OT: Toothbrushes an...
[Closed] OT: Toothbrushes and chargers
27 Users
 Sui
Has anyone ever seen a multi charger of toothbrushes? How do people charge 3 up at the same time (the communal adult one + 2 kids individual). I've got 3 individual charging plates, but run out of sockets that are not otherwise the other end of the house.
Oral B if makes any difference.
cheers
Posted : 27/03/2017 11:41 am
They stay charged for several days. Just operate a rota.
Posted : 27/03/2017 11:51 am
Indeed. Mine needs charging, what, once a month maybe?
Posted : 27/03/2017 11:55 am
Since they all come with the stupid 2 prong plug, remove and wire 2 to a single 3 prong plug with fuse?
But more importantly, why is the base so small compared to how tall they are? Couldn't they flare it a bit to make it more stable when stood up?
Posted : 27/03/2017 11:57 am
Communal adult toothbrush?
Posted : 27/03/2017 11:59 am
As mine has got older the battery runs out quite quickly. Two or three goes on the two-minute timer becomes the point at which I start looking for a new one.
Posted : 27/03/2017 12:00 pm
Change the working bit.
Posted : 27/03/2017 12:01 pm
Charge once a month?? 😯 How often do you use it??
Posted : 27/03/2017 12:02 pm
I use a morning Philips brush and an evening oral-b. I then need to charge them half as often as normal.
Posted : 27/03/2017 12:12 pm
Or make it so it can lay flat on a shelf in a cabinet. But as above, used twice a day they can easily last upto a month.
Posted : 27/03/2017 12:16 pm
 Sui
😀 different heads for the adults. As slowoldgit says, the battery doesn't tend to stay charged once you've had 2 or 3 goes, also Dentist says you should keep them charged, I always notice the effectiveness when it runs down, even when new. I did think about splicing the Base units, though it's probably asking for trouble. Surely there's got to be something?
Posted : 27/03/2017 12:17 pm
Charge once a month?? How often do you use it??
I wondered that ❓
Posted : 27/03/2017 12:20 pm
 mos
NSFW, but has anybody got a Tingletip fir their Oral B?
https://www.amazon.co.uk/tingletip-N4321-Tingletip-Massage-Head/dp/B005VFFIIS
Posted : 27/03/2017 12:23 pm
Twice a day. I'm only brushing my teeth, not cleaning the bath with it.
Posted : 27/03/2017 12:38 pm
Twice a day. I'm only brushing my tooth*, not cleaning the bath with it.
* Contents may have been edited
Posted : 27/03/2017 12:43 pm
 Sui
I'm twice a day, probably about 4 mins each (2 on top, 2 on bottom), surely that's about average non? Brush is probably about 5 years old now, but when fully charged it works well, just wont get that many brushes out of it.
Posted : 27/03/2017 12:46 pm
You are turning it on aren't you......not just using it like a manual toothbrush? My cheapie, always on offer in the supermarket, oral-b needs charging at least once a week. Maybe I should check the other half hasn't been using it with
Posted : 27/03/2017 12:48 pm
Yes, mine goes for about 3 months between charges, used twice a day.
Of course it's only a week at best if I switch it on 🙂
Oral B one I have lasts about five days (got it at Christmas to replace last one) and that's cleaning my teeth in six quadrants as per the pauses from the brush.
Posted : 27/03/2017 12:54 pm
Used to have a Phillips one that lasted ages between charges, but that died after several years. Got an oral B which barely gets 2 of us through 3 days. Will buy a Phillips when this gets too annoying
Posted : 27/03/2017 12:57 pm
My Philips Sonicare lasts a couple of weeks between charges. We don't have a socket in the bathroom so I charge it in the USB travel case.
Posted : 27/03/2017 1:01 pm
There are 4 different models of Braun Leccy brushes in our house and the performance of the battery is quite varied - the cheapo £25 job is very poor, needs charged every 2 days - approx 16 uses
The XLDelta3000GoldstarTitaniumDiamondInterstellar Bluetooth one £120 (I know! it was given to me as a gift from my dentist sister) lasts around 10 days of 8 brushes a day.
Posted : 27/03/2017 1:04 pm
 Sui
time for a new brush i think - mine wasn't cheap, though as is common, i waited until Boots sold it for half price as they do 2-3 times a year...
Posted : 27/03/2017 1:22 pm
I've managed to brush my teeth pretty much since having teeth in the first place without requiring a stopwatch, so I ignore that. (The cynic in me thinks it's just a ploy to make you buy replacement heads more often.)
Also, six quadrants? Sextants maybe.
Posted : 27/03/2017 1:31 pm
Maybe he has one and a half mouths?
Posted : 27/03/2017 2:03 pm
They are often on sale (boots/supermarkets/Amazon) and I get "weeks" rather than "days" out of decent ones.
When the battery starts to not last I've usually already got one I bought last time they were on sale...
Posted : 27/03/2017 2:24 pm
 SamB
Any recommendations on a decent rechargeable? I get about 2 days out of my Oral B one now. Tempted to just go for the default half-price option in Boots atm (OralB 2000 I think) - anything better?
Posted : 27/03/2017 3:11 pm
#Pray4CougarsTeeth
Posted : 27/03/2017 3:15 pm
Bugger. I clicked on mos' link and forgot that your amazon history follows you on every site you visit from now on 🙁
Posted : 27/03/2017 3:16 pm
https://www.amazon.co.uk/gp/history + remove
...or click 'more like this' if you want. 8)
Posted : 27/03/2017 3:17 pm
Posted : 27/03/2017 3:38 pm
STW = sextoyworld 😀
I was wondering if there is such a site, but I expect there is and NO, I do not want a link to it!! 😯
Posted : 28/03/2017 8:16 am
I don't think anyone has said this yet - can't you just use different brush heads? That's why when you buy packets of the Oral B ones they all come with different coloured plastic rings.
Posted : 28/03/2017 8:33 am
Back to the OP, I'm sure I have seen a pair of toothbrushes being sold with a double base in the past, but it may no longer be available. A bit of DIY wiring would be very easy - in fact I've just cannibalised two chargers into one with a longer cable, so that it could reach more comfortably from socket to shelf.
Posted : 28/03/2017 8:45 am
Aye, I'd be interested in a multi charger too OP.
Posted : 28/03/2017 8:51 am
 Sui
@Finbar - think you've missed the point entirely (unless refering to the tingle tip), it's the base that's the issue - i.e. battery running down, not the heads - got plenty of those in bulk.
I've got a few of the base chargers, so i might have a play at making something, but if i blow myself/family up i'm blaming you lot..
just seen this was discussed 4 years ago!!
http://singletrackmag.com/forum/topic/recommend-me-and-electric-toothbrush-with-dual-charging-base
Posted : 28/03/2017 9:52 am
I'm guessing the XLDelta3000GoldstarTitaniumDiamondInterstellar must finally be coming with a li-ion battery., All the others have some sort of [url= http://batteriesplus.co.uk/acatalog/Replacement-AF-Braun-Oral-B-Triumph-Toothbrush-1-2V-NiMH-Bat.html?gclid=Cj0KEQjwk-jGBRCbxoPLld_bp-IBEiQAgJaftZkY6OstpiqNNa7395NCcg0XV1FZQFg6l93kONolmWgaArVx8P8HAQ ]NiMH[/url] NiMh of around the same capacity. Best part of a week when brand new, maybe about 4 days now it's a few years old. The *not bottom of the range* models have faster motors in but I'd have thought they'd run the battery down faster rather than lasting longer.
Posted : 28/03/2017 10:17 am
[quote=Sui ]@Finbar - think you've missed the point entirely (unless refering to the tingle tip), it's the base that's the issue - i.e. battery running down, not the heads - got plenty of those in bulk.
I think [i]you've[/i] missed the point. 😆
If you keep one base on charge and just change the heads when you're going to use it then you only need one plug.
Posted : 28/03/2017 10:20 am
I'm unsure as to why on the amazon link for toothbrushes it was selling these next to them [b]Size Matters Twist Up Nipple and Clitoris Suction Devices Size Matters Twist Up Nipple and Clitoris Suction Devices[/b] do they get the plaque of better?
Posted : 28/03/2017 10:58 am
How do people manage to brush their teeth if they go camping or whatever?
Is using a toothbrush that you actually have to scrub up and down your teeth too arduous an activity for modern humans?
Posted : 29/03/2017 6:29 pm
Use a manual toothbrush. It's shit. Teeth always feel much cleaner, and gums less battered, when I get home.
Posted : 30/03/2017 9:20 am
