Ply lining a van - ...
[Closed] Ply lining a van - talk to me about it 🤷🏻
5 Users
I've got a 2013 pug expert van (with a row of 3 "back seats" which I use a lot but can come out. I'd like to ply line the floor end to end and ensure I can still get the seats in and out plus access the the load anchor points.
Is it as simple as create a template out of card and then trace onto ply, Jigsaw it and then use self tapping screws to fix to the floor?
Then I am thinking about ply lining the rear cargo area as a part 2 but as it's an ex mobility vehicle the state wheel is in the load area 😭 any suggestions or am I stuck with that as is?
This is as it currently stands with some OSB over the ramp hole - ramp chopped off, the yellow strap is stopping movement of the door latch whilst I work out how to sort it permanently, happy to take suggestions
IMG-20210101-160118907
Posted : 01/01/2021 8:15 pm
You can buy a kit pre cut to fit. Saves much messing around making templates etc.
Posted : 01/01/2021 8:20 pm
Cool, but I am only after certain parts 👍
Posted : 01/01/2021 8:22 pm
Welcome to swing by for a look/strip sometime if you fancy? How you fix down is driven a lot by whats currently on the floor - you can just screw down but need to be aware of what is below. Does the ramp not come out fully?
Posted : 01/01/2021 8:49 pm
Happy for you to have a look @steveh that worked be ace, the ramp would leave a BFO hole in the floor and rear bumper 😭
Posted : 01/01/2021 8:52 pm
Depending on how long you plan to keep the van it might be worth doing that and getting someone to weld the hole up and paint etc.
Posted : 01/01/2021 8:56 pm
Didn't know that was an option tbh
Posted : 01/01/2021 8:57 pm
Should be, have a google or try and find some ex mobility/wheel chair van forums for info/inspiration?
Posted : 01/01/2021 9:19 pm
Remove the ramp gubbins. Weld and paint any holes. Get a replacement bumper from e bay/a breakers.
Depening on how long you plan to keep the vehicle, self tappers through the floor might not be a good idea. Start of rust, going through something underneath.
How about using adhesive and laying a set of battens in first to get a level area to then fix the ply floor to(screws or more adhesive).
Spare wheel.
Small roof box, or rear door mount?
Posted : 02/01/2021 9:45 am
Spare wheel.
Great way to bugger the hinges.
When you have the floor welded up have a hinged wheel mount welded under neath as per factory.
Wheel chair adapted vehicles are cheaper for a reason.
Posted : 02/01/2021 10:00 am
