Could someone please help me with outlook. When you send an email to someone outlook remembers who it is,example;
joblogs@hotmail.com
If I want to send and email to some one else all the j's I've sent previous emails to come up in a list. How do I get rid of all the J's in this list (or the J's I no longer require)
Thanks in advance
IIRC just press "delete" when the name appears, as you type in J***
Just tested it on mine & it seems to work.
I dont think you can stop this behaviour, well you can stop it doing at all but AFAIK you cant choose who appears in this list or not:
http://searchexchange.techtarget.com/tip/0,289483,sid43_gci966527,00.html
You can use an app to tune the nickname file if you want:
http://support.microsoft.com/?id=242074
# Create a new email message in Outlook.
# Start typing the name or address you want to remove.
# Use the down arrow key to highlight the desired (undesired) entry.
# Press Del
Hmmm so it appears you can !! 😳
Thank you all the info has helped and I can manually remove said addresses.
