Poorly mower
[Closed] Poorly mower
11 Users
Screwfix Mountfield one - usually starts first time. If i prime it 6-8 times it starts and runs then cuts out. JUst replaced all fuel anyway with fresh and still doing it. Guess is filter or fuel supply - total noob so before i take it apart wondered best place to start !
Posted : 05/06/2018 2:37 pm
Espares have some good video's on what to do:  https://www.espares.co.uk/advice/howto/how-to-fix-a-petrol-lawnmower-that-wont-start
Posted : 05/06/2018 2:52 pm
Blocked air filter? Take it off and see if it runs or just get a new one to rule it out.
Posted : 05/06/2018 2:57 pm
If it's a Mountfield it's probably a Briggs and Stratton. Things to check / change
- Air Filter
- Fuel Filter
- Spark Plugs
- Carb Diaphragm and Gasket
Might need oil change but I don't think this would cause the symptoms you described. B&S engines really easy to work on loads of videos on youtube etc.
Posted : 05/06/2018 3:08 pm
With mine it's usually the air filter. As has been said above, remove it and see if it runs. It's amazing what a difference it makes.
Posted : 05/06/2018 3:51 pm
Take off the air filter and catalyser and the engine will rev its nuts off; you'll get the lawn cut much quicker and have time for a cold beer in the shed before she realises and starts nagging you to put those shelves up.
Posted : 05/06/2018 3:57 pm
 jwt
If it's a Briggs and Stratton there are cheap kits via eBay for plug, carb diaphragm , filters and such.
I had similar issues with my B&S Mountfield, sorted with a spares kit.
Posted : 05/06/2018 3:58 pm
Fuel tank breather blocked.
Posted : 05/06/2018 4:04 pm
As all said above. I just replaced my air filter, spark plug and diaphram last week for about £10 and renewed the oil. Took about 30 mins following YouTube. Running dead good now and simple to do. Not sure what my issue was as i just did the lot, but for the cheapness of bits/ time taken I just went the whole hog.
Posted : 05/06/2018 6:16 pm
Check the cap on the spark plug isn’t coming loose, that’s what has happened to mine a few weeks back
Posted : 05/06/2018 6:18 pm
My Honda did this exact thing a few years ago. I forgot to drain the tank over the winter. Carb was full of gunge so could be a good starting point. It still did it even after changing the fuel ( i hoped it would dissolve the gunge) so I had to clean the carb out.
Posted : 05/06/2018 9:46 pm
