Cooker has just been delivered but has no plug on it what type of fuse do I need to put in for safe use ?
Not sure if your being serious rich.
If no plug on an appliance its usually not supposed to be plugged in and should be hard wired via an appropriate isolator switch and correct appliance rated cables and breaker from cu
This is likely due to current draw exceeding 13amps
What does the manual say ?
Check the ratings plate on the oven, anything over 3100w and you ain't just plugging it in, it will need hardwiring. W=VxA
Could be a gas cooker that needs to be plugged in for the spark and fan. Ours is like that (could be a bodge though as we rent this place).
I have a stand alone commercial electric oven for curing parts in the lab which is basically domestic fan oven in a shiny stainless steel surround (can be removed and fitted into a domestic cabinet) and that runs off a 13A plug as it's about 2kW.
But yes, a normal electric oven in a house is wired directly and is in a notifiable area.
Its a straight swop for a old one which had been plugged in but that got collected by the metal man yesterday!
brown blue and earth wire showing!
Thought due to eu regs everything came with a bonded plug on electrical items
Straight swap as in an identical model or its just going in the same hole? As above check the rating and that will tell you if it can run off a 3 pin plug, plenty can but plenty can't and need to be hard wired. Usually coming with a plug is a sign they can be plugged in and without is a sign they can't.
Posting the name and model number would be a help.
Its just the oven and grill the hob is separate!
[url= https://farm8.staticflickr.com/7639/16761044346_7a49bfed66.jp g" target="_blank">https://farm8.staticflickr.com/7639/16761044346_7a49bfed66.jp g"/> [/img][/url][url= https://flic.kr/p/rx7Jxd ]11070172_10153190545161474_6794701505131476758_n[/url] by [url= https://www.flickr.com/people/22534490@N00/ ]Richard Munro[/url], on Flickr
Has it been supplied with a flexible cable without the standard 3 pin plug attached ? if so it will just be a case of fitting a 3 pin plug with a 13 amp fuse, if it had no cable then possibly hardwired, the simple rule is: cable sized to appliance load, fuse sized to protect cable.
2.1kW so 10A would be better...
Just read the full spec sheet it does look like it ought to be hard wired ! odd that its supplied with a flexible lead !
Haha reminds me of my father in law wiring up the immersion heater to a 3 pin plug UNDER OUR BED! It was 6kW! Not like that "in his day", apparently.
Looks like no pie and mash for me tonight STW fails me again
Just googled the product number and found three sellers stating 'requires 13 amp plug'
It also says the same in the manual.
Stick one on and get your pie on 🙂
Edit: I did also find one that said to hardwire it, but that's still three to one so far.
However, if you die I accept no responsibility.
13 amp plug is fine. It says so on the spec. 2.1kW = 9 amps.
