Plumbing. Isolation...
Plumbing. Isolation valves that don't leak?
9 Users
8 Reactions
Are there any recommended brands?
I understand they might go wrong as they don't get used often but it's really frustrating when you're trying to fix one thing and the f***ing things don't close properly.
Posted : 27/09/2024 10:15 pm
Do you have a cold or hot water tank? If not then I wouldn't bother as you can just turn off at the main isolation tap where the mains comes in.
Posted : 27/09/2024 10:27 pm
Trouble is the main isolation tap shuts off the water to the rest of our flat and the flat upstairs, so individual isolation valves are preferred.
Posted : 27/09/2024 10:34 pm
jeffl and jeffl reacted
Because I’m a bit of a plumbing saddo, I have a yearly reminder in my calendar to go round the house and exercise all the isolation valves and all the radiator lockshields. As with anything mechanical, they don’t like not being used.
Posted : 27/09/2024 10:48 pm
oldnpastit, leffeboy, leffeboy and 1 people reacted
 Bear
Oventrop very spendy though
Posted : 28/09/2024 6:02 am
Ballofix or Pegler, but be prepared for nearly £10 each for 15mm
Posted : 28/09/2024 8:20 am
Happy to pay 10 pounds (though the 50 pounds for Oventrop might be excessive).
I think Toolstation have Pegler
Posted : 28/09/2024 11:05 am
Anything other than ball valves has failed for me. Hep2o washing machine valve was useless after c6 years.
Posted : 28/09/2024 12:14 pm
I'm now discovering that most isolation valves have compression fittings at both ends. A like for like swap means I need 15mm compression on one end and half inch male thread on the other end.
Never straight forward is it?
Posted : 28/09/2024 12:24 pm
You can get flexible tap connectors with a built in valve that are 15mm to 1/2 inch. Dunno if that might be an option.
Posted : 28/09/2024 12:31 pm
 5lab
Thanks 5lab! That's almost perfect but I need the half inch connector to be male instead of female.
Yes I saw the tails with built in valve but they were pushfit at the end and tbh wasn't sure how that works.
Posted : 28/09/2024 12:40 pm
https://www.toolstation.com/flexible-tap-connector-with-isolating-valve/p90613
Bought this exact one last week. I think it's the configuration you are after.
Edit actually maybe not as it's the same connections as 5labs.
Posted : 28/09/2024 1:30 pm
https://www.toolstation.com/flat-faced-male-straight-isolating-valve/p95064
Going to try this one
Posted : 28/09/2024 1:59 pm
Butterfly valves tend to last longer and easier to turn off
Posted : 28/09/2024 7:58 pm
binman and binman reacted
