Old vice - lead pai...
[Closed] Old vice - lead paint? Will I die?
6 Users
Just started cleaning up an old steel vice with an angle grinder and a brush wheel. Then it occurred to me that sometimes old things have lead paint on them - heard of it for doors and the like, but not metal. Is it a possibility? Should I be worried? Ways of testing?
Posted : 08/02/2016 9:34 pm
Don't eat it, or snort lines of it, possibly wear a dust mask and clean up properly.
Posted : 08/02/2016 9:37 pm
Not a risk to adults, only small children.
Posted : 08/02/2016 9:43 pm
Really? I knew they were more sensitive to it but...
Posted : 08/02/2016 9:53 pm
Your odds are good, if it's your only vice.
Wear a decent dust mask though obvs.
Posted : 08/02/2016 10:02 pm
Ways of testing?
You can get little testing kits from decorators merchants (or online) for about a fiver
Posted : 08/02/2016 10:09 pm
If you have to take it off use a dust mask. But lead paint is flipping ace at its job, so I'd leave it on unless you really, really need to take it off.
Posted : 08/02/2016 10:31 pm
Right, will wait til I have a new respirator, which was imminent anyway and do it outside, but not take it the extremes I've read elsewhere, which were like dealing with asbestos. Cheers all.
Posted : 09/02/2016 8:10 am
using a chemical stripper is probably smarter. Using a cup brush throws the stuff all over the place, so unless its a space you can then clean up really well then the dust and the problem is around all the time.
Posted : 09/02/2016 8:23 am
A small amount of lead paint ingested by an infant can cause significant brain damage, but an adult, whose brain is fully developed, is much more robust and would have to consume a hell of a lot, so one bit of DIY is pretty much negligible risk. NB I've heat gunned off all the lead paint in my Victorian house (and breathed most of it in) and am still alive...
Posted : 09/02/2016 9:20 am
