Painting MDF Kithen...
[Closed] Painting MDF Kithen Units
10 Users
Anyone ever done it? Fancy trying to spray them to get a good finish, anyone any tips before I arse it up!! Thanks
Posted : 25/01/2015 7:21 pm
Bare mdf? Yup spray is the best, though you can get a good finish with a brush with the right paint thickness.
Won't be very durable though IME.
Posted : 25/01/2015 7:25 pm
There have been several threads on bunk beds - one of which at least mentioned a hard-wearing paint finish which had proven very durable. Worth a search!
Edit. Here it is: http://singletrackmag.com/forum/topic/bunkbeds-possible-to-makelearn
Alex Simons post is the one.
Posted : 25/01/2015 7:27 pm
Clean them first with sugar soap - grease will make the paint not stick properly
There is a product call ESP Easy Surface prep - not cheap but really effective way of preparing the surface for paint.
Use eggshell type paint - gloss will show any imperfection
Brushing is fine, need to take your time!
(If you do a search there was a thread about a year or so ago on this subject with pics!)
Posted : 25/01/2015 7:29 pm
Try Annie Sloan chalk paint, it's brush on not spray but Mrs Clatter has done our kitchen and a built in wardrobe with really good results.
Posted : 25/01/2015 7:31 pm
The end "grain" will have a better finish when sealed [url= http://www.amazon.co.uk/Rustins-MDFS250-250ml-Quick-Sealer/dp/B001GU6GP6 ](other products and retailers are available )[/url]
Posted : 26/01/2015 6:19 am
Thanks everyone, I will give it a go.
Posted : 26/01/2015 6:57 am
As long as you seal well, it'll take whatever finish you choose pretty well.
The edges suck up moisture like a sponge so seal well, sand, seal, sand and finish.
Posted : 26/01/2015 7:09 am
A good way to seal is paint with a 50/50 mix of PVA glue and water. honest!
Posted : 26/01/2015 7:20 am
As above make sure everything is well covered and you will need to repeat the painting. We had an MDF kitchen and after a few years it was already falling apart with water ingress, never again.
Posted : 26/01/2015 9:11 am
Paint with at least two coats of vinyl, rubbed down gently between coats with medium wet 'n dry paper used wet.
Posted : 26/01/2015 10:03 am
