Photoshop knocking ...
Photoshop knocking out HUGE files
10 Users
 Pook
Not sure why, but photoshop png outputs the other week kicked out some massive files. Now normally the 749x320 png i use is kb size. Small.
These were outputting at 4gb. I've not changed anything, didn't think to look at the file sizes and then my laptop has ground to a memory rammed halt.
Why?? And how can I fix it with limited admin rights on this work laptop?
Posted : 10/07/2022 8:32 pm
are you sure you've got it set to 749x320 pixels rather than mm? (or possibly points)
Posted : 10/07/2022 8:49 pm
Still saving as ping and not accidentally knocked it to bitmap?
(is that still a thing?)
Posted : 10/07/2022 9:38 pm
Yeah, something wrong there. Can't imagine a PNG < 1000px can output anything near Gbs under any circumstances.
Posted : 10/07/2022 9:48 pm
 Pook
Leffe- defo as it's a file I've used for years
Definitely not a bmp either as I did a quick export as png
Posted : 10/07/2022 10:10 pm
Leffe- defo as it’s a file I’ve used for years
bummer - something has changed but it's difficult to see what.  If you had it originally set to points and you had changed the display type then that might explain it but I don't think so as that is a massive change :(.  no more ideas, sorry.  Are you doing something like using photoshop on a different computer from normal?
Posted : 10/07/2022 10:19 pm
 Pook
Sequence of things in recent weeks has been
Small Software update
Mahoosive files produced
Windows update with restart - failed, no space
Photos Photoshop disappears
Begin clearing files
Succeed in reinstall
I can only think that first update tripped something up with how PS was working
Posted : 10/07/2022 10:24 pm
How big are the output files in terms of resolution? Are they definitely 749x320px?
Png files have capability for layers but as far as I can tell, not via Photoshop's quick export function. When you load the file back into Photoshop, does it load as a single layer image?
If you copy the png to an external drive or upload / email it somewhere, does it still take up loads of space? You ruling out a local filesystem issue.
Posted : 10/07/2022 10:31 pm
4GB seems suspiciously close to 2 to the power 32.
Posted : 10/07/2022 10:36 pm
What happens if you create a new file at 749×320 px and save out as a png? Is it still massive?
Posted : 11/07/2022 9:37 am
Adobe have probably switched off the setting that everyone uses all the time, hidden it about 4 menus deep, and replaced it with some bollocks
That's my considered opinion. The ****s
Posted : 11/07/2022 10:47 am
Sounds like it might be saving as a PSB which is a large file format. Photoshop often does this if somethings not right, such as resolution, mode, layers etc.
Check the file is flattened. Check resolution is actually pixels and not meters. Then save a copy as PNG.
Posted : 11/07/2022 10:54 am
Post it up here so we can check it for you 😂
(My money is on unnoticed unit change btw 😀)
Posted : 11/07/2022 11:13 am
