Not putting the hea...
Not putting the heating on - how's it going...?
328 Users
203 Reactions
11.5 K Views
Want to enquire about fitting a wood burner,
They're an environmental disaster, they just spew out PM10s into the environment.
Posted : 07/10/2022 1:46 pm
We've had ours on in the new house now maybe 3-4 hours in the last 2 weeks since we moved in. Installed curtains a few days ago and that has definitely helped. Looks like the rest of October could be cold so I guess we will give in soon enough.
Posted : 07/10/2022 2:24 pm
Is it my maths or is that a hell of a lot?
I’m on about 1/4 of that I think in a 3 bed house. Is yours big and draughty?
Just checked mine, yesterday 55kWh.
Yes draughty & it’s not even that cold yet.
Are you comparing m^3 to kWh? Or are we using that much more?
Posted : 07/10/2022 2:35 pm
Stat set to 15 degrees. Not come on yet in Glasgow.
Posted : 07/10/2022 3:02 pm
Well, ecotricity have ballsed up my bills something rotten so I cannot really compare. I'd guess my boiler would be running for no more than 2hrs a day in winter unless it's a cold snap and it's 12kW, so 25kWh seems reasonable at max.
That was last winter though, we will be making serious cutbacks this winter as I have learned a lot about heating - thanks to this thread.
I will post here when our first full month of heating happens.
Posted : 07/10/2022 3:44 pm
Is 1m³ on a gas meter around 11kw in kw? That's my usual conversion rate that I use when trying to make sense of my gas bill.
Electricity meter is much easier to understand 😂
Posted : 07/10/2022 3:55 pm
...well 15 degrees is positively tropical in Glasgow! 🙂
Posted : 07/10/2022 3:57 pm
It varies based on the composition of the gas at the time and the temperature - because 1m3 of cold gas contains more actual gas than 1m3 of warm gas, of course. This calcualtion is on your bill.
Posted : 07/10/2022 4:02 pm
[smug]Suns out so the conservatory is currently keeping the house lovely and warm today 😎 [/smug]
[url= https://i.ibb.co/5WVXGMT/20221008-131531.jp g" target="_blank">https://i.ibb.co/5WVXGMT/20221008-131531.jp g"/> [/img][/url]
[url= https://imgbb.com/ ]image hosting[/url]
Posted : 08/10/2022 1:19 pm
It varies based on the composition of the gas at the time and the temperature – because 1m3 of cold gas contains more actual gas than 1m3 of warm gas, of course. This calcualtion is on your bill.
It also varies by your supplier. I'm with SO Energy and their cubic metre of gas has more kwh than some others - consequently a cubic metre costs me a little more from them than from, say, Scottish Power.
Posted : 08/10/2022 1:25 pm
Just put ours on for an hour or so to warm the house through as we've been away for a week and the bedroom radiator seems blocked 🙄
Cold at bottom,warm at top. Bled it to no affect, so assume we'll have to get the landlord to get it flushed out 😣👎
Posted : 08/10/2022 3:07 pm
20KWh gas has been last week with heating on 2-4 hours a day - we've been using about £15-£20 a month at the 7p KWh rate. Kwh based on the formula the gas company uses as it's measured in cubic m. We're way below average gas use, but have been way over on electric - that's been majorly changed to about 12KWh a day.
Posted : 08/10/2022 4:05 pm
Heating still not on in the south Midlands/north Southwest borderlands. SWMBO has agreed that we won't even consider it until we get back from Spain in a week. Hopefully it'll still be warm enough to hold off a little longer.
Posted : 08/10/2022 4:21 pm
Our rented flat is, like so many Spanish properties, great for summer but cold in winter. We have a couple of portable Calorgas heaters that come with the flat - possibly the least healthy way ever to heat a building - but they're our only option other than plugging in electric radiator type heaters, which use a lot of power if you turn them up high enough to be useful. 9kg gas bottles were costing us 17 Euros two years ago, 21 Euros a year ago... no idea what they'll be this year.
We're away at the moment enjoying an extended summer in the States but we'll almost certainly be putting on long pants and some heating when we eventually get home in early November! We always try to keep it to a minimum, opting for "more layers" before turning on any heating, but there inevitably comes a point . . . .
Posted : 08/10/2022 5:24 pm
Calorgas heaters that come with the flat – possibly the least healthy way ever to heat a building – but they’re our only option other than plugging in electric radiator type heaters, which use a lot of power if you turn them up high enough to be useful. 9kg gas bottles were costing us 17 Euros two years ago, 21 Euros a year ago… no idea what they’ll be this year.
I was thinking of getting a Calorgas heater. They used to be everywhere back in the day. What happened to them? How much is a bottle of gas and how long does it last for? And how come they're unhealthy?
Posted : 08/10/2022 5:34 pm
Its been surprisingly refreshing getting used to not having the heating on in the evenings after work. a few simple measures like keeping internal doors shut, making sure enough sunlight gets in during the day, and just heating the one room we are sitting in for 30 minutes when it dropped to 16deg last week, has hopefully saved us a lot of money on our bills compared to this time last year.
Posted : 08/10/2022 7:36 pm
Cold at bottom,warm at top. Bled it to no affect, so assume we’ll have to get the landlord to get it flushed out
Warm at top means there isn't air in it, so bleeding won't make any difference. Could just be lack of flow meaning there isn't enough water flowing through it to heat the whole thing up. If it's significantly cooler than all the other rads, I would open up the restriction valve* half a turn at a time and see if that makes a difference. If it becomes the only warm radiator in the house, you've gone too far!
*The one on the opposite side to the thermostatic valve, if you have one. Normally has a small square key thing sticking out the top under a plastic cover.
Posted : 08/10/2022 8:50 pm
I've got a SuperSer Calor gas heater that's easily 30 years old. Not sure if I've got any gas for it but it's probably going to be 50 quid for a refill.
Posted : 08/10/2022 8:51 pm
 irc
@jambourgie
Portable gas heaters are potentially unhealthy because they produce water vapour. So prolonged use in an unventilated space could cause damp. No idea running costs but this link suggests no cheaper than electricity.
https://www.hinckley-bosworth.gov.uk/info/200376/preventing_hazards_in_the_home/1611/condensation_damp_and_mould/2
That said I'm thinking of buying one as both a heating source if we get a power cut and for use in shed while working on bikes. Though I guess for the latter I would need to check that it wasn't more expensive than just running a fan heater
Posted : 08/10/2022 9:18 pm
longdog
Just put ours on for an hour or so to warm the house through as we’ve been away for a week and the bedroom radiator seems blocked
@longdog - shut all the TRVs on the other rads and fully open that one for a while.
It will push all the flow through that radiator, which might help to give it a clear out.
We put the heating on, on the 29th Sept. It ran for an hour and we got too hot, so we adjusted the thermostat by a small amount.
It then ran for 30mins on the 30th and 15 mins on the 1st Oct.
It's not come on at all since then and not really felt cold.
Problem is drying towels in the bathroom especially if I shower on the morning and then after some exercise in the evening.
Posted : 08/10/2022 9:22 pm
Cheers will give that a try tomorrow 👍
Posted : 08/10/2022 9:24 pm
So after having the boiler turned down for a week I have turned it back up yesterday and already noticed a difference in hot water temperature. Should make it go further.
As an aside we have just had it confirmed that we are having our solar PV system installed in Nov. Not the best time of year to really notice the gains but should help keep the hot water warm so saving some gas there.
Edit: we have our 'stat set to 17 for an hour in the morning and the same for about 4 hours late afternoon into evening. Set to 15 rest of the time. Only time it ever come on is first thing. The sun is keeping the house warm enough for the evening.
Posted : 08/10/2022 9:28 pm
When we used a Super Ser years ago as back up in a cold draughty farmhouse everyone thought the air got very dry and complained of prickly eyes and drowsiness but the additional heat was very welcome and dogs lay in front of it when they couldn't get near the fire for humans.
PS our CH is set at 50'c at the boiler and HW at 40'c, rads are all off at the moment, is this unsanitary? It is very economical since I lowered it without telling anyone and they have neither noticed nor complained , YET!
Posted : 08/10/2022 9:31 pm
Still doing nothing more than firing up the system once a week for a quick blast.
Bike ride, walk, pushing a few weights or gardening gets the metabolism working - I'm fortunate in that I can do any/all.
Porridge to fuel the day.
Winter wear still a long way off.
Am just about to assemble a stages smart bike to complement my home fitness stuff; will be in an insulated shed so the build and using it will stoke up the system!
EDIT - posted from balmy/barmy Newark in the East Midlands; positively Mediterranean!
Posted : 08/10/2022 9:34 pm
Not even close to being cold enough to even think of putting the heating on. Bedroom window still open 24/7.
Posted : 08/10/2022 9:44 pm
HW at 40’c
Way too low, that's within perfect bacterial growth temperature! It'll be even cooler once distributed through your pipework.
Being unsanitary to save a few quid is ridiculous. spend about 30 quid less on beer this winter and put it towards the cost of keeping your water at a safe temperature...
Posted : 08/10/2022 10:26 pm
yeah Calorgas heaters are great for taking the chill off quickly, but they do produce water vapour which will lead to damp. We've found the best way to use them is to have all the windows open a crack while they're on.
Posted : 09/10/2022 3:13 am
First nippy overnight in North Somerset last night. 5 degrees. Dropped to 18 degrees indoors, except for the snug, which has three exterior walls and a big set of older patio doors in one of them, and that reached 16.5 degrees.
So far, solar gain in the mornings is bringing the house up to c.20 degrees most days, but as the weather worsens that is going to become less and less reliable. Sustained colder nights and worse weather will make it more difficult to achieve a decent into temperature, so the need for heating is coming this month I suspect.
Posted : 09/10/2022 8:13 am
Blimey! I’ve been in “winter wear” indoors already this week. Not this weekend though. House up to normal temperature by about 10am thanks to the ball of fire in the sky. Just need to have an extra layer on first thing (and last thing).
Posted : 09/10/2022 8:18 am
Ours is regularly topping up 18 to 20 degrees in the morning now, then 20 is maintained naturally through the rest of the day. The long range forecast for London is that the current temps will mostly be maintained until first week of November, so we are building up a nice line of credit in case of a very cold winter.
We are £700 in credit after this months £66 Gov credit which I can’t see us using tbh, but who knows - as tempting as it is to be extra warm and toasty my thoughts are with saving the fuel so people don’t have blackouts/the environment. I’m taking screenshots due to the pending takeover of Bulb by Octopus.
Posted : 09/10/2022 8:46 am
Way too low, that’s within perfect bacterial growth temperature!
But, as Edukator mentioned earlier - the water doesn't hand around I the pipes or tank for long does it?
Posted : 09/10/2022 9:28 am
That's kinda what I was hoping , it's an enclosed system and legionaires relies on a semi stagnant set up doesn't it ?
Posted : 09/10/2022 10:18 am
3 degrees in Derbyshire Dales at 8.30am. How cold does it have to be before you give in?
Ours has been on for weeks, Mrs STR feels the cold and we have two Devon Rex, which have to have a warm environment (or so I'm told)
Posted : 09/10/2022 10:30 am
We’re looking at a Devon Rex… what are they like to live with? Are they cuddle up cats, or bugger off cats?
Still no central heating on here so far… BUT, there will be fire and crumpets tonight. The anticipation is great.
Posted : 09/10/2022 10:32 am
No idea. When I'm too cold I guess. There hasn't even been a frost in Macc yet.
Posted : 09/10/2022 10:34 am
That’s kinda what I was hoping , it’s an enclosed system and legionaires relies on a semi stagnant set up doesn’t it ?
If you don't have a hot water tank it's fine. You don't get legionnaires disease from drinking water straight from the cold tap either.
It's only if you have a water tank where it can sit for extended periods of time.
Posted : 09/10/2022 12:07 pm
What's an extended period of time? Our tank probably gets emptied every few days.
Posted : 09/10/2022 12:58 pm
2-10 days .
Depends how lucky you feel I guess.
Solar thermal is our next venture due to the fact that we have used half a tank of oil just on ho****er this year according to the Watchman....since the boiler stats been on frost mode.
And the solar PV/battery sometimes gets on ok with the electric shower....but mostly doesn't so moving to an unvented tank and a pumped shower. Move the redundancy to the tank which can be heated by solar thermal /solar PV /grid feed /oil.
I hopefully get our dependency on burning dinofuel down since our car milage is minimal such that spending the same cash in an electric car made no sense.
Oh and the boilerss still not been on again since the firing earlier Inn the week when it was 3 degrees .... But the stove is going on this afternoon. The north winds blowing and it's blowing hard
Posted : 09/10/2022 1:12 pm
Ours are very cuddle up cats. When THEY decide they want to of course. Have some real charachter though, rather than just being aloof cats
Posted : 09/10/2022 4:38 pm
Solar thermal is our next venture due to the fact that we have used half a tank of oil just on ho****er this year according to the Watchman….since the boiler stats been on frost mode.
@trailrat - I thought your pv panels heated your hot water? Why the need for oil heating?
Posted : 09/10/2022 4:49 pm
I've no tank. I didn't have space for a tank when I fitted my combi years ago.
Couple of extensions since and I'm forcing one in.
The PV charges my battery.
I can set it up to heat a water tank but I am running out of front roof space. Solar thermal is considerably more efficient at converting sun into hot water 80-90% Vs 15-20% for PV. But PV more versatile for most part and has proven that I have the sun coverage 9-10 months of the year to make it viable.
Posted : 09/10/2022 4:58 pm
Put my heating temperature up about an hour ag, it was set on 16 degrees, it’s now on 18, it was just too cold to sit around even with warmer clothes on, my hands are really feeling the chill.
Posted : 09/10/2022 6:19 pm
@trail_rat so you have PV that heats water on demand for a shower? Assuming a leccy shower then. That's good going to get it working like that. Be interested to see a solar thermal system up and running doing a similar thing. FYI an invented tank doesn't need a pump. Runs off main pressure. I experienced a thermal system on a campsite that had a very small panel and still heated a tank enough for half a dozen people to have a comfortable shower at tea time.
Posted : 09/10/2022 9:53 pm
 bruk
Relented and have switched the heat on at the wireless controllers. Gave it a boost on Friday morning as has someone coming round for a meeting. I don’t mind sitting down at the desk with a coat on but bit rough to expect someone else to do that too.
Then this morning lots of condensation inside the bedroom and in laws coming to stay meant it’s gone on.
Have to admit it is nice having the heating on.
Posted : 09/10/2022 10:14 pm
We've flicked the electric convection fire on for a bit today at the static caravan. Not resorted to firing up the gas CH though - bloody gas bottles are £88 per 47kg bottle £60 a year ago) - our van has 4. Fortunately, we use maybe two bottles a year. The oil filled radiator is on low in the hallway as it keeps the chill off the bedrooms.
Back home to work in the morning !!!
Posted : 09/10/2022 10:25 pm
Still nice and mild here in Cardiff. Tshirt weather out and about.
Posted : 09/10/2022 10:28 pm
We’re saving loads*. Seeing as we’re in Spain, wife wants the air con on tonight.
*can’t remember how much this place is for the month we’re here though, probably 10X more than we’re ‘saving’.
Posted : 09/10/2022 10:32 pm
We have a one year old, so the heating has come on. Set to 19C, on for three hours a day around the time we eat, just to take the edge off for the la'll 'un. I have also set the boiler to heat the heating water to 60C, down from the 75C it was set at. Not sure if it is saving money, but the boiler is firing less and the house is warming just the same. We are about to replace all our radiators with new larger, to make better use of the lower heating temperature. Wood burner has been going on too, it has been warming the house too much mind, so rationing that even though I have a free wood supply.
Posted : 10/10/2022 7:39 am
We've just caved and put it on an hour a day. Last week we had put it on a couple of times as it was 15* in lounge and just a bit too cold
Posted : 10/10/2022 7:43 am
 StuF
Still not on yet - it has been down to 16.5 in the sitting room - luckily MrsF has been crocheting blankets for years which are great snuggling under
Posted : 10/10/2022 8:10 am
Still in shorts here in Cambs and no heating yet. It's gone quite mild again.
Posted : 10/10/2022 8:16 am
Why do people think little kids need extra warm houses? I see lots of people worrying that their kids will be cold when the kids are not acually cold. We did this too at first.
Posted : 10/10/2022 8:22 am
100% they are usually in t shirts from running around. Even our toddler (who last year was a proper baby) was not bothered by a house at 15-18 Deg c. Just had an extra body grow thing on.
Posted : 10/10/2022 8:33 am
Ok so my last post was inelegant, but your kids are probably much tougher and less bothered than you think.
My nephew likes to strip to his underwear and run about in the rain, whatever time of year. His mum was horrified at first but he's fine.
Posted : 10/10/2022 8:39 am
My nephew likes to strip to his underwear and run about in the rain, whatever time of year. His mum was horrified at first but he’s fine.
His university house mates are getting used to it now as well....
Posted : 10/10/2022 8:48 am
Still in shorts here in Cambs and no heating yet. It’s gone quite mild again.
Compared to here where my shed lock had ice on following the dawn drizzle...
Posted : 10/10/2022 8:49 am
Yip, 5 degrees at 8am here so the heating got a boost for an hour. That will be in for the rest of the day as the heat keeps in the house well. Still trying to sort the account with EON which is frustrating.
Posted : 10/10/2022 8:52 am
first solid frost on the car this morning
was 2 degrees outside at 7am.
Posted : 10/10/2022 8:58 am
When I say comes on, it heats up for half an hour in the morning, then nothing for the rest of the day as the solar gain in the living room and the insulation keeps the house pretty much at temperature. Re the baby and heat thing, I guess it's conditioning, I'll maybe undertake an experiment. I'm still in shorts and, at best, a hoody. I've gone 2 years without wearing trousers consistently, but we had a very mild winter last year. We're just south of the Lakes, so it's usually grey and wet.
Posted : 10/10/2022 9:08 am
I guess it’s conditioning
A lot of it is, with adults as well as kids. Kids have lots of brown fat tissue, which generates heat. That's how come they can play in the sea far longer than grown ups can. You lose this as you grow up but you can prompt your body to create more by making yourself cold more.
And a lot is perception. I keep thinking "oh it's a little chilly, I should put the heating on" but this is because my feet might be a bit chilly whilst my core is fine. So I put thick socks on. You only need worry when your core is cold. I am tempted to put heating on because I can simply press a button and get a warm house. But I have to remind myself of the downsides of that.
Posted : 10/10/2022 9:13 am
wife swims in the sea and lochs year round for extended periods.
Can still detect the house dropping below 18 degrees instantly.
Posted : 10/10/2022 9:20 am
Dwtecting it is one thing, solving it by putting on the heating is something else 🙂
Posted : 10/10/2022 9:22 am
well if you wanted to be a complete and utter **** about it ....
https://newsthump.com/2022/10/05/man-installs-fake-thermostat-to-let-family-think-theyre-putting-the-heating-on/
But to her credit shes usually under the blanket before the heating goes on .... shes just runs cold.
As a result i end up in shorts and tshirt most of the time.
Posted : 10/10/2022 9:26 am
Eee, when I were a lad………..
I grew up in a council house up in Durham. Coal fire but no central heating & we’d often wake up to frost on the inside of the single glazing.
Posted : 10/10/2022 9:33 am
Thermostat showing 17.5° in the home office, heating comes on at 17.
Feet are toasty warm in the new hut slippers, legs requiring a blanket. Might go and make a cup of tea in a minute...
Posted : 10/10/2022 9:39 am
But to her credit shes usually under the blanket before the heating goes on …. shes just runs cold.
Ok, fair play, as long as she makes an effort.
As an aside, I've been feeling much warmer since I got back on Zwift.
21.8 in my room according to my Garmin, heating not been on. That's all residual heat from us having slept in here. Quite impressive.
Posted : 10/10/2022 10:16 am
Yup I remember that too – no CH until I was about 10 years old IIRC and single-glazed draughty windows.
And we haven't put our heating on yet either – I haven't really felt cold enough to actually WANT it on.
Posted : 10/10/2022 10:20 am
 irc
A bad winter round 1981 was -15C in Glasgow. I returned to my flat after a couple of days away to find the water off as the lead rising main was frozen and a layer of ice in the toilet bowl
No CH in that flat.
Posted : 10/10/2022 12:11 pm
Not on yet here in HD6.  Bit of a chill last night but still reasonably mild really.  It's ~18 degrees in my home office (dining room), sp perfectly pleasant at the moment.  I have got a woolly hat on though, but that's because I'm a baldy who likes a warm head 🙂
Posted : 10/10/2022 12:24 pm
Blimey!!!
The thermostats on my immersions max out at 60c and that needs mixing down to make it useable!
Posted : 10/10/2022 12:29 pm
I've not had to light the stove for 10 days or so but it's looking like it could be on tonight and then that's it, it'll be lit every day for the next 6 months.
I've started turning the shower off while I lather up to save hot water, that's easy currently but as it gets chillier that could prove more challenging. I'll see how I get on.
Posted : 10/10/2022 12:51 pm
I worked in a Scandinavian nursery who sleep the kids outdoors, including in sub zero, and the measure of 'too much' snow was if the kids are shorter than the snow is tall...
https://www.bbc.co.uk/news/magazine-21537988
Agree a lot is conditioning - if you live in CH house, work in CH office or school, sit in heated car etc, then your body does loose it's ability to physically respond, and your brain certainly finds it a shock.
Posted : 10/10/2022 12:55 pm
We cracked this weekend and put the central heating on. What did it for me was the curtains. The dampness in the house meant that the curtains wouldn't slide on the rail!
Posted : 10/10/2022 1:02 pm
 Chew
Those of you not putting the heating on:
A) How much are you actually saving?
B) Is it worth it?
Posted : 10/10/2022 1:05 pm
Blimey!!!
Not just me who was surprised at that then? 😀
My hot water is set at around 40ish, and the plumber told me not to increase it for fear of scalding an unwary hand-washer. (Just googling reveals that over 48degrees is considered unsafe.)
Posted : 10/10/2022 1:07 pm
I read it as "heating water" as in the water in the radiators; a lot of people have recommended lowering the temperature of this recently as it can be quite a bit more efficient.
85 degree domestic hot water would indeed be crackers.
Posted : 10/10/2022 1:24 pm
Yes, very mild down here, I just reseeded the lawn yesterday afternoon!
Posted : 10/10/2022 1:27 pm
Posted 19 minutes ago
Ours is set at 70+ as we have a very small HW tank and won't have enough HW for showers, esp in winter when the CW temp is low.
I solved the scalding problem by fixing mixer units under the sinks, so the HW feeds is thermostatically controlled mix of HW and CW.
Posted : 10/10/2022 1:29 pm
I read it as “heating water” as in the water in the radiators; a lot of people have recommended lowering the temperature of this recently as it can be quite a bit more efficient.
Of course. That would make more sense.
B) Is it worth it?
A) Whatever running my heating for 45mins-1hr costs x however many days I haven't had it on
B) *ANY* money saved when you don't have much is worth it. As I've said further up the thread, it hasn't been remotely cold enough for me to even think about putting the heating on and isn't likely to be for a fair while yet. I try and limit my heating use to the 3 coldest months of the year and then for a max of 1 hour per day.
Page 6 / 26
