& this tread was ticking along so sweetly, I did wonder when the bickering would start
Discussion != bickering.
it basically tells the light meter to meter based on the comp so exp comp -1 means the light meter assumes minus one is 0 (if that makes sense). D300.
PS - and when you start working with lights (flash or studio) you do start thinking in shutter speed, fstops and to a lesser degree ISO levels by nessesity (primarily due to sync speeds, effect of shutter speed on depth of light etc).
Gotcha - so basically it just adjusts what 0 means on this display
but doesn't actually alter the shutter/aperture setting?
[url= http://www.dpreview.com/reviews/nikond300/page6.asp ]The D300 [i]does[/i] have P, A, S auto modes by the way.[/url] just hidden away on a button rather than on a dial.
Yes - if it's in manual you change the actual S,A&ISO settings obv. It's just the meter indicator you see through the viewer takes the comp in to consideration so if you program your cam to expose to the left then you can still use the LM as it's easier to see rather than figuring out where a 1/3d or 1.5stops to the left is on the guage.
A is for Aperture though - not "Auto". Program is still user manageable - you can turn the knobs and it will change the inputs.
Got any examples you can show us here with that lens Mintman?ta.
My flickr account is here [url= http://www.flickr.com/photos/40364853@N03/ ]flickr[/url] but not many taken with the 50mm lens. The only one on there that springs to mind is the Edinburgh Tattoo one, taken at night (some flood lights admittedly) on minimum aperture and I couldnt do that with the stock 18-55mm lens that I also have.
I'll add some 50mm photos later today and i'll let you know. Please not i'm not exactly professional!
Okay gotcha. I've no idea if it works like that on the D80 to be honest. I guess it probably does.
Incidentally the meter indicator looks a LOT finer grained on the D300 compared to the D80, which doesn't even appear on the top panel and is fairly small on the viewfinder image:
yer I know but it's an "Auto mode" (i.e. it calculates the shutter speed for the 'correct' exposure automatically). As I said I think we were probably talking at cross-purposes earlier.
I was going with the official Nikon naming: P/A/S/M as "[b]P[/b]rogrammed [i]Auto[/i]", "[b]A[/b]perture-Priority [i]Auto[/i]", "[b]S[/b]hutter-Priority [i]Auto[/i]", and [b]M[/b]anual respectively.
The completely auto [s]idiot[/s] scene modes are officially called the "Digital Vari-Programs". And confusingly there is an "Auto" digital vari-program which I suspect is what you think I meant.
There's some useful stuff here for the first time user of a D90:
[url= http://www.kenrockwell.com/nikon/d90/users-guide/index.htm ]Ken Rockwell's D90 User Guide[/url]
Ken Rockwell is very opinionated and you have to take a lot of his stuff with a pinch of salt, it's worth a read though...
I have taken his recommendation and configured an "extra vivid" custom colour setting on my D90. In the right situations it works (and saves time doing the same thing in Picasa later...=
[url= http://www.kenrockwell.com/nikon/d300/picture-control.htm ]Picture Control[/url]
Programmed Auto
What you've got there, I'd suggest, is "semi-automatic."
The completely auto [s]idiot [/s]scene modes are officially called the "Digital Vari-Programs".
That's almost as bad as Canon; the scene modes outside of the noddy presets like "Sport" are called "the creative zone."
Yep, fair description - but then you're left with:
"What does the P stand for?", "Semi-Automatic" 😀
And possibly the further confusion:
"Oh right, [url= http://en.wikipedia.org/wiki/Semi-automatic_pistol ]like a gun[/url], so one shot at a time, but no need to wind on to the next one.."
I meant as a blanket description of the -priority modes.
I wonder if part of the "manual" discussion back there might have been because I was taking manual to mean fully Manual, whereas perhaps others were using the term to mean anything other than full Auto? Maybe.
bazep - Member
Awesome - I didn't know it did this. Will have to try it out later on the D80.
Yeah I think so Cougar. I meant Manual as M, as you did, I think others use it to mean anything that isn't the überidiot "AUTO" mode on the dial (including the scene modes), and to other others the scene modes are all "auto" and "manual" means any of P,A,S or M.
All terribly confusing. 😕
Just had a read of the [url= http://www.nikonusa.com/pdf/manuals/dslr/D80_en.pdf ]D80 [s]manual[/s] book[/url] and page 54 says it does indeed work the same way on the D80:
"Exposure compensation is available in modes [b]P[/b], [b]S[/b], and [b]A[/b] (in mode [b]M[/b], only the exposure information shown in the electronic analog exposure display is affected; shutter speed and aperture do not change)."
Really intereresting thread this, good to see how others set their gear up.
Personally, if shooting gigs I tend to use the highest ISO available if light is limited and shutter priority to control movement.
For portraits I preselect a low ISO and use full manual, including focus.
Same with landscapes and use a tripod for both.
For general snapshots I tend to use manual aperture and shutter, but with autofocus and auto ISO (set between predetermined settings).
Don't tend to take many sports shots, but use shutter priority and auto ISO with auto focus.
Still think it's better to start with everything set to manual.
Start with simplicity, then add complication when required.
For me, it's just easier, but I am a bit of a Luddite 😀
Manual is manual - full manual in my book. Auto is auto is the green auto selector on the D90 and below Nik's, i.e. point and shoot mode. A is aperture and not auto, S is Shutter and not auto and P is probably best described as semi-auto. IMV
not sure it matters like.
And it looks like it does work in the way I said it did - M mode equals it's all in your hands but the light meter can be essentially fooled by the comp to show what you want it to show. I guess it comes down to how you use the cam and the light meter.
I have a D80, and the D90 (and D7000 even more so!) are big leaps on in technology. The D7000 I recently (last week) saw discounted to about £900 with a VR lens, very good value. My D80 is now four years old and I find myself craving for something with HD video and much higher ISO sensitivity (lots of stage photography).
I use manual a lot, but mainly with Flash. This way I can meter for the background (and underexpose a little) and then have the flash/camera correctly meter for the main subject.
Or I can set the camera to 1/200 sec (max flash sync) and set a sensible f stop and then let my bank of flashes make up the correct amount of light (wireless).
Yep, wasn't trying to argue with you. (surprisingly for STW) just trying to clear up the confusion. Nikon officially call the P,A,S modes "Auto" but then put the Green AUTO on the dial too so they haven't exactly been clear. 😆 (maybe it makes more sense in Japanese)
Oh well, so now we have that cleared up. How do you go about shooting a scene in (full) manual?
I imagine you might select an aperture, then twiddle the shutter speed till the light meter says you have the 'correct' exposure, is that right? Does that gain you anything over just using Aperture-priority or is it just a different approach to it?
CHB - Member
Not sure about the D90 being a big leap on over the D80.
It is definitely a more capable body, mainly down to better ISO performance & the fact that it incorporates live view & video capability (in my opinion). But it doesn't do anything that makes me want it over the D80.
I've never been that bothered about videoing stuff though, so when I used my mate's D90 I was distinctly underwhelmed by it. Definitely not worth upgrading to from the D80 in my opinion.
The D7000 however, that does seem massively more capable.
Nikon D-Wunundred!
No I jolly well have not got one. 🙁
What I would like, is a D-700 with the full-frame sensor but it's proper spensive is that. I'm hoping Nikon will bring out a 'consumer' FX sensor cam soon.
A digital FM2 would be the nuts.
You've been waiting all day to do that joke, haven't you? (-:
P = Programme mode, where the cam sets the aperture and shutter speed according to the lighting conditions. Can be shifted to favour shutter speed or aperture, but essentially gives the 'correct' exposure.
The Green Rectangle or 'Auto' mode is an 'idiot' mode for when you just want full auto of everything point and shoot snap mode. No manipulation of A or S, and I think it locks the cam in HocusPocus mode too. May also set a particular light-metering mode (IE not Spot Metering), single frame advance, and set auto-flash if necessary. A redundant mode if you actually know what you're doing with a cam, but can occasionally be useful if you're having a few and just want to rattle off a few snaps without worrying about setting the cam up for optimum performance.
Graham-S
I'll use all modes in different situations tbh (except P). Shutter for if I need to either stop or capture some motion (sports, aircraft or the like), Aperture probably the majority of the time, or for people. I use manual when I'm confident the camera will either be fooled or I know something is going to change which I want to capture differently than the camera meter would see (in any of the three modes). I sometimes you exp lock or similar to get to the same place but with the d300 knobs where they are it's just as easy to flick a button and turn the two dials for manual. I don't use Manual that often though as it's mostly in a fairly well controlled environment these days.
HTH
Quick Q for the D90 owners. Since upgrading the firmware on mine, to 1.002, I'm unable to format the memory card with the two button shortcut.
Anyone else get that?
Elf: yeah we know, read back a bit further 🙂
bazep: okay that sounds more like how I use it. I probably use aperture-priority 95% of the time.
So when you (or anyone else that wants to answer) want to take a (fully) Manual shot where you know the meter is going to be fooled then how do you pick the correct shutter speed?
Is it just experience? Recognising the light? Or do you spot meter off something in Aperture-priority then transfer the settings from that into Manual? Or do you just shoot, consult the histogram and then adjust?
(this was my original point about "isn't manual basically guess work?")
(while trying to avoid monopolising the conversation)
The meter still works in manual so either meter off something you think will give an accurate reading (still in manual) or potentially set the app you want and bracket the exposure if you're really not sure. If you're shooting in RAW it doesn't have to be bang on either as you can tweak the image file by a stop or two without degrading the image too much.
the subject is moving too fast to get a crisp shot at 1/125sec due to the light conditions, so what do I have to do to achieve a faster shutter speed. Stick it on Auto?
That's what shutter priority mode is for. Not the same as manual for me.
You are probably shooting at 1/250 f8 at the moment or thereabouts. Be aware there are some clouds coming over so you'll lose X stops of light so will need to increase your aperture by Y amount, your shutter by Z or increase your ISO
Or.. just get the camera to do it and tweak it with the comp.. it's quicker!
molgrips - MemberYou are probably shooting at 1/250 f8 at the moment or thereabouts. Be aware there are some clouds coming over so you'll lose X stops of light so will need to increase your aperture by Y amount, your shutter by Z or increase your ISO
Up above there was a comment about can you guess that for a certain shot you'll need X shutter, Y aperture & Z ISO?
My point was that this guy had been taking photos for so long that he could do this. It was a workshop, he was trying to help up improve our photography so was suggesting things to try. He was able to anticipate the changes we might like to make, judging by what the weather was doing and he was pretty much correct all the time.
I think the main reason he mentioned it was because people who were shooting in P or A, might not notice that the camera would start to decrease shutter speed as the cloud came over and this might result in blur. He was suggestion methods to combat this and providing settings that on the whole, worked.
Actually mol, birds against sky are one of the situations I'd probably consider using fully manual.
You're probably wanting to expose correctly to see the bird detail, but all that bright sky will make a (semi)automatic mode (like Aperture-priority) get the exposure to dark. And the chances of hitting the bird with the spot-meter every time are pretty low if you're trying to get it in flight.
that's fine if you know the bird you're going to be shooting before it flies past you, i find I use the fuller features of my cam when trying to get BiF - 3d tracking over 51 focus areas in continuous focus mode on Ap priority unless the light is fading. When the light's fading then start to hop around to get the best combination. Might rarely use manual for really low light just to get a shot.
Sorry - also - you'll need to hit the bird with the spot anyway if you want it in focus so it might be a moot point.
If I were shooting birds (as I have done, fairly poorly admittedly but the issue has been focusing and holding the camera steady, never metering) then I'd put it on aperture priority for my largest aperture and highest ISO that I could use for the available light, and let the camera choose as fast a shutter speed as it could.
Does anyone have experience with wide angle lenses on the D90? I'm currently looking at the Nikon 12-24 and 10-24, as well as the Tokina 11-16. I'm wondering if the limited zoom of the Tokina is a problem in practice. Any other wide angle lenses to consider for sensible money?
Not had any experience of them but I know a lot of folk who went for the siggy 10-20.
Do yourself a favour and buy one of these books.
[url= http://www.amazon.co.uk/Nikon-D90-Companion-Ben-Long/dp/0596159870/ref=sr_1_1?s=books&ie=UTF8&qid=1314385693&sr=1-1 ]Nikon D90 Companion[/url]
Don't mean to be a photographic bore ... but the only thing a reflective meter (i.e. the one in your camera) is going to do is tell you what setting to expose whatever you are metering at ... as the mid tone i.e. 18% grey.
Hence the understanding of manual exposure is pretty important. Nothing like spot metering a nice white wedding dress, and losing the shadow details of the grooms tux, or vise-versa and blowing out the highlights of a dress.
The old adage that I have always followed is to expose for the highlights ... and in the old days develop for the shadows.
Understanding that a white dress falls 2 to 3 stops over mid grey means you can meter the dress, transfer the same readings to manual exposure and adjust either aperture / shutter speed the required amount. Knowing that skin tone is typically mid tone also helps, or even grass for that matter. Knowing what the histogram means will also help prevent clipping (or better yet purchase an incident meter and understand it)
Relying on in build meters IN ALL CIRCUMSTANCES can cause confusion for newcomers, as the tone priority of a scene changes, your camera will automatically compensate (i.e. zooming in, recomposing). Don't get me wrong, "P" or auto modes certainly have their uses, but you may as well learn what your camera is doing, so you can then apply it correctly.
If you are serious about photography, id highly recommend learning about light, Ansel Adams developed the "bible" as such (ok there are detractors but Im going with what I know) and his Zone system can shed some light (no pun intended) on the situation.
As to the example above or shooting a bird in flight, if the same light is reflecting off the bird, as is reflecting off a nearby tree ... simply spot meter off the tree for your mid tone and set your camera to manual. You will sacrifice your highlights (sky) but Id assume the subject matter is more important.
Alright bluddyell only trying to be elpful jeeze....
Pends on the subject, lens in use, desired effect etc dunnit? Faster shutter speed to freeze action, and the rule of thumb I use is to pick a minimum speed 'similar' to the focal length of the lens you are using, so 1/250th for a 200mm lens, 1/60th for a 50mm, 1/30th for a 28mm etc.
Faster shutter will necessitate larger aperture which is useful in portraiture of course.
'Rule's are there as guidelines though really. Useful, but not always appropriate:
Fast shutter, 1/250th of a sec or something, just enough to stop the rider but allow for a tiny bit of wheel blur:
[img]
[/img]
Slow shutter, half a sec or something, to create blur and accentuate movement:
[img]
[/img]
FTFY. 😉
On a more serious note. Do you consider the second photo to be a good photo, Elfin?
I don't think we want to know such things on a Family Forum Mol, thank you very much. 😐
You're not one of those 'glamour' tographers are you? You dirty...... 😡
I like both of freds pics.
Well, in that I achieved the effect I was going for, I spose yeah. As for it's greater appeal, I'll leave that for others to decide.
Could do with a tighter crop, the colour's a bit off (was shot on film and I've not tweaked it bit of a magenta cast), mebbe a tiny tiny bit of flash on rear curtain sync cooduv picked the rider out from the background by just a little touch....
Considering the bugger was tooling along at over 30mph and I weren't using a tripod/monopod to steady the pan, I think it ain't turned out too bad really. The lighting's not ideal as it's a bit too side on but there's now I could do about that.
I kind of like it, but from my point of view, I don't think it's a good photo, or shall we say it could be improved upon (IMO).
This'll sound lame cos I removed the bit I was going to write about the photographers intentions. 😀
Move?
Fair enough, I'd be inertested in hearing your views actually.
It's all personal choice and if it's your intention and you achieved your objective, then it's perfect.
Pesonally I prefer shots with movement to have at least some in focus element. I'm not overly keen on the full rider being fully focussed, kind of like this.
[img]
[/img]
I don't like ^^^^^^ It's flat and not too challenging.
I prefer something like this.
[img]
[/img]
Where we have the movement and a bit of action.
But my favourites have more movement, like this...
[img]
[/img]
Or
[img]
[/img]
Also bear in mind that non of these have been near Photoshop or any other editing software shite. 😆
Feel free to criticise and comment.
Looking at the two that you posted elfin, I didn't realise you took the second :oops:, is the first one of yours too?
The first one doesn't give me the idea of speed, there's nothing to gauge speed with. Track cycling is very fast and one of my favourite subject. To be honest I don't know if the guy in the photo was racing or posing, you know like the mags do.
Speed.
[img]
[/img]
The second photo as I said above. [Remember, you can't see the wheel on the right, ok?]
Put the above on Talkphotography for a [s]flaming[/s] opinion, on the last you really need to get rid of the tyre
Why? I'm not particularly interested.
I'm interested in Fred's opinion and anyone else here. Not that interested in the views from a photography forum, I guess it'd probably be like here and the bike forum. I spend a lot of time in the chat forum.
And you missed the dirt on the censor too. 🙄
Some good examples of cycling photos [url= http://www.flickr.com/photos/tyler138/ ]Tyler138[/url], no I didn't lol
And no, the photography one is useful and not full of bullshat
Just stuck some up, it could be quite good fun. 😉
Seriously, they give alot of good advice
Need to use the Critique prefix 🙂
apparently there are rules already and I don't do rules very well. 🙁
Don.. your track cycling one doesn't do it for me.. I think it's the lighting of the rest of the building. It looks cold, depressing, grimy.. that overshadows the coolness of the racers for me. Pretty tricky to light, that.. I think perhaps some post processing would be good.. black and white, dim the background a bit, that sort of thing, but I am not really experienced in such things.
I like the cyclocross one best - brings to my mind the effort and the struggle of racing. The movement of his limbs and body shows effort, which is harder to capture in cycling other than facial gurning.
Am I waffling enough for this? 🙂
Shots two and three are ok but just so obvious - bloke on a bike, like every magazine cover. I guess that's more me than you tho 🙂
I love Elf's B&W track shot - looks retro, brings to mind a century of history and heritage which over-rides the rider's high-tech getup. But I guess those things are only meaningful to me as a cyclist. It's also very crisp and clean which emphasises him slicing the air and being very neatly tucked up on his bike. The blurry one tho I'm not so keen on. Not quite blurred enough to be all zoomy and abstract for me, and the blur on the rider isn't going in the right direction. Colours are nice tho. Maybe I'd crop it heavily to show just a bit of the bike and background, make it a proper abstract splodgy thing that would just hint at cycling, so you might see it you might not.
Be interesting to see what feedback you get on TP.
For me, I like them although the "effect" could be overused and end up looking like you can't get the shutter speed right.
Well I wanted an image that summed up the intoxicating excitement of the event, when all the noise, movement, colour etc blur together and leave a more abstract idea. That was the effect I was trying for; seen it done with sports photography before and like it.
With yours, they're a lot more 'standard' sports photography, technically very good, you can see what's going on etc, identify the riders and stuff. The bottom CC one I like a lot; great photo. The others just seem like 'standard' biking pics to me; they don't convey much more than a description of what's going on, for me. But they serve their purpose perfectly. If I was charged with providing visual information about an event, I'd be well pleased with them. The CC one is an great shot; full of movement, chaos and excitement.
Your track one; nice idea, but you're hampered by the difficult lighting conditions, and it has the look of a 'snapshot' taken with a compact, to me. It's a nice idea though, just not as well executed enough to do the concept sufficient justice.
But there's more than one way to skin a cat. 🙂
Anyway I posted those two as examples of using different shutter speeds, not as entrants to a photo competition. 😮
Move?
Have you ever tried to get a good vantage point at a TDF Prologue? 😀
Elf, you said almost the same things as I said about simon's pics 🙂
No I'm not being negative; I think they are technically great photos, and serve their purpose perfectly.
And I've said I love the CC one. That's the only one, for me, which transcends ordinary description and becomes something beyond that. Really sums up the ethos of Cyclocross racing, for me. The others are just technically good shots of bods on bicycles.
All very subjective though.
As you say, the first two are very standard as it was my first time in Llandegla and I hadn't had time to find view the circuit. By the time I reached the two points I had already passed the better positions and in a 10 mile course I wasn't back tracking. 😆
The CC one I'm very please with as all my pictures are a one shot capture, non of this "machine gunning" then selecting the best, neither are they run through editing software. It came out of the camera that way.
Secondly I like it becasue of the subject, Jose Maria Cristobal is a fantastic junior rider who has a great future in cycling if he wants it. He not only has speed, he's unstoppable in both CC and MTB, I didn't follow the juniors too much on the road, but he also has incredible grace which makes the picture more exiting for me.
Lastly I took the shot at 14mm and could feel the air rushing past my face as he came by, and didn't/couldn't flinch.
I have got better track pictures but couldn't put my hands on them lastnight.
Here's something that's a bit better from the track, still not the best though.
[url= http://farm7.static.flickr.com/6202/6084888569_c0829c1d9a.jp g" target="_blank">http://farm7.static.flickr.com/6202/6084888569_c0829c1d9a.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/63916749@N02/6084888569/ ]stwcampeonato de españa pista 290610 las carreras 107[/url] por [url= http://www.flickr.com/people/63916749@N02/ ]kala y simon[/url], en Flickr
You need to get yourself friends in high places and the correct back stage passes. 😉
What I do know is that alot of my work is KwikSave photography...
Thanks for the comments. 😀
I see we have another anonymous tagger who hasn't the cojones to speak publicly. 🙄
Elf, I wasn't being negative either...
I can tell the difference between constuctive critisism and being negative, thanks anyway. 😉
Yeah well I had to ask some grumpy 'cycling club' feller to let me get by the barrier to take just a few shots (about 5 or 6 altogether) before he started 'harumphing'. On fillum, manual everything, can't check each pic right after it's bin taken.
I think given the constraints I had to work with, I achieved a fairly good result. I'm reasonably happy with it anyway.
B+W one is on a Nikon FM2, HP5, manual focus 24mmm Nikkor, no motordrive...
Hang on.. am I being accused of being negative or not? I certainly wasn't trying to be, apologies if you thought so.. Come here and give me a hug...
And that's generally where I differentiate in the manual/auto argument and have upmost respect for the (good)photographers who have come through the ranks. You had to learn how a camera works when working with film. You had to know the settings before hand because the darkroom didn't give you the scope that software gives you today. There is no getting away from the fact that there was a huge element of luck with the Cristobal photo, he passed me the lap before and the photo wasn't so good, I do have what I consider to be a better photo but of a lesser known rider.
A friend of mine, Oscar Matxin, takes the machine gun approach and also does a lot of work for the press, I took the one shot approach and the press used my podium shots only. 😥
All photography is good, when done with passion and when it's photography (by my definition). 😀
Molly, I didn't take it as negative. *hugs*
i don't like the poor developing/agitation, you can see where the dev has flowed through the sprocket holes along the top but not enough to ensure even development, print has that chalky/grainy look of underexposure and going up a grade in paper to compensate. the pube on left is irksome too.
