Need to buy a few small lanyards with these connectors but have no idea what they are called and my Googlefu is failing me
Quick release buckles.
Breakaway clips.
Proper name is Side release buckle.
They’re safety connectors or release so that folks don’t strangle themselves should they get caught on rotating machinery or shaggy things - practically all lanyards come with them - often just called ‘safety lanyard’
Cheers for the replies
Searching using Mini QR Loop/Buckle lanyard has yielded the perfect result
10 of exactly what i need for £4
https://www.amazon.co.uk/gp/product/B00BNCDCW2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
" They’re safety connectors or release so that folks don’t strangle themselves should they get caught on rotating machinery or shaggy things – practically all lanyards come with them – often just called ‘safety lanyard’"
<span style="font-size: 0.8rem;">It just allows the thing on the end of the lanyard to be removed. It doesn't stop you getting strangled if either a machine or a person grabs the lanyard itself.</span>
Lanyards should have a safety breakaway clip in them, one that breaks apart with far less pull than that one.
....Rotating machinery and things that dangle......
(Just making a statement, dont actually know what the OP use is though)
Just to clarify these are being used so i can swap camera's and lights between bikes/helmets but not have to unravel/remove the lanyard each time as each bike/helmet will have its own lanyard attached and i just need to clip on the camera/light to whatever bike/helmet id be using
I have to wear a proper break away lanyard for work (work with large industrial machinery)
Our company state they must have to have a break away clip at the top of the lanyard so its at the back of your neck, so if the lanyard gets caught in a machine the whole lanyard will come off your neck easily and not leave anything else around your neck that could drag you into the machine
