More Excel spoddery
[Closed] More Excel spoddery
4 Users
This one is foxing me -
I have a workbook with a bunch of numbered sheets. I want to be able to create a summary that combines various sheets. eg.
I have sheets named 1 to 10 with values in cell a1
On Sheet 'Summary' I want to list some sheet numbers in column A (say a1:a5, some of which could be blank) then have b1 report the sum of values in a1 on each of the entered sheets.
So B1 should be something along the lines of an array formula like:
=sum(iferror(indirect(a1:a5&"!a1"),0))
but that fails when it expands the array reference. Any thoughts?
Posted : 27/04/2015 8:47 am
I'd just simplify it by pulling in the values on each sheet individually, then sum them.
so in B1 type:
=IFERROR(INDIRECT(A1&"!A1"),0)
and copy down to B5
then in C1 type:
=SUM(B1:B5)
Does it have to be an array function?
Posted : 27/04/2015 10:54 am
Cheers reggie - that's sort of what I've ended up with. At the moment I've just expanded the array manually rather than use the array function, but it makes maintenance more long winded eg when someone wants to summarise more sheets than I've allowed for, and just seems less refined.
Posted : 27/04/2015 11:05 am
How's your VBA?
Posted : 27/04/2015 11:10 am
Yeah that's the other option portlyone
Posted : 27/04/2015 11:12 am
YGM OP
Edit: Well, you would have if your profile emailer worked... Mine does if you want me to send you [s]the[/s] a solution 😀
Posted : 27/04/2015 12:48 pm
