Nukeproof Reactor o...
Nukeproof Reactor owners - flip chip
6 Users
2 Reactions
I got one in June, I tried a few rides in trail mode then put it in rail mode and left it there because I was trying to make it as much of a lightweight enduro bike as I could.  I wanted to sit behind the front end like I used to do on my Patriot to great effect, so I went with the slacker option and fitted a shorter stem and even higher sweep bars. However I eventually realised it didn't work well like that. I put the longer stem back on (45mm) and on the last couple of rides I put the flip chip back to trail, and whilst it climbs a bit better it is actually significantly better ragging through tight woodsy singletrack.  Perhaps because it's on the big side for me so I need a bit more help getting over the front, or maybe steeper angles add to the manoeuvrability to offset massive wheels and tyres.  It's not very enduro-ey but I think I am ok with that now. It's perhaps not the bike I thought I was getting but that might be a good thing.
What do you run and have you experimented with both?
Posted : 22/04/2024 12:39 pm
I've never tried mine in rail mode. I've decided the medium is too small for me so am currently selling it on the bay, frame only.
Posted : 22/04/2024 12:55 pm
Never even bothered to play with the flip chip. But like you it's on the large side for me.
Posted : 22/04/2024 1:07 pm
I've never changed mine. Mines a medium and I'm bang in the middle of the size guide.
I might flip it to rail and see what it does!
Posted : 22/04/2024 1:12 pm
I think rail might be better for bike park or trail centre style.
@mandog what you replacing it with?
Posted : 22/04/2024 2:23 pm
I've already got myself an Ecstasy Bike in size large. It's much more confidence inspiring.
What size is your Reactor?
Posted : 22/04/2024 2:37 pm
I'm 5'11 and mine is large. According to the size guide I could have had either M or L.  I honestly don't know what M would have been like.  Probably lighter, which in itself would welcome.
Posted : 22/04/2024 3:08 pm
I've read that the bolts and other bits of hardware are made of cheese so I'm a bit more reluctant to touch them now that they're no longer easy to replace.
Posted : 22/04/2024 4:07 pm
Was just going to respond saying I haven't had any problems with weak bolts.....
...then I went in the garage and change my flip chip to rail mode. I hope I like it now cos one of the bolts is not coming out again soon!! I swear my torque wrench didn't click, now there's no hex in the bolt, just a nice circular hole! Shit!
16Nm's...
Posted : 22/04/2024 5:24 pm
I didn't realise this at first but it's a bolt through the yoke thingy and it's accessible (ish) from both sides. There should be a bolt head on the inside as well as the hole in the end of the bolt where the chip is.
I wonder if we can start a crowdfunder or something to obtain the patterns and make parts?
Posted : 22/04/2024 7:31 pm
I’ve never tried changing mine but I’m quite tempted to give it a try, just cos I can. I’m 6ft 2, on an XL and it feels pretty perfect size wise
A slight tangent but still Reactor based… does anyone know here I can get a spare hanger?
Posted : 22/04/2024 9:25 pm
@molgrips - yeah I figured I'd have to try and get at it from the other side if I want to change it back to trail. Christ knows if I'll be able to get another one from anywhere....
Posted : 22/04/2024 9:47 pm
I found rail setting meant more pedal strikes on rough ground and generally seemed harder work to ride. Might be ok for bike parks but for xc / enduro it was not improved, I stick with trail now
Posted : 22/04/2024 10:33 pm
The reactor hanger is Pilo part number D1239
Posted : 23/04/2024 9:02 am
Thanks. The Pilo ones were out of stock previously. I’ve ordered a Betd one that ads linked to above.
I’ve only ever broken one hanger but, you know, Sod’s Law and all that.
Posted : 23/04/2024 2:33 pm
