I'm fairly sure I've asked this years ago and I seem to have found somwthing that worked but several installations of windows later I don't know how 🙁
I want to rename a load of photos to a format using the date they were taken, naming along the lines of 2015-08 001
ANyone know how to do this to large batchs of files ?
Free software preferred but ot essential
[url= http://www.faststone.org/ ]http://www.faststone.org/[/url] Resizer should do that for you.
I use EXIFTool, Google for the download on Windows/MAC
When this is run on any folder containing .JPG's it will change the file name from:
effectively renaming it to the second it was taken.
Oooh, thanks
I've had a faststone porogram on here before, so maybe it was that but I'll investigate all of these - cheers
Or you can use Bulk Rename Utility. http://www.bulkrenameutility.co.uk/
It has loads of options for renaming files, including using the date taken from EXIF.
Ah, that is the one I used before, thanks - quite comlex IIRR. May chicken out & use one of the others
