Motorcycle wheel ci...
[Closed] Motorcycle wheel circumference...
11 Users
... are they all the same ? Bar Mopeds etc ! ie 700c etc ??
I know nothing about motorcycles !
Posted : 10/04/2019 7:55 am
ish. Mostly 17" Diameter on modern bikes
Adventure bikes will vary 18-21"
Posted : 10/04/2019 7:58 am
Sports bikes are 17" front an rear. Dirt bikes 21" front 18" rear ( mainly) Cruisers often have a large front wheel and small rear. Faux dirt bikes 19" front, 17" rear
so no - sizes vary
Posted : 10/04/2019 8:00 am
At the extreme ends of the spectrum Honda xl 500 with a 23" front wheel and
Moto guzzi lemans mk4? with a 16" front wheel
Posted : 10/04/2019 9:01 am
The Yak has a few motorbikes. TJ is along the right track. Most street bikes will have 17 inch wheels with a big selection of tyres, some have a 19 inch front. The Yak has an "adventure bike," whatever that means, and a couple of dirt bikes that both have 21 front and 18 rear.
Posted : 10/04/2019 4:57 pm
Sports bikes 17 inch (some older had an 18 rear, which limited your tyre choice to Michelin "Hyside" Sports or Japanese-no-grip-ever-lasts....go ask me how I know, I'm not bitter........)
Race bike dabbled with 16.5 but I'm not sure wether that's petered out now
oh and the earlier Fireblades had a 16 inch front which led to some interesting handling foibles.
Posted : 10/04/2019 6:54 pm
I think even the first Hornet had a 16?
Course, just like cars, you get different widths of rim, different heights of tyre... My SV came with a 120/60 but I switched it (like everyone else) to a 120/70 because that's what most sportsbikes use so they're cheaper and more available, frinstance.
Posted : 10/04/2019 7:28 pm
Op asked about circumference. Everyone gave diameter. I assume you did actually mean diameter op?
Funnily enough I've been trying to measure the circumference of my motorcycle front wheel today as I've fitted a digital speedo and need it for calibration.
I put a tape measure on the floor with the valve at the bottom, rolled it forward until it was in the same position.
I made it about 1850mm (Gsx750 inazuma)
I ran over my tape measure and it's knackered now. Plus, the setting seemingly didn't work as it had me down for 110mph when I was doing about 45 😂
Posted : 10/04/2019 8:48 pm
my SR250 has a 16" rear and a 18" front, but my Triumph Street scrambler has a 17" rear and a 19" front
Posted : 10/04/2019 9:50 pm
Kayak: just enter your radius in here...
Posted : 11/04/2019 3:57 pm
Ooh thanks. I knew it were something to do wi pies. 👍
Posted : 11/04/2019 3:59 pm
1850mm sounds about right for a typical 17" front wheel. How many magnets is the speedo reading from?
Posted : 11/04/2019 4:22 pm
kayak23
Pro tip- mark the floor/ground, then measure it after doing the bike rolling
Posted : 11/04/2019 5:38 pm
1850mm sounds about right for a typical 17″ front wheel. How many magnets is the speedo reading from?
This is the thing. None. I have a widget that converts the analogue cable signal into digital. I think that's where it's going wrong as the manual only mentions magnets in setting up, . Nothing about using a converter.
Now why didn't I think of that! 😄
Posted : 12/04/2019 7:23 pm
