Paupers corner ..2/...
Paupers corner ..2/£300 max washing machine 7kg min ..used or new ?
11 Users
I like buying used stuff ..both for value and keeping things going . I also fix quite a lot of things which I enjoy and helps a minimal income.
We need another WM ...we have a fairly recent model but it's poor and unreliable.
People might point to miele I would think but due to weight ( I work solo ..billynomates) it might be a struggle to source. Any other suggestions /models to consider old or new ? I do like quality older stuff but economy may be an issue with energy prices . Older models must be fixable re spares etc .
Thanks in advance
PS I need to do a similar thread soon on fridge freezers so forive me !
Posted : 27/12/2022 3:35 pm
 Chew
Have a look on AO.com
Plenty of choice to achieve what you want
Posted : 27/12/2022 3:46 pm
I've a free LG - needs a new tub as it cracked - in central Scotland. It's 6 years old and perfect, apart from the tub fail.
Posted : 27/12/2022 3:49 pm
I'm currently runnin a pair of Beko 8Kg (Beko WTG841B2W_WH) machines - cost £229 in 2018 and they've been great since I've had them.
Some stuff I'm happy to buy used but I'm not so sure about washers.... Dunno.
Posted : 27/12/2022 5:07 pm
We got our last one on a heavy discount (something like half price) as a new return in store at John Lewis. Only difference from an actual new one seemed to be some missing packaging. So might be worth popping in for a look if you have a store nearby.
Posted : 27/12/2022 5:39 pm
We got a discount code a few days after registering on ao.com, then got one of these for £270 a couple of months ago. Only complaint is that it doesn't beep when finished so you forget to empty/reload it. It's night and day to our previous (10 yr old, 6kg) one, much bigger load & faster, it's undoubtedly saving us in electricity compared with the old one.
https://ao.com/product/wtl104121w-beko-washing-machine-white-76347-1.aspx
Posted : 27/12/2022 6:55 pm
Bought a factory damaged one new. Painted the side panel boom done
Posted : 27/12/2022 6:56 pm
With a used washing machine it'd have to be very cheap or Freecycle. They can be dicks. Especially after being moved.
Posted : 27/12/2022 7:09 pm
thanks all . appreciate the advice ..keep it coming ! Out of interest ..is moving WM's really fault inducing ? Never had a problem myself that I remember but handy to know what to be careful of. I've actually got a few units working again over the years ...bad connections fixed by wiggling , replacing the main drum bearing + a few other simple fixes ( replaced solenoid etc )
the scottish LG unit in need of repair is appreciated but collecting from Devon is a little far with current fuel costs ...thanks anyway !
Posted : 27/12/2022 7:10 pm
We bought a top loader a few years back where the drum has opens on the curved surface so the drum is supported by a bearing on both sides of it's spinning axis.
It's a Hotpoint iirc.
It doesn't shake anything like a front loader (I guess because the load isn't acting as a lever on the motor and bearing), it takes up less floor space (about 2/3 of a normal machine) but obviously doesn't fit under a worktop.
Posted : 27/12/2022 7:23 pm
I’ve found Hoover machines easier to repair than some other manufacturers. Parts are readily available and the drum bearings on the models I have worked on have been easy to replace without unobtainable seals that break if you just look at them!
Have a look on Gumtree for something local to you?
Posted : 27/12/2022 7:24 pm
I’ve a Bosch machine I bought second hand 10 year ago. Had to replace the brushes on the motor last year, change out of £20. It’s moved house with me no drama.
Friend had a Beko one with same problem, but parts aren’t available for it.
If you want new check out eBay for scratched / damaged ones? I got a new fridge freezer that way, big scratch down the side, but works perfectly. Big discount, happy days.
Posted : 27/12/2022 9:24 pm
