No man skills - Tin...
[Closed] No man skills - Tiny Stove Installation Help
4 Users
I recently got a mini wood burning stove for my wife to use in her summer house.
[url= https://www.ebay.co.uk/itm/Miniature-Mini-Coal-Wood-Burner-stove-heater-shed-summerhouse-workshop-garage/371479630493?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 ]Mini Wood burning stove clicky[/url]
The flue is 63.5mm (2 1/2 inch) and this is, apparently a common size for car exhaust tubing.
I just don't know how to put in the flue. My googlefoo has failed and I now have a stove sitting there waiting to be used!
- Should I go straight up through the roof or bend it out of a side wall?
- What tubing should I buy?
- How do connect sections of tubing together
- How do I stop water coming down the flue or through the wall/roof?
- How do I stop the flue setting fire to the roof / wall that it goes through?
- How do I bracket the flue to the wall to stop it flopping around?
I have neither the skills or tools to fabricate anything fancy, I just need to do something quickly and easily so any help very much appreciated.
Posted : 13/11/2017 9:00 pm
Get a man in?
Posted : 13/11/2017 9:02 pm
What sort of man though? Seems a bot overkill to get a HETAS stove installer in!
Posted : 13/11/2017 9:03 pm
Handy having it exhaust sized, that way you can fit a turbo to make it go faster.
Posted : 13/11/2017 9:53 pm
You want a roof flashing. A heat proof gasket suitable for the roof and size of pipe you have.
A lot of pipes slot together, male into female and attach with jubilee type clips.
No offence but if you have so many questions, it might be better to get a person in who can instruct exactly what's needed.
Go and get all the kit from a stove supplier. They'll usually have all the right clips and pipe supports etc.
Posted : 13/11/2017 9:55 pm
Depends on the roof style really. You might find it easier to go straight up and through a gasket so less/no bends.
For a shed, single wall the size you have would be fine. Maybe ask whoever makes the stove if they can recommend some.
- How do I connect sections of tubing together
It can vary but quite often with jubilee type clips.
The gasket does this. It can be screwed to the roof and further sealed if need be.
The gasket is heat proof and gives the flue clearance from the roof.
These sort of flue supports.
Posted : 13/11/2017 10:10 pm
Posted : 14/11/2017 4:48 am
