I have a small Fender amp (Mustang) that I hook my phone / iPod up to. Sound is good (to my ears), but sometimes I don't want my phone wired up to the amp.
So, is it possible to rig something up where I can stream to the Mustang? It does have a micro USB connector...
There's Bluetooth receivers. Aldi usually has some.
Bluetooth, Apple Airport Express, Sonos
Bluetooth reciever or a raspberry pi running volumio wired into the amps aux input will do this pretty cheaply
We use an Apple Airport Express, works a treat.
Do you need to be an "Apple" house? We have an existing wifi network etc
I picked up a BT receiver dongle for next to no money, plugs into the existing iDevice connector. Works perfectly.
I'm sure fruit-based devices will work too, if you want to spend five times as much for little practical difference.
EDIT: I assume you're connecting via the phone's headphone connector to that amp, which complicates matters a little.
Look on amazon for a DNLA wifi music streaming jobby. They are about £30-40.
They also do BT versions.
Another option is a chromecast with a HDMI to analogue/digital audio adapter and then you can use chromecast apps from your phone.
BT is cheapest but has limited range. Leave the room with your phone in your pocket and the music stops.
Airport express. More money but connected over wifi so works all the time you have a wifi connection. You will either need to be using an iphone or remotely controlling itunes on a PC somewhere. There are android apps that may work but when I tried a couple of yeas ago they were flakey.
Sonos is ridiculous money for what you want.
never tried one but looks like it might be okay: http://www.amazon.co.uk/Neet%C2%AE-Wireless-Receiver-wireless-streaming/dp/B00O0U37HO/ref=sr_1_1?ie=UTF8&qid=1429608389&sr=8-1&keywords=dnla+bluetooth+music
Different versions too
We use a Logitech Bluetooth Adaptor. I saw something similar in Aldi for £14 yesterday. You lose quality, but it still sounds good to me, because old amps and speaker separates still produce nice sound which compensates for the compression. Best £25 I've spent in years.
http://www.amazon.co.uk/Logitech-980-000913-Bluetooth-Audio-Adapter/dp/B00IJYG4FY
