Sadly my car failed MOT today and will cost £650 to repair so going to scrap it (only paid £350 for it 3 years ago so been an absolute bargain!).
That was a 2000 1.6 golf and had absolutely no issues with it until this year.
Thinking I might go for a golf again given VW build quality they can reach a high mileage but just thought I'd see if anyone on here had any recommendations.
We have a newer family car so this does mainly local trips and couple days going to work.
Quite like the idea of something a bit more interesting?!?
My son bought a very ancient Honda civic (probably almost as old as him tbh) and thinks it's great.
The FK/FN Honda Civic is a nice thing to sit in and drive and they are pretty bulletproof. We had a 2006 for a few years and then sold to a mate's sister and is still going strong the last I heard. 1.8 petrol engine was surprisingly economical.
£2k doesn't buy much nowadays.
Normally/previously I'd recommend MK4 Golf especially with the 1.9 PD engine, Berlingo or Peugeot partner but only with the 2.0HDI but they feel a bit dinosaur like nowadays being old school diesels with their associated dirty engines.
Toyota Yaris, Carina and Corolla are cockroach cars. I have a soft spot for Fiat Pandas and looked after my sister in law's so know they are good simple reliable cars. French stuff is good because they don't rust (but will have electrical issues)
Other than that look for larger capacity non turbo petrol engines cars - avoid smaller turbo engined cars. Check the MOT history and look especially for cars with decent branded tyres, filters, batteries etc - ie one that's been looked after.
Whatever you find locally with a good owner, great history and in good condition. Simpler the better. Older the engine tech the better.
I would avoid 'problem' models or unusual, but beyond that just buy from and owner and history you think "know what, they've looked after this"...
Second opinion on the golf? A 2k car comes with it's own problems so maybe fixing it an option. Appreciate it's a pretty old car tho
Where do you live?
Edit: something like this
Have a look at the Shed of the Week over on Piston Heads? Interesting/left-field/risky ideas for £2k or under.
I bought a 70000 mile citroen C3 a couple of years ago for £1200. I replaced the discs and pads for £350 and its not missed a beat since. No electrical, or any other, problems at all.
if you are not in a ULEZ / LEZ area and not likely to visit a big city you might be able to pick up a bargain. If you are then shop carefully.
My 2013 Renault Megane Estate is up for sale soon. 150k miles, drives lovely still. I’m going to get it MOT’d then punting it out for £1k. The OH says that’s too cheap, but it cost me £3k 5 years ago, we’ve done 60k miles in it, (with virtually nothing going wrong with it), so if I get £1k, I’d be happy. It’s not ULEZ friendly, so its value will plummet soon I think, if not already.
What's it failed the MOT on? Structural rust and knackered suspension or a couple of tyres and some brakes?
Agree, if it’s a good un spend the £650 and invest the remaining £1350 in C&H
+1 on what's the MOT work for? If it's just wear and tear items then i'd spend the money and keep the car.
We inherited a car recently that nominally would sell for 4k ish. We had to spend nearly 2k on routine maintenance and replacing wear items. Buying a new to you car is far from buying a trouble free car. Your 2k car could easily have huge bills.
If you are set on a new to you car then buy on condition and how well it's been maintained rather than a particular model or manufacturer.
This is the failure reasons. Might get a few quotes from other garages
Ford Focus ST170. Still can be had under 2k easily and if you look after it you could well sell for a profit.
Can I suggest that whatever car you do get that you check your tyres for wear occasionally?
I'd get it fixed.
You need a pair of tyres = consumable
Brake system - not sure what handbrake type you have but that reads like it's a cable / caliper issue - easy problem to end up with on any replacement and top and bottom points quite possibly connected.
Coil spring - par for the course at that mileage could happen to your next car the day after you buy it (lost a number of springs around 100k on various cars)
Position lamp = side light in old speak? Possibly as simple as just a bulb or bad connector.
How's your mechanical skills?
<p style="text-align: left;">New tyres, springs and a bulb, then sort the handbrake. Keep it.</p>
That's a fix job.
Thats all standard stuff. You buy a snotter you run the risk of more
This is the detailed brake requirements from a quick Google of MOT manual.
Might cost £650, might be less if you shop around. But none of them are dealbreakers or indicative it's about to junk itself, least of all two tyres (consumables)
You'll still be £1350 up on a £2K new car and that could have very similar issues.
Just to add my mum has one of those and iirc it's done a fair few miles than yours (not 100% on that but it's a 2002) and not had the easiest of car lives. It throws up the odd bill but it will probably be here and still running after the end of days!
You can get helper springs for the rear caliper handbrake mechanism that help retract it. I put them on my snotter £400 Mk4 Golf.
Otherwise I'd get it sorted and run it for at least another year especially as rust/corrosion isn't mentioned. Cheap motoring and less hassle than buying something else.
https://www.ebay.co.uk/itm/262990043034
Good advice there from 2019.
At this price everything is a gamble, not many come with 12 months MOT, so you're buying and hoping they don't fail, you're at the wrong end of the bathtub curve as well with major issues arising around this time in their life.
If you can spend 650 quid and get 12 months MOT on your car, then that might be the best bet.
Not sure how you've failed the secondary and park brake ones, i thought it would only be 1.3.1 that was the major, and 1.4.2 was not applicable due to this, then again i'm not an MOT tester so just struggling to understand how you can fail both, still means you have to get it fixed though 🤣
Forgot to add, 123k miles is not a lot on that car, one thing i would check is the bodywork for any rust areas, that tends to be something that doesn't get better with age!
mx5. interesting, cheap to run, pretty much bombproof, just set aside an annual budget for welding rust.
As above my work colleague has an 08 Golf Tdi with 200k miles, it's rusting from the inside out quite badly now on the sills
Squirt some Bilt Hamber S50 inside the sills to guard against them rusting.
Have you checked the MOT history on that ^ ?? It's ****ed.
I only looked as MrsRNP had a similar arctic MX5 but the petrol blue version.
I can’t believe we’re this far in and nobody has mentioned an Octavia vRS
Standards are slipping around here
£650 seems expensive for that, get some internet prices for tyres and someone else to quote for the spring. Handbrake could be as simple as adjusting it, or as expensive as a new caliper - do some research.
But that's a fixer upper.
That’s a fix job.
For that list of stuff it is definitely a fix it situation. With the market being so crazy (10 year old cars are worth at least £3k+ if not more) anything you buy will be something that's being punted on due to upcoming issues. Hell, my car is on 186k at 10 years old and needs £1k of work before the next MOT (two new tyres, front discs and pads, front dampers and top mounts. Will do the brakes myself though) and it'll be getting the work done without question. It would actually pass without any of it bar the tyres (at 2.5mm now so won't last until January) but I like to look after my cars subscribing to the 'Preventative Maintenance' school of thought but they are all tired and do need doing.
Two new tyres*, a parking brake adjustment, a bulb and a spring is just regular maintenance at that age and mileage!
* I would be embarrassed to present a car for MOT with knackered tyres, the bulb could have just blown but it does point to you not checking the car at all!
Get it fixed 🔧
My fabia diesel estate is 20 years old, on 170 000 miles, needed £500 spent to get through MOT (mainly worn discs), bargain.
Yes I d get it fixed, YouTube will help you understand the problems. Light bulb is a quid, may as well do both sides.
Try your local scrap yard for 2 tyres.
Just pay for the work you can't do.
Better the devil you know, and good luck, plenty of life left in the car.
Agree with fixing it. You wouldn't toss a bike out because it needed a bottom bracket - this is no different. ALL those things could easily go wrong with a £2k car as soon as you drive it away, and a whole lot more expensive stuff besides.
Cars have consumables and they have maintenance requirements - that's all you are seeing there.
Don't do this. Get mid range new tyres. This is not a repair, it's the cost of motoring just like fuel and oil.
If you do decide to buy at that price look for dull car driven by dull people.
Namely: Small Suzukis - Alto, Celerio, Splash. Never going to set the world on fire and stupidly reliable.
I will go one further.
You'd be bloody mental to dodge paying to fix that wear an tear and spunking 2k that will almost definitely need work within the year.
With the exception of the tyres I have DIY'd everything on the list. And had our local garage fix similar for not much.
But seriously as someone posted already don't be a dick, check your tyres for everyones sake.
Definitely fix that. It's not that bad of a failure. If handy with a spanner you could do some yourself as said.
sharkattack
Ford Focus ST170. Still can be had under 2k easily and if you look after it you could well sell for a profit.Good advice there from 2019
Yeah, they started to climb in value a long time ago. Lovely handling car, just need a bit more power but definitely better than a golf MK4 GTi in my opinion. The only cheap ones now tend to have rust issues.
I'll give a stw answer:
Berlingo multispace with a remap. The feeling of smugness as your little van swallows kids, mountain bikes and tumble dryers....
We've an Smax, Mk7 fiesta st and a 22 year old Berlingo hdi. 9/10 times I pick to drive the old bingo.
Never bored with a ford: a fiesta st 150 can be had for 2k and under. 2.0 duratec. You'll only get about 34mpg, not the quickest compared to its peers at 0-7.9 but it has sublime handling and is a nice car to daily and doesn't seem so common these days.
Never bored with a ford: a fiesta st 150 can be had for 2k and under. 2.0 duratec. You’ll only get about 34mpg, not the quickest compared to its peers at 0-7.9 but it has sublime handling and is a nice car to daily and doesn’t seem so common these days.
Nice car to drive daily. Depending on location. Mine was grim over the setts of Edinburgh. Swear I am an inch shorter since.
What engine is yours and who did the remap?
Only asking as I have a '04 Peugeot Partner with the 2.0Hdi
Yeah definitely repair, I'd diy most if not all. Never done a spring but there will be loads of info on the web how to do it on a golf
Re tyres, yes mid range new would be my position too. Plus get your alignment checked while your in the fitters
Even if you spend the 650 for the work, you'll have spent a grand overall and still have a car you know with 12 months mot. Not too bad a position
Only asking as I have a ’04 Peugeot Partner with the 2.0Hdi
It's a 2.0 hdi, I imagine the clutch will give at some point as I'm on 128k.
"Psa performance" buy an ecu with a map on it on eBay. About £100. Seems silly cheap but it works. Definitely got more poke. Same on fuel.
Also defeats the immobiliser though. Which suits me as the flashing key light is bound to rear it's head at some point:
https://sites.google.com/goingslow.co.uk/psaperformance/home
Did anyone say you should fix that yet? 😀
But yeah, get it fixed and keep it going. I spend more than that keeping my van on the road each year.
Don't think so - good shout that - I'd fix as well! 🤣
I pretty much always budget for £500 every MOT - there's nearly always something you've not thought about. My cars are 16 and 21 years old though!
Putting a car into an MOT with bald tyres reminds me how crap people are with looking after their cars - and how no one on the road can be trusted.
If you're following someone with decent tyres in and they slam on, say a kid ran out, odds on you'd run straight into the back of them.
#slacker
So your looking at 2 tires (say 150 quid fitted)
a spring (100 quid)
caliper( 100 quid)
and possibly a bit of faffing.
get it fixed
The bigger question is did you know about any of these before you put it in for the mot? do you do things like check tire pressures or just get an mot and thats it for a year (like the wife)
Do you have a breakdown of the £650...how much was for tyres?
You can easily shop around for tyres and knock a few quid off. If costs are tight, part worn (used to be £10/£15 each) would see you through a month or two before upgrading to mid-range new tyres and help space the cost out.
I'm still a member of a FB ST170 group and there are plenty that come up under 2k. As long as you are happy with a 5 door base spec rather than an imperial blue 3 door with leather Recaro's and all the optional packs.
intheborders
Putting a car into an MOT with bald tyres reminds me how crap people are with looking after their cars – and how no one on the road can be trusted.
Bit of an eye opener sitting in a tyre place a while back waiting for a slow puncture to be repaired on a Sat morning. In the space of 30mins, 3 different people came in, all asking if they could get new tyre fitted as their cars had just failed the MOT for bald tyres.
One needed all 4.
One just needed 1 on the front (sounded like an alignment issue as it was knackered inside edge)
One needed 2 new fronts, as they were down to the casing.
My brother insisted on getting a car with a 5* NCAP safety rating when his kids came along & then moaned when it failed the MOT because the front tyres were bald.
ANYWAY - yeah, I would repair.
^ yeah, all this. It's most likely very common that folk do nothing about tyres or any maintenance items unless it's at a service or MOT. At least that's likely to be 2x per year that stuff gets looked at. Modern cars with monitors for this and that have probably helped in taking away the mindset of preventative checking of tyres, pressures, fluid levels etc on a regular basis.
Yeah, I would fix all that and carry on driving it unless there are other reasons for needing a different car.
Fix it. Tyres are a daft thing to fail on to be fair so need replaced anyway.
A £2k car will have a whole host of problems you don't know about and may end up fixing sooner rather than later.
Those issues are all largely service items. There's nothing pointing to the car being dangerous such as corrosion, or expensive to fix engine parts. If you spend £650, then you have a car with 1 yrs MOT and that must be worth £1k, with a wash and polish.
Or you spend £2k, and then have to change that cars tyres next year anyway......
I'm wondering whether anyone who is saying fix it has actually driven a 23 year old golf recently... it's perfectly reasonable to be happy to get rid imo.
rsl1
I’m wondering whether anyone who is saying fix it has actually driven a 23 year old golf recently… it’s perfectly reasonable to be happy to get rid imo.
Why get rid? It still functions as a car for getting from A to B despite not having Apple car play or massaging seats.
I've got a 20 year old MK4 Golf 1.4E and happily spend £300 to £500 a year to keep it going!(I've just replaced the front suspension) It's basic but will happily do 70mph all day on the motorway.
I think it's great!
Perhaps if he was looking at a much newer car - but he's not. At a budget £2k it'll still be an old car he's looking at.
And 20 year old cars aren't like driving a Morris Minor!
20 year old cars are just getting tot hat point where by they dont seem modern to me. Its strange that the kids at work arnt interested in engine size or badge, its all about the interior for them.
Having said that one of them almost took me out on a round about yesterday as they were speeding and operating their in car tv
It's a golf, it's petrol, it'll drive similar to similar today if the steering and suspension are ok, the Mk4 was pretty much the best for finish and since then each mark has had a lower build cost vs retail cost, with 123k miles as well, his Mk4 hasn't exactly been around the clock either, so confidence that the transmission should be sound.
Nonsense. I had a similar vintage car for a few years and although lots of fun it was a million miles away from modern standards. The mk4 Golf might be solid but it was seen as dynamically poor even back then so won't have improved.
I'd avoid 'interesting' with that budget.
I've just had my nans car valued at about 2.1k.
2011 1.2 micra, 30k on the clock, so basically brand new, new tyres all round (not due to wear, they had plenty of tread but were of 2011 vintage0
and new battery, superb condition, FNSH, tax is 35 quid a year, and it does 50 to the gallon according to the trip computer, aircon, cruise control.
Exciting, it isn't, but it's a fabulous little runabout... I'm not selling it, I'm keeping it (so not a stealth ad).. but just to give you an idea of what you can get for your budget if you don't care about street cred 🙂
So I would be looking at small Jap cars, owened by ex-pensioners for best VFM.
The mk4 Golf might be solid but it was seen as dynamically poor even back then so won’t have improved.
Who cares it's reliable and cheap to run!
