Outdoor wood glue?
Outdoor wood glue?
11 Users
2 Reactions
Can anyone recommend a good glue for use on outside wood? I've wedged wood between a fence panel and post as it's difficult to hammer due to the location. The wood is steady but I'm looking for a kind of glue just to add some extra strength. Thanks
Posted : 02/04/2024 9:56 pm
One of the slightly expanding PU glues like Gorilla Glue*
*pretty it that is PU but it is certainly weatherproof
Posted : 02/04/2024 10:09 pm
As WCA says, a D4 PU glue of some sort
Posted : 02/04/2024 10:21 pm
 pk13
Pu is the way messy if you over use it.
Posted : 02/04/2024 10:25 pm
Yeah it takes a bit of practise to use PU glue in terms of how much to apply, but when it expands out of the joint, as long as you just leave it and don't wipe, it'll foam up and generally be pretty easy to remove when set.
Epoxy can be good too, as can Titebond 3.
Posted : 02/04/2024 10:40 pm
PVA?
Posted : 03/04/2024 9:39 am
Pu glue but if you get it on your clothes it will never ever come off. Treat it with utmost respect would be my advice.
Posted : 03/04/2024 10:05 am
as long as you just leave it and don’t wipe, it’ll foam up and generally be pretty easy to remove when set.
This.... Taping up with masking tape the area you want to protect/where the glue might run is also worth five minutes of your time.
Posted : 03/04/2024 10:09 am
Gorilla Glue appears to turn white in the rain. Won't matter if not visible of course (unlike my cack handed usage where I didn't clean up some glue squeeze).
Posted : 03/04/2024 10:10 am
I would have thought epoxy would be the answer here but I use Gorilla for quite a lot of stuff and it's pretty good.
Posted : 03/04/2024 2:30 pm
PVA?
PVA isn't waterproof enough for outside long term
Posted : 03/04/2024 3:01 pm
