img][/url]
I saw a bit of a wheeler dealers yesterday, one of the ones with Ant, in America. The car was a cayenne. I think you could teach Ant a thing or 6.
Update time for anyone interested in running a cheap Cayenne!
I've been beaten! I removed the rear bumper, reversing sensors and loom. I checked them with my oscilloscope and found one failed.
However the voltage seemed a little low at 8.5volts. I removed the PDC module and pulled the circuit board out but it was dry and okay. Reassembled with a replacement sensor but still doesn't work.
I'll get Vagcom at some point and track the fault down properly.
Painted the body underside of the bumper area with Jotun epoxy mastic.
Reassembled then did some towing.
I've had a notification set up on eBay for awhile for 18" Cayenne wheels, these popped up - 958 18"'s with new Maxxis all terrains (from a bore score broken V8). Got them for £350. Better ride comfort than with the 19's.
Subframe rust busting next, but unfortunately Greta is having to cover for a few days for my 20 year old Berlingo/Pug Partner daily driver that has shat a CV joint.
[url= https://i.ibb.co/19pPDz8/IMG-8175.jp g" target="_blank">https://i.ibb.co/19pPDz8/IMG-8175.jp g"/> [/img][/url]
[url= https://i.ibb.co/stLX1Qz/IMG-8261.jp g" target="_blank">https://i.ibb.co/stLX1Qz/IMG-8261.jp g"/> [/img][/url]
[url= https://i.ibb.co/SXnhFZV/IMG-8335.jp g" target="_blank">https://i.ibb.co/SXnhFZV/IMG-8335.jp g"/> [/img][/url]
[url= https://i.ibb.co/TRc5LXY/IMG-8363.jp g" target="_blank">https://i.ibb.co/TRc5LXY/IMG-8363.jp g"/> [/img][/url]
[url= https://i.ibb.co/K07Zbw8/IMG-8364.jp g" target="_blank">https://i.ibb.co/K07Zbw8/IMG-8364.jp g"/> [/img][/url]
[url= https://i.ibb.co/4JFv318/IMG-8365.jp g" target="_blank">https://i.ibb.co/4JFv318/IMG-8365.jp g"/> [/img][/url]
[url= https://i.ibb.co/sFrQWpy/IMG-8367.jp g" target="_blank">https://i.ibb.co/sFrQWpy/IMG-8367.jp g"/> [/img][/url]
Another small update and a few photos seeing as mine have disappeared??????.......and nothing much to report! We've been caravaning a few times since to various small quiet campsites (no children/clubhouses etc) and they've been great.
Car running well but only been used for towing, not done anything to it but it's just clicked over at 170k so is having an oil change and a prep for an upcoming roadtrip....
Bought a code reader (£160) as the reverse sensors had beaten me, turns out three of them have failed. New ones bought but not fitted yet.
https://ibb.co/bv3pwGM
https://ibb.co/Mk8pWXW
https://ibb.co/cy6GMKZ
One of the caravan weekends we were in Yorkshire and noticed this poster in Pickering's high street which I thought was a good idea.
Repair not replace.
I miss tangfastics... Can't get them here.
I miss them as well...I seem to go through packets of them at a fantastic rate!
Not towing it will do ~30mpg, the ~20mpg is two up towing. When it’s not towing it’s parked up – it’s not a daily.
Considering my Yamaha-engined 1.7 Zetec Puma with 130bhp would deliver roughly 33mpg, and about 26-27mpg with my bike on a roof-carrier, the Cayenne seems almost frugal considering its a much bigger car, with a much larger engine, and all of the complexity of a full 4x4 system.
I haven’t seen any of the photos, I can’t work out how to open them, sadly, but I’ve long had a desire for a Cayenne, or even better the Touareg with the V10 TDi, properly fitted with off-road kit, ie good underbody protection, an exoskeleton with off-road light bars, winches, towing hitches, etc.
Of course that requires a significant amount of money, they’re even more complicated than the Porsche, due to the active suspension system amongst other things.
One can but dream.
Hurrah! Now I can actually see the car, and I have to say that’s a lovely thing, considering it’s age, it stunning! I envy you the skill set to enable you to do all the work yourself, and the facilities to do it, I have neither, but to be able to keep a car going instead of sending it to CoPart is a great thing, the carbon footprint of its manufacture is being spread over a greater and greater timeline, which is all to the good.
Yeah, Hats off to you, I never thought I'd see the words 'Porche' and 'bangernomics' in the same sentence!
You utter mad man lol!
Another engine oil service as it recently clicked over at 170k also PAS fluid change. Fuel tank brimmed with 470mile range showing.
Last minute rusted exhaust heat shield studs ground off and riv nuts fitted with stainless bolts.
Few extra tools, footpump, LR bottle jack, packets of epoxy, cable ties, jump leads, footpump, anchovies, and bottle of coolant stuffed into the space saver and rear storage areas
Recent PSA Nordisk tent packed. Fridge freezer stocked with Bert's raw food and a few arrival beers.
Sat nav programmed for Fort William, alarm set for 6am........
https://ibb.co/gyv6YYC
https://ibb.co/KqnpMbH
https://ibb.co/bzgh0V1
https://ibb.co/DzFggGS
https://ibb.co/myZLPPF
It shouldn't be 'Have a great trip?' It was a smiley!! Why does this place not work properly?!?!! Haha! Coz I won't out another emoji in here!!
Sat nav programmed for Fort William, alarm set for 6am……..
Was it dark?
Are you wearing sunglasses?
I've never seen a space saver spare like that. Is it solid?
What is that tow hitch attachment you have there RNP
Looks like the Buzzrack P10
Yep - it's a Buzzrack, the boot isn't <i>massive </i>and I have to make sure Bert has enough room so the tent is in one box and cooking gear in the other. If it wasn't for Bert they'd fit inside Tetris style. Very adjustable, easy to fit and solid when tightened up. I think it's possibly better and cheaper than the Thule Easybase's I kept an eye on eBay (Thule no longer make them).
tthewFull Member
I’ve never seen a space saver spare like that. Is it solid?
It has a collapsible sidewall - there's a factory fit 12v air compressor to inflate it in the tool kit. It's never been used which means it might be utter crap and easier to ring the AA?
Currently in Speen Bridge with the PSA Nordisk tent.
https://ibb.co/h1Vpbyh
https://ibb.co/MhtSx01
https://ibb.co/41jFv22
https://ibb.co/nzpjq4Y
https://ibb.co/yN9HWQx
https://ibb.co/pj72Xgc
What's the midge count like? I'm heading in a similar direction soon.
I'll be comparing my driving statistics as well!
we achieve a similar thing to the boxes and a custom rack by strapping one of this kind of thing to a standard bike rack (altura strada)
does the trick nicely, packs into a tiny bag when away, didn't cost an extra £180
Midges aren't great - it's been raining for a few days up till this afternoon (I didn't set off till the forecast got better) and it's a nice still evening. Smidge is working well though.
I did a few full boot redline overtakes of dawdling hire campervans near Glencoe so I don't think the economy is bad.
I've done similar with my Thule RideOn 3 rack (like the one below) a few times. I flip the silver bars which the wheels rest on over so it's more basket shaped then ratchet strap a couple of Lomo Drybag Holdalls to it.
hmm. Midges and nordisk tent. While it has mosi netting doors and windows when I used mine there appeared to be no way to properly seal the front corners (where you can let the groundsheet down and have it flat so not a trip hazard). I'm sure the way they fold up is sufficient for waterproofing but it struck me I'd not want to be anywhere midge-y in it.
Back to civilization and a data connection!
I went from a great campsite at Roy Bridge (Bunroy Park) and a good dog friendly bar/restaurant (The Old Station at Speen Bridge) via the A82 / A87 Great Glen to Skye.
Stayed at Glenbrittle campsite for a few days, amazing place full of hardcore rock climbers and mountain people, beautiful beach and the Cuillin Ridge just behind. Great pizza! Had an early start before it got too hot and did the couple of hour hike up the Loch / tarn. Evening sat on the beach.
Had a little mooch about Skye then went north to Applecross and I'm on the campsite there currently.
I was originally thinking about doing the NC500 but I'd read the negative impact it was having on the locals. That case was made today. Skye has a lot of single track roads with passing places - it works with only a few snarl ups with unconfident drivers. I drove to Applecross up the Bealach na Bà pass and had Billy balls in his massive wheeled Ford Ranger trying to police everyone and people not knowing how to use single road passing spots. I got to Applecross and parked at the heritage centre to have a nosey. The amount of do not shit or light fires here signs makes me not want to add to the negative impact so I'm going to bail out of the NC500 and go inland next.
Car running well - it was designed for these types of roads/roadtrips. It would be wasted driving round a city centre!
https://ibb.co/rvqLyd9
https://ibb.co/X4x3Mf6
https://ibb.co/VNNwQsy
https://ibb.co/KmRw2V2
https://ibb.co/Tqsvdq0
https://ibb.co/yPB7sHb
https://ibb.co/4sBpWR5
https://ibb.co/fF6qscY
https://ibb.co/jLXvqy7
Good to hear the car is performing to your expectations.
I'll be aiming for an anti clockwise nc500 soon.
@retrorick it's exceeded my expectations - it was £500 remember (plus a bit of tinkering). Life in the old dog yet (car, Bert and me!)
My previous NC500 grumpiness has subsided! I'm at the Inn@Applecross, had something tasty to eat, got a pint of local lager whilst watching the sunset with a band playing in the background.
It's like Scotland's answer to Cafe Mambo Ibiza!
https://ibb.co/1TrMpGh
https://ibb.co/NYm50TK
love this thread, both for the sensible approach to keeping a big SUV that had already been manufactured on the road instead of scrapping it and also for the doggo pics. Having been bitten by a dog recently and having had my BiL nearly killed by one today in an over the bars incident, threads like this remind me that dogs are really not the problem, just bad owners. Keep up the good work on both fronts!
I"> http://You are a rubbish hunting dog!!! https://youtu.be/zOecymKx8nI
I don't know how you embed YouTube videos nowadays?
Nice one RNP, you picked a grand week to be up here. ( thumbs up emoji)
From Applecross we went to Gairloch and a larger campsite. It was actually really good - set in the dunes with pitches wherever you wanted. If you explored a bit and were okay driving on sand there were some really good Instagram worthy spots. Once again a beautiful beach and great weather.
From there cut across country to Inverness then down the A9 to Aviemore before heading for home as the weather broke.
What an amazing roadtrip!
Just over 1100 miles @25.3mpg. The rural west coast, Bealach Na Ba, and Skye single track roads really hurt the fuel economy due to constantly stop/starting.
Car worked faultlessly - I know it's a big heavy unloved SUV but doing things like this is where they are in their element. It's parked up again now.
2 issues
1. It needs cruise control. No idea why you wouldn't option a car like this without it. Can be Porsche Classic retrofitted for £500 from main dealer but that's what I paid for the car so need to figure another way of doing it!
2. Has some driveline vibration when it's been parked overnight. Goes away once it's done a few miles so I suspect the rear propshaft CV joint is dry/tired. It's had a prop a few years ago but the cost would indicate it's an eBay cheapo rather than genuine Porsche (£2200) or OEM (GKN £450). Will be sorted before the Christmas roadtrip we are starting to formulate.
A few more pics.
https://ibb.co/qgZv0Cw
https://ibb.co/R9hnGqZ
https://ibb.co/MNNqFz6
https://ibb.co/zFnR9hx
https://ibb.co/gWrRGhk
https://ibb.co/19jTV9T
https://ibb.co/g6vDyYm
https://ibb.co/K0kg8Wm
Great thread, thanks
Goes away once it’s done a few miles so I suspect the rear propshaft CV joint is dry/tired.
Sierra 4x4s suffered with similar. Front propshaft UJ ran too close to the exhaust
Small update - started cleaning up the rear subframe, it was noted on it's MOT as its bit rusty scabby. Always a fun job with a die grinder and Roloc stripping discs. Needs a bit more work before epoxy coating.
Then this weekend we are away in the caravan again, met up with friends in their camper. Lovely quiet campsite, glorious weather and Bert is happy as always
What's the status of the xc90 now rnp? Did that get moved on or is it still being worked on?
What’s the status of the xc90 now rnp? Did that get moved on or is it still being worked on?
The Volvo is downstairs in our house but it's had a bit of a pause due to getting on top of the Porsche and buying & using our caravan. I have just finished rebuilding the XC90's rear subframe with all new bushes, and the underside of the bodywork is clean and ready for epoxy. I'm hoping to get it finished over the winter, then I can fully get to work on the Porsche.
Then you can FULLY get to work on the porky! Hahaha! Love it.
Re cruise control have you tried just plugging in the correct stalk? That works in a lot of cars, failing that it may need a switch changing via a usb lead
https://ibb.co/rkJWwQ3
https://ibb.co/VS6pCpk
It needs a stalk (which I can get from my local Porsche breakers) but there's a cable missing when cruise isn't optioned that needs to be run from the steering column through the bulkhead and spliced into a loom in the engine bay. It then needs to be enabled with PIWIS Porsche diagnostics software. So it's doable but not a priority at the moment.
Dropped MrsSB's car off for a service this morning, they'd parked this outside and I thought of you RNP!
[URL= https://images2.imgbox.com/a1/29/1c75qS59_o.jp g" target="_blank">https://images2.imgbox.com/a1/29/1c75qS59_o.jp g"/> [/IMG][/URL]
Also thought of this recently - theres a tidy looking and reasonably priced early 3.2 manual on Autotrader. Small wheels, steel coil suspension, manual, venerable VR6 engine... prime budget cayenne-ing fodder.
Merely laughing because your already doing what most would think of as a full and proper job.
Also thought of this recently – theres a tidy looking and reasonably priced early 3.2 manual on Autotrader. Small wheels, steel coil suspension, manual, venerable VR6 engine… prime budget cayenne-ing fodder.
Just found it - very nice, it's not often you see them with 17" wheels.
Sorry-just noticed an emoji became a ?
The work I'm doing so far is just to get it back to a mechanical level I'm happy with and to stop the any rust from progressing further. Once the Volvo is done then I'll bring the Cayenne inside and do it properly - remove the rear subframe for shot blasting, rebush everything etc.
Some good friends have a printing company and have done wraps previously, I think the Rothmans Cayennes look awesome so I might go that route.
Just caught up with this thread - Porky’s looking fantastic, and absolutely in its element! Exactly what Porsche designed it for; for £500, and in the hands of someone with an engineering passion, and the space, what a wonderful project.
sharkbaitFree Member
Cool!Shame about the cruise…. That would have been handy.
What will you do about the rear subframe (seeing as you’re not scared of taking cars apart!)?
Small update.
Cruise control
Porsche want ~£500 for the cruise control retro fit kit which consists of the stalk, short length of cable and two pins for the cable to connect into the steering wheel module and main loom. You can't buy the stalk on its own, but the pins are available separately for less than £2.
Ive bought a complete steering wheel module from an Audi Q7 (functionally the same as a Cayenne) for £15 off eBay. I'll remove the stalk and fit it to my module.
Subframe.
Made myself comfy with a bit of foam seeing as I'm going to be under here for quite a few hours! Ground/scraped/chiseled the rust off, treated with Bilt Hamber, let that cure then brushed Bilt Hamber Dynax over the top. I'm going to source a spare subframe, have it shot blasted and do it properly like I've done with my XC90 subframe but this will do for this winter's protection.
Popped the front sill covers off and surprisingly both sides were really good condition, there are some horror stories online of major rot in this area. Hosed a lot of compacted dirt out then popped the covers back on.
And finally - ferry booked yesterday for Christmas road trip.....
Oh, to have the necessary knowledge, skills and space to be able to do something like this! My ideal car.
necessary knowledge
When you run older cars everyone has already had the same problems and they are widely documented on forums etc.
skills
No particular skills needed for this particular job, just patience and determination (it's a bloody awful job that I hate doing). The factory Porsche workshop manual and parts ID is available FOC online for any major tinkering. I haven't had to make any specific tooling yet and have used normal hand tools.
Space
All the jobs on this Porsche have been done outside. It requires a bit of planning and luck with the weather - ie get the car prepped for winter when the weather is nice.
Time
Is the thing I have plenty of which is probably the main difference.
@countzero - keep an eye on autotrader, there are the occasional unmolested genuine cars that values have been dragged down by the blinged up gangsta wanna be pimped Cayennes. Theres a silver 955 in London with the very rare tailgate spare wheel carrier - it might even have the ultra rare locking rear differential. A V6 on coils is pretty easy to maintain, avoid the V8's and diesels if running on a shoestring and stick to pre 2006 for lower road fund.
Great thread!
With that attention to detail you should just be "NissanPrairie" 🙂
I've come on a bit since the mighty Prairie days. We had so many awesome bike and snowboarding roadtrips in that absolute shed of a car before it eventually died of rust 🙁
https://ibb.co/gwRgjDH
https://ibb.co/B2Q6F5X
https://ibb.co/Vj7Jnj5
I can see that now 🙂
And finally – ferry booked yesterday for Christmas road trip…..
But before that we've been down to see friends in St David's Pembrokeshire (550mile round trip).
I know I keep harping on about how good this car is, and nowadays it's probably completely outclassed.....but the motorway weather conditions going were atrocious and it handled the torrential rain absolutely surefootedly. We came back today on the twisty route through the middle of Wales in glorious sunshine and the car wore a different hat as it effortlessly cruised home.
However! Big expenditure is looming.........
It's been flagging a few transfer box faults now for the last couple of journeys. The transfer box is the '2nd gearbox' bolted onto the back of the 'normal' gearbox that then splits the output drive to the front and rear axles. It also contains a lower ratio 'set of gears' for low speed off roading.
It's a big chunk of metal that newer Cayennes don't have.
Bolted to the transfer box is an actuator motor, this operates the high/low range selection. Mine is throwing a fault code as 1st gen Cayennes overworked this actuator causing it to overheat and damage the feedback potentiometer.
New ones are £1200..........
Also of concern is the rear propshaft, this is a well known problem for 955's and Touraregs. The centre support bearing has a thin rubber outer supporting ring that wears fairly quickly. The propshaft then flails around. Mine has been replaced by the previous owner (at a garage) but they bodged the main CV joint cover. As a result it's spun it's grease out and is becoming noisy.
New genuine Porsche propshafts are £2000.......(I don't fit Chinese/eBay/aftermarket junk in any of my cars)
It's also throwing the odd evap valve fault but these are only £35.
Bit of decision making and some tinkering required before it's next big trip out at Christmas. Maybe running a £500 Cayenne isn't so cheap after all, let's see what I come up with......
https://ibb.co/nb3MQG5
https://ibb.co/Kx51dCf
https://ibb.co/5k9JSzy
https://ibb.co/Kq8m9qd
https://ibb.co/5xRpV0Q
It’s a big chunk of metal that newer Cayennes don’t have.
Although the newer Cayennes don't have the low range box they still have transfer box and they still go wrong!
Mine was replaced under warranty.
New ones are £1200……….
Can you get a cheaper VW version, Touareg, etc? Does someone rebuild them in a shed somewhere?
Fingers crossed 🙂
Yes that's what I was about to suggest, the shed-man indy doing refurbishment and upgrades, probably on a swap basis and hopefully half the price of new. Get one from a scrapper to send in if you need to keep the car (? 'Car' seems very inappropriate!) on the road in the meantime.
Hope you find a solution!
How complex is the props aft?
Here in Oz you can get them made. I sat and watched someone make one for me years ago. He even put higher spec joints in "just in case".
It's usually the support bearing that fails - mine has been replaced previously but the garage bodged the centre CV joint cover in the process.
There are lots of options ranging in cost from £150 new Chinese eBay units through to £600 OEM (GKN) and then upwards to new genuine.
https://ibb.co/SvT4nz4
https://ibb.co/Jd45dPB
My thinking at this moment in time is to source a used propshaft from my local Porsche breakers then fit a JXB support bearing upgrade. This mod replaces the outer rubber support ring (you cut it off the bearing) and doesn't require the driveshaft to be split.
Small update.
So we left the thread with a knackered propshaft and a transfer box actuator code......
I'd been keeping an eye on eBay for awhile for used propshafts just to see what came up.
I noticed a good condition used shaft with a 'white sticker' in one of the photos. Zooming in showed it was a recent date GKN (OEM), the listing was for a 3.2 so it hadn't seen Turbo power in its time. I haggled it for £120 delivered.
On delivery it looked like new and the centre bearing support was good. I popped the CV end cover off and repacked it with moly grease then gave the shaft a few layer's of Rustoleum.
The following weekend I dropped the original shaft and mounting plate out. This is why I don't use garages - this centre bearing had been replaced previously (probably with a cheap and nasty unbranded crap), it was dry and knackered. The centre CV cover was bodged and had spun it's grease out. Both CV's are dead and the shaft is headed for the scrap bin.
[url= https://i.ibb.co/DWkW0xX/IMG-9695.jp g" target="_blank">https://i.ibb.co/DWkW0xX/IMG-9695.jp g"/> [/img][/url]
Mounting plate cleaned up and painted, shaft installed and 'aligned' by rack of eye and twist of gob.
[url= https://i.ibb.co/F8bGm40/IMG-9698.jp g" target="_blank">https://i.ibb.co/F8bGm40/IMG-9698.jp g"/> [/img][/url]
Transfer box actuator - I removed this at the same time as the propshaft. I pulled it apart as I'd read of some being 'burnt out' on disassembly. Fairly simple - DC perm mag motor with multi stage epicyclic reduction box to operate the transfer case and a quadrature channel encoder for feedback of position.
Checked it's operation and everything looked okay so I cleaned, greased, painted as required then reinstalled. Fault code needs further investigation.
[url= https://i.ibb.co/mTsFh25/IMG-9662.jp g" target="_blank">https://i.ibb.co/mTsFh25/IMG-9662.jp g"/> [/img][/url]
[url= https://i.ibb.co/XDNVK8N/IMG-9663.jp g" target="_blank">https://i.ibb.co/XDNVK8N/IMG-9663.jp g"/> [/img][/url]
[url= https://i.ibb.co/KVd1GWw/IMG-9666.jp g" target="_blank">https://i.ibb.co/KVd1GWw/IMG-9666.jp g"/> [/img][/url]
Whilst the rear end was raised I pulled the wheels off and cleaned/Dinitrol'd the hubs, brake splash guards etc.
Spark plugs. I hate doing these, it's a simple job but the consequences are huge should something go wrong.
Porsche include a nifty little tool for pulling the coil cable connectors then an eBay tool pulled the coils out of the head. They all looked original and fairly clean.
Hoovered everything before removing the spark plugs.
They all came out okay and looked fine although I don't know how long they've been in.
Nervously screwed the new NGK's in by hand then tightened with my Facom torque wrench.
[url= https://i.ibb.co/VVmDqHD/IMG-9743.jp g" target="_blank">https://i.ibb.co/VVmDqHD/IMG-9743.jp g"/> [/img][/url]
[url= https://i.ibb.co/LzVR2JL/IMG-9744.jp g" target="_blank">https://i.ibb.co/LzVR2JL/IMG-9744.jp g"/> [/img][/url]
[url= https://i.ibb.co/tB9Q0Q7/IMG-9745.jp g" target="_blank">https://i.ibb.co/tB9Q0Q7/IMG-9745.jp g"/> [/img][/url]
[url= https://i.ibb.co/y8bMvL9/IMG-9747.jp g" target="_blank">https://i.ibb.co/y8bMvL9/IMG-9747.jp g"/> [/img][/url]
Test drove and everything's fine, the replacement propshaft has removed the low speed bearing whine and feels more direct / less clunky.
MOT next!...........
I love this thread. FWIW, the P0441 code can be thrown by worse than normal fuel - my GTI throws it every time I fill up in NL after a tank or two in Germany. We used to get transfer box fault codes thrown up on our old L322 as well, which ended up being the potentiometer's track wearing away and the car throwing a fit because all of a sudden it didn't know where it was. Switching between high, low, and back to high again at the next opportunity always cleared it.
I should have mentioned - the torque wrench pictured above cost more than the car!!!!! (Borrowed from work)
Re. the transfer box code that this is throwing - the 4wd system on these Cayenne's is really complex and the cars are very capable (they benchmarked against Ranger Rover's). The actuator changes the high/low ratio selection but also constantly shifts torque front to rear as needed via a set of clutch plates and can lock the clutch pack to emulate a locking centre differential. Early 955's had an over active control module, this resulted in the motors burning out hence why I disassembled mine. Later modules and actuators can be retrofitted but they are fairly rare and you have to search eBay for serial numbers.
Frustratingly the same fault can be thrown due to low battery voltages as the position feedback from the actuators encoder takes 'too long' due to lower voltages driving the motor.
The battery is buried under the passenger seat and is bit of a faff to access so I don't know how old the battery is yet. Further investigation required!
I also made a logo (of sorts) in case I ever start a YouTube channel..... Now I might be good with spanners but I can't draw to save my life, thankfully Chatgpt exists.
Both need further tweaks but I'm using free services so it will take a few more days
https://ibb.co/wBHKtrQ
https://ibb.co/D7dckCf
That logo's ace!
Impressive stuff, all of it.
I've done a Binners and crayon'd out the 50 & 955 numbers and made the background transparent. I think removing the random wheel is beyond my skillset for now.
The 500 is reference to this Cayenne (and my XC90) costing £500
[url= https://i.ibb.co/gzpnZSb/IMG-0148.pn g" target="_blank">https://i.ibb.co/gzpnZSb/IMG-0148.pn g"/> [/img][/url]
Tinkering pretty much complete for now.
Front jacking points are a bit exposed and any galvanising has long since disappeared so the light surface rust was removed then my usual routine of Bilt Hamber to kill any pitted rust followed by Jotun epoxy mastic. Undertray refitted with new stainless bolts. Didn't take any pics.
Ram Xgrip phone mount track attached to the dash top vent.
Had a printing business friend do me a small run of my logo sticker to add to the previous Rothmans and Deus stickers for added coolness.
......and the overnight sailing with dog friendly cabin out of Harwich is booked for the 27th December, the only thing between us and the ferry is the MOT that's booked for this Tuesday, any fails won't leave me much time to resolve. Fingers crossed!
[url= https://i.ibb.co/tHc1qWM/IMG-9910.jp g" target="_blank">https://i.ibb.co/tHc1qWM/IMG-9910.jp g"/> [/img][/url]
[url= https://i.ibb.co/6Yrp2b7/IMG-9903.jp g" target="_blank">https://i.ibb.co/6Yrp2b7/IMG-9903.jp g"/> [/img][/url]
Good luck! I think we're on the same ferry.
We're on the night sailing to Hook of Holland. Our dog Bert will be prowling around so we should be easy to identify if you to say hi / avoid!!!!
[url= https://i.ibb.co/hKMRF0Z/IMG-9397.jp g" target="_blank">https://i.ibb.co/hKMRF0Z/IMG-9397.jp g"/> [/img][/url]
Haha, I'll say hello if I see you. 🙂
MOT passed! No advisorys!
Tester commented how clean and rust free it was underneath. Here's to another year of adventures....
[url= https://i.ibb.co/xY2LWC6/IMG-9917.pn g" target="_blank">https://i.ibb.co/xY2LWC6/IMG-9917.pn g"/> [/img][/url]
[url= https://i.ibb.co/zxCHV3W/IMG-9918.jp g" target="_blank">https://i.ibb.co/zxCHV3W/IMG-9918.jp g"/> [/img][/url]
Yay! I'm sure you expected nothing less
I forgot to include that I'd done a bit more logo tinkering - I registered a free account with Adobe Firefly, I think it's pretty much Chatgpt but with a fancy front end. Adobe Firefly gave me more credits - Chatgpt only allowed a few revisions before locking me out for 24hours.
Anyway, I did a few different colourways. As someone who has no artistic talent at all I was more chuffed with the results of tinkering with digital crayons than I am the car passing it's MOT today!
I also registered 500overland.com - I just need to actually film and edit something now!
[url= https://i.ibb.co/myPf1jj/IMG-0163.pn g" target="_blank">https://i.ibb.co/myPf1jj/IMG-0163.pn g"/> [/img][/url]
[url= https://i.ibb.co/WgfzVR8/IMG-0162.pn g" target="_blank">https://i.ibb.co/WgfzVR8/IMG-0162.pn g"/> [/img][/url]
[url= https://i.ibb.co/rmBwrGX/IMG-0165.jp g" target="_blank">https://i.ibb.co/rmBwrGX/IMG-0165.jp g"/> [/img][/url]
[url= https://i.ibb.co/k8hLZq6/IMG-0166.jp g" target="_blank">https://i.ibb.co/k8hLZq6/IMG-0166.jp g"/> [/img][/url]
@RNP ,if I am ever in an unfortunate situation that involves a plane crash on a desert/remote island,I want you to be one of the other survivors.
#flightofthephoenix 😉 🙂
...DC perm mag motor with multi stage epicyclic reduction box to operate the transfer case and a quadrature channel encoder for feedback of position.
I've about 5% of an idea what this means, but by golly, it's very a very satisfying sentence to read.
So! Christmas out of the way we loaded some tools and our cargo boxes and set off on the 27th for a night sailing out of Harwich with Stenaline to Hook of Holland, traffic was busy all the way with many delays and hold ups.
Me and MrsRNP had a dog friendly cabin and I slept okay, disembarked then slow and steady through Holland with its 100km/h motorway limits. Into Germany and cheaper fuel and higher speed autobahns heading for our overnight hotel in Leipzig.
From there it was our final leg into the Czech Republic and Prague. Bizarrely the temperature plummeted to -5c just after crossing the border. Met up with MrsRNP younger sister (who lives and works in Prague) and parked Greta at the International Hotel.
Just had a great meal and a few drinks!
Our £500 Porsche has once again proved to be an incredible car for this type of journey - roomy, spacious and surefooted, it's only blotted its copybook by blowing one of the small sidelight parking bulbs!
........and that 18hours and 26minutes were spent with the mother in law in the same car!........
[url= https://i.ibb.co/tbKWM2S/IMG-9974.jp g" target="_blank">https://i.ibb.co/tbKWM2S/IMG-9974.jp g"/> [/img][/url]
[url= https://ibb.co/tDfwV3s ][img] https://i.ibb.co/gJ1bk6T/IMG-0013.jp g" target="_blank">https://ibb.co/tDfwV3s ][img] https://i.ibb.co/gJ1bk6T/IMG-0013.jp g"/> [/img][/url]
[url= https://i.ibb.co/4jjK1FR/IMG-0022.jp g" target="_blank">https://i.ibb.co/4jjK1FR/IMG-0022.jp g"/> [/img][/url]
[url= https://i.ibb.co/WVqSPYN/IMG-0060.jp g" target="_blank">https://i.ibb.co/WVqSPYN/IMG-0060.jp g"/> [/img][/url]
[url= https://i.ibb.co/cvMhZHP/IMG-0049.jp g" target="_blank">https://i.ibb.co/cvMhZHP/IMG-0049.jp g"/> [/img][/url]
[url= https://i.ibb.co/ZB4f1t0/IMG-0065.jp g" target="_blank">https://i.ibb.co/ZB4f1t0/IMG-0065.jp g"/> [/img][/url]
[url= https://i.ibb.co/56tdWWm/IMG-0066.jp g" target="_blank">https://i.ibb.co/56tdWWm/IMG-0066.jp g"/> [/img][/url]
[url= https://i.ibb.co/mqDGHbW/IMG-0055.jp g" target="_blank">https://i.ibb.co/mqDGHbW/IMG-0055.jp g"/> [/img][/url]
Was she in the top or bottom box on that rack? ?
Schrödinger’s Mother-in-law?…
Loving this thread! The decal design is outstanding, creating something like that when I was in print and graphics I’d have spent a day or more drawing that up in Illustrator. After coming up with a design.
Nice work, the whole project is delight, thanks for sharing it with us.
…DC perm mag motor with multi stage epicyclic reduction box to operate the transfer case and a quadrature channel encoder for feedback of position.
I’ve about 5% of an idea what this means, but by golly, it’s very a very satisfying sentence to read.
Forgot to say - stripping, cleaning and rebuilding the transfer box actuator has appeared to work, it didn't throw up the '4wd fault' that would have been expected previously.
26mpg average for motorway miles? That's worse than my 944 s2 used to get. Aren't you going to have spent more than the purchase price of the car in fuel on this one trip alone (I think you might be north of £200 already?)
I had a gulp at 26.2 as well. Lovely thread, thanks
