Philishave or?? bes...
[Closed] Philishave or?? best electric shaver? what are you using?
5 Users
Hi all,
What electric shavers are recommended? what are you or your other half using?
My philishave has just given up after 10 years.
Ta
PS I know wet shaves are better, but sadly I can't do that everyday; my face explodes.
PPS I don't want a beard anymore..
Posted : 19/07/2015 7:52 am
Your face explodes if you wet shave? You just got to explain that one!
I got a Phillips SensoTouch 3D. It is the best electric I have used.
However - I still find a wet quicker, more comfortable and just easier all around.
Vintage double edge safety razor is the way to go.
Posted : 19/07/2015 8:00 am
Ta
I wet shave occasionally, and have a nice razor, but after two days of doing so (and I'm a nearly need two shaves a day type), my face just gets red, sore and spotty, no amount of prep, creams etc change this, so I only wet shave 'for pleasure' occasionally.
Elec for the daily work safe appearance.
Are the foil ones any good? does anyone buy Braun or Remington?
Posted : 19/07/2015 8:07 am
I've got a wet/dry Panasonic foil and it is great, good shave and lasts a good few weeks on a charge.
Posted : 19/07/2015 8:12 am
 Del
recently bought a braun 720. seems decent enough. quite tolerant to my lazy ways of leaving it for a couple of days from time to time and doesn't pull hairs if i do that.
Posted : 19/07/2015 8:15 am
What razor do you use to wet shave?
I too quite sensitive to what shave I do. Electric is uncomfortable unless I soak & lather face (hence why it's no quicker than the DE).
A mild razor with a good DE blade should sort your problem. It may take a while for the grain on your face to adapt (electric razors cut hair in an unruly fashion) but longer term I'd expect better results.
Posted : 19/07/2015 8:54 am
STW, last week.
http://singletrackmag.com/forum/topic/electric-shavers-2
Posted : 19/07/2015 8:55 am
