Pool of water at th...
[Closed] Pool of water at the bottom of my windows - HELP!
17 Users
Hi - Am getting of pool of water collecting at the bottom of my down stairs windows each morning. Seals seem to be ok at first glance, any other things it could be?
Posted : 04/12/2015 2:37 pm
 kcal
double glazed?
our single glazed windows pool water at an alarming rate when the weather is of a certain type..
Posted : 04/12/2015 2:44 pm
double.
Posted : 04/12/2015 2:45 pm
 cdoc
My knackered double glazed hall window collects a surprising amount of condensation through the winter, too.
Posted : 04/12/2015 2:47 pm
Inside the sealed Glazing unit? - Seal's busted and glazing unit needs replaced.
On the cill internally? Did it rain overnight? No? - Condensation.
On the cill internally? Did it rain overnight? Yes? - External seals are likely gubbed or window is out of alignment. Get a window fitter to look at them.
Posted : 04/12/2015 2:49 pm
Thanks perchypanther. will look into that.
Posted : 04/12/2015 2:55 pm
 teef
Condensation - the temperature drops overnight below the dew point and the moisture in the air condenses on the coolest surface - the windows. Seems to occur with mild damp days and cooler nights. Either keep the heating on low overnight or maybe get a dehumidifier.
Posted : 04/12/2015 2:57 pm
Have you closed the trickle vents?
They are the little slot vents at the top of the windows.
If you have excess condensation there are a few causes
- No trickle vents
- Curtains remaining closed all day and night leading to an air pocket
- An excess of moisture in the air, Leaks etc
Posted : 04/12/2015 4:23 pm
 hora
Could be a failed unit. I put a pebble through one via my lawnmower a replacement unit cost £90 fitted.
Posted : 04/12/2015 4:26 pm
If they are inward opening the deal is that some water will always get past the seal at the bottom (between sash and frame) and collect in a channel where it drains to the outside via a couple of holes (often sealed up by braindead fitters).
Posted : 04/12/2015 8:23 pm
Condensation. Check the trickle vents are clear,ours were full of swarf.
Vac the sills to clear.
Posted : 04/12/2015 9:07 pm
Condensation ought to occur within the outside brickwork skin or cavity, hence the air bricks and drip on Wall ties. Bricks are porous so if condensation happened in the external brickwork skin it goes to atmosphere.
If it doesn't then it's either
Not enough ventilation,
K value of your wall make up is screwed, meaning your dew point occurs on the inside brickwork ( probably block)
Doubtful it's the second option. Increase ventilation.
Onc level building engineer ought to be able to calculate the theoretical dew point location,
Posted : 04/12/2015 10:10 pm
Aluminium framed Windows are notorious for condensation. We replaced ours with pvc and rarely ever get condensation now .
Posted : 04/12/2015 10:31 pm
Turn it into wine.
Posted : 04/12/2015 10:53 pm
Posted : 04/12/2015 10:58 pm
Condensation, if you're unlucky enough to have trickle vents fitted then open them. Otherwise have the window in question opened very slightly (most uPVC furniture allows you to still lock them in a night vent position).
Always made me laugh when I used to work for a window company how many people would complain at the fact the inside of their windows were wet in a morning yet never opened them.
Posted : 04/12/2015 11:28 pm
Get a Scoopy and wipe off and collect the condensation in the morning. http://www.lakeland.co.uk/24546/The-Scoopy
Posted : 05/12/2015 12:49 am
I had same problem boughta dehumidifier and problems gone
Posted : 05/12/2015 4:43 pm
Of no help but I put it down to "that time of year". The big single-glazed windows in our kitchen just flow with water now - I can wipe them (cue a lake forming) and in half an hour they're soaked again. Coldest part of a fairly damp room etc etc. They don't open. Upstairs Windows the same too.
Posted : 05/12/2015 7:26 pm
