Octavia just out of...
Octavia just out of warranty. Dealer or indy service?
15 Users
4 Reactions
My 21 plate Octavia estate is a couple of months out of warranty and due a service.  A basic oil change and inspection, plus spark plugs and pollen filter which are apparently due is coming in at £440 at the Skoda dealer - £160 just for the spark plugs.  I'm sure I can get this done cheaper at a local garage I trust and use for an older car.
I'm probably going to sell the car in a year to 18 months.  I don't have a paper service record, it's an electronic one and I'm worried it will show as not having been serviced on there. I would of course have a receipt for an independent service if I go that route. Will a non-dealer service affect resale?
Posted : 09/07/2024 2:20 pm
Just go to a VW/Audi/Skoda indy and ask if they will update the electronic record.  Mine does, and they can also give you a print out if necessary.
I can only speak for myself but I'd rather have a car maintained at a good indy than a main dealers.
Posted : 09/07/2024 2:26 pm
susepic and susepic reacted
£160 for spark plugs, that is a piddle take.
Posted : 09/07/2024 2:37 pm
daviek and daviek reacted
I took out a plan which covers all servicing. £20 a month. I also extended the warranty as it covers my DSG gear box.
Posted : 09/07/2024 2:45 pm
Indeed. That was the point at which I thought about going somewhere else.  With older cars I am happy to do a basic oil change/spark plug service myself. If an independent can update the electronic record and clear the warning on the infotainment display, that might be the way to go.
Posted : 09/07/2024 2:48 pm
Get a quote from an indy. I used to use a VAG specialist but in the last couple of years their prices have really gone up.
So much so that I now just service the car myself. Although it does have nearly 150,000 miles on it, so not massively concerned about resale value.
Posted : 09/07/2024 2:58 pm
They're expensive these days, cost over 50 quid for Fiat 500 ones last time I purchased from a motor factor, and it only had 2!
But they do go 3 or more years between replacement now, not annually like they used to be.
Posted : 09/07/2024 3:08 pm
You may get some goodwill from Skoda should something go wrong even if out of warranty if its had a full main dealer service history. May help residuals if you're planning to sell.
Posted : 09/07/2024 4:05 pm
Main dealer if you plan to sell shortly.  It would affect my decision as a buyer.
Posted : 09/07/2024 4:26 pm
 irc
As it happens when my 6 year old Skoda Superb was due an oil change service and MOT the main dealer was far  cheaper than three independents I got quotes from. £202.42 total.
No faults found. No upselling. They mentioned aircon service but it blows cold. Queried brake fluid but that was done last year.  Advised front brake pads were 60% worn but not needing changed anytime soon.
Indys were all around £280-£300
Henrys (north)  Glasgow
Posted : 09/07/2024 4:51 pm
Epends on your indy guy.
We went straight to the local guy after ours went out of warranty. It's 5 minutes walk rather than pissing around with the main dealer to get to them either on a day when there's a courtesy car or on a day MrsMC can fetch me back home and then take me in again later.
Local guy is clear if its a job that needs a main dealer - he won't do belt changes on certain VAG engines due to a known issue with a dodgy bolt (I think it was). He took his own van back to the dealer to get it done.
Posted : 09/07/2024 4:57 pm
Look online. It used to be possible to reset the warning by a combination of button presses, key insertions, flap wiggles etc...
Posted : 09/07/2024 6:48 pm
Depends on what independent you have, how much you trust them etc.
Mine is great, I've used for 10 years, isn't much saving over the dealer - but I do trust them and they do a better job than the dealer IME.
Posted : 09/07/2024 7:22 pm
At that age I'd get the oil change done at the dealer and everything else done at an Indy. I've literally just done this with my 4 year old A4 which is on a service plan.
Audi wanted north of a grand for new discs and pads, Indy place was half that and all the saving is in the labour - I've still got OEM parts fitted.
Edit - pollen filter change on a mk3 octavia is a bit faffy , so theres probably a hefty labour cost there too. I DIY'd mine, its not difficult, but does take a while as you have to take  the glove box door out.
Posted : 09/07/2024 7:54 pm
If you’re keeping it then probably Indy, although as others have said you might buy yourself a bit of goodwill if you get unlucky.
If you’re planning on selling shortly through then go main dealer - that’ll help with resale.
Posted : 09/07/2024 9:29 pm
DIY
Posted : 09/07/2024 9:57 pm
