Phone experts..why ...
Phone experts..why has my phone stopped connecting to network after repair?
4 Users
 DrP
Galaxy s20 5g.. a few years old but i love it..no need for new phone..
The charge port was getting loose, with iffy connection to charging/data transfer, so I did a simple charge port swap yesterday (also replaced cracked rear glass cover)..
No issues, a simple 7 screw, 2 plug swap type affair..
Phone works perfectly in terms of 'being an electronic device', and charge port now great.
But...I've lost my mobile network! FFS!
It shows bars, and often 4 or 5g there, but i've got no mobile network connection (on 3).
I can't see how swapping a charge port can affect this, but i guess it must have..
Annoyingly, it does VERY intermittently work..or did initially, now nothing...
Bar swapping the old broken port back in and crossing fingers, any other thoughts?
DrP
Posted : 16/12/2022 9:06 am
Maybe you unclipped a connector inadverently or have crimped/damaged a ribbon cable/connector while taking it apart/putting it back together.
Sounds like you need to open it back up & go over it with a fine tooth comb.
Posted : 16/12/2022 9:53 am
 DrP
i'll give that a try (which emans orgering a sticky glue kit for the s20..which will take a week!), but honestly, it's 2 ribbon cables you pop out to move out the way, then pop back. one goes to teh power board (the bit i replaced) so if that wasn't plugged in, it wouldn't cahrge...
Hmmm...
Curious
DrP
Posted : 16/12/2022 10:17 am
Make sure the SIM card is sat correctly. Maybe it got misaligned when you were messing on.
Posted : 16/12/2022 10:31 am
Anyone else on 3 in the house who you could confirm is getting a signal OK? When I was with them there used to be very occasional few days where the signal just upped and left.
Posted : 16/12/2022 10:48 am
 DrP
yeah - OH's 3 phone workls fine.
Now this is odd....
when i phone my number, it doesn't even ring or go to answer phone.....
WTAF
DrP
Posted : 16/12/2022 11:02 am
 DrP
OK - so it's deffo the phone as my 3 sim works in another phone..
Oddly, I put a friend's EE sim in mine (it's an unlocked phone) and though it reads the SIM, and shows it's EE, it simply can't connect to ANY network!
DrP
Posted : 16/12/2022 11:37 am
