Afternoon all
I have some 100mm posts I need to saw through for a garden project. My bow saw is bloody hard work and so I am thinking of getting a cheap circular saw from screwfix. It gets great reviews and only costs £35 but it also only claims to be able to saw through 66mm
Do you think I will be able to cut through one side easily and then simply turn it over and do the other? And therefore cut through nice and easy?
Appreciate it might sound obvious but wonder if anyone has any experience...
Thanks!
How accurate a cut do you need? If it is just a roughish cut I would get one of these rather than a circular saw.
http://www.screwfix.com/p/erbauer-erb373rsp-1100w-reciprocating-saw-240v/80388
Rich.
If I were you I'd look at getting a mitre saw instead. Circular saws are really for cutting sheet materials. Mitre saw would be best just check its capacity. It'll also be useful for doing angles for the fencing too.
If you want to stay manual get a decent normal saw rather than a bow saw.
I've cut posts with a circular saw before. No issues cutting one side then turning it over and doing the other.
Mire saws are okay but if the posts are massive in length or thickness it's often hard to get them in properly, a circular saw is only really limited by the power lead.
How accurate does the finished cut need to be ? It can actually be quite tricky to make the cuts on opposite sides match up [b]exactly[/b].
If it's a mains powered saw it should have no trouble doing a ~55mm cut.
+1
use with a decent set square , you can get both from screwfix .
New [url= http://www.screwfix.com/p/irwin-jack-universal-saw-20/95247 ]hand saw[/url] - throw it away afterwards if you want.
Bow saw is the wrong tool
How many posts?
Also the last 2 Irwin saws I've bought have been dreadful, virtually unusable.
+1 for a normal hand saw. Bow saws are for felling small branches.
2 for £10 at B&Q and I've had no issues with them cutting shelves, building walls etc (get the first fix / coarse tooth one unless you need a particularly neat cut, which I guess you don't if you were happy with a bow saw!)
http://www.diy.com/departments/spear-jackson-panel-saw-l22/152626_BQ.prd
I cut 5" fence posts with a hand saw, very quick of the saw is sharp....
You could frame an entire stick framed house (eg 2x6 lumber with beams and posts bigger than your fence) with nothing more than a circular saw and a carpenters square. (Wel, add a tape, level, pencil etc.)
A circular saw is exactly the right power tool for the job.
Shame he's only building a garden project and not a complete house, S&J Predator all the way. As said 2 for a fiver.
you dont need those new fangled lectrickery tools
thats ace the hook joint on the roof is superb
How many posts are you cutting?
I cut 5" fence posts with a hand saw, very quick if the saw is sharp....
Yep, it helps if the posts are dry though.
This imo is by far the best value for money handsaw :
http://www.clasohlson.com/uk/Cocraft-Handsaw/40-7177
It's made by Bahco for Class Ohlson. It's basically the Bahco 244 handsaw but with a pale blue handle instead of a dark blue handle, and it's even cheaper - the Bahco 244 itself is excellent value for money.
