Plumberists...easie...
Plumberists...easiest way to connect new tap?
4 Users
I'm replacing my kitchen tap with a new monoblock one.
Old tap is copper tails - speedfit Flexi hose - copper pipe supply.
New tap has Flexi tails prefitted which end in 1/2 inch female coupling.
Problem is the new tails are a bit too short. Is there some kind of speedfit coupler to connect 1/2 inch female to a speedfit socket, or is there a better way, bearing in mind I'm not a plumber but usually ok with DIY stuff!
Edit - I found a hep2o connector which is 1/2" to a brass stub but not sure if this works with speedfit stuff
Posted : 23/10/2022 1:32 pm
Can you remove the prefitted flexi tails and just whack on some longer ones?
Posted : 23/10/2022 1:36 pm
Get a longer flexi hose with speedfit coupling
Posted : 23/10/2022 1:43 pm
Easiest way is above. Prob 10mm tails, unscrew and measure.
Or buy push fit 15mm connector, joiner, coupler thingy and make a short extension using a few cms of 15mm copper
Posted : 23/10/2022 1:47 pm
Conversion socket 15mm to 1/2in exist, how short are you?
Posted : 23/10/2022 1:49 pm
Thanks, I'll get some longer monobloc tails, couldn't find them on Screwfix but then remembered Amazon!
Posted : 23/10/2022 2:44 pm
