Nice wood for a 3D ...
[Closed] Nice wood for a 3D model?
6 Users
So I'm making a 3D model of the Malvern's and want to do it out of a nice wood. Thinking something like ply with layers to give it a nice, contoured, look.
What sort of thing would be good?
Posted : 17/09/2015 9:10 am
Birch ply (Not birch faced ply)
or maple would give you some nice figuring.
Posted : 17/09/2015 9:15 am
Ply would be good for that kind of thing. Although I imagine to get true contours, you'd have to start off with a fairly thick block of ply. And to avoid voids (oh I like what I did there), it would have to be at least BB grade (and even with that, you'd get small ones here and there), so you might have to go B grade which (given recent experience of pricing up higher, rather than structural/flooring grades, would cost ££££ for a thick block.
Posted : 17/09/2015 9:20 am
how big are you going to make it?
I reckon ply will look great, but you need to get the expensive stuff that is real wood throughout. But then you can rip and glue it into a nice big block.
Posted : 17/09/2015 9:21 am
zebrawood ?
Posted : 17/09/2015 9:22 am
+1 for birch ply. Good quality, easy to cut and readily available. A few coats of sanding sealer, sanding between coats, will give a nice finish.
Posted : 17/09/2015 9:23 am
Only limited by the size of the machine so could be up to 6-700mm long. Working on about 350mm at the moment but can scale it up easy enough.
I'll look into the suggestions, thanks.
Posted : 17/09/2015 9:25 am
