Phone battery charg...
[Closed] Phone battery charging when on 100% but screen on
3 Users
 Aus
So I use my phone as SatNav on my motorbike, so the screen is on permanently. When it gets to 100% battery charge, and the screen is on and SatNav doing its job, is it bad for the battery to leave it still plugged in or should I allow the battery to run down a bit?
And the same for my MacAir, if using it, better to leave running on mains despite it being fully charged ... or not?
Many thanks!
Posted : 18/05/2020 11:59 am
My understanding is that most, if not all modern phones, are designed to prevent over-charging.
And to do so, they actually tell a few fibs. So, when it says it's charging at 100%, it will actually have stopped, allowing the battery to drain, to say 95% before resuming. All the while telling you it's charging at 100%.
No idea if it makes any difference whether the screen is on. But my last phone I pretty much left plugged in all day (for 4 or 5 years) unless I was on the move, with no noticeable loss in battery performance.
Posted : 18/05/2020 12:13 pm
20-80% is the sweet spot for battery longevity. Stuffing electrons into the battery once it is over 80% will reduce its lifespan, as will trying to extract electrons from it once it's below 20%.
So, on the bike, I'd let it run down unless you're going to need it at 100% when you reach your destination.
iPhones will now learn your charging pattern and not charge beyond 80% overnight until you need it. If you normally get up at 7am, it will charge to 80% until 6am then do the final 20%.
Posted : 18/05/2020 12:28 pm
