Methods for de-rust...
[Closed] Methods for de-rusting an old cast iron pan
18 Users
Steel wool has shifted a lot of the rust but I'm thinking something corrosive to soak it in?
Posted : 28/08/2018 7:45 pm
Either LOADS of salt and a bit of water to make an abrasive paste to go with the steel wool, or a power drill with a steel brush attachment.
And then season it properly.
Posted : 28/08/2018 7:49 pm
Coke
Posted : 28/08/2018 7:57 pm
Hookers
Posted : 28/08/2018 7:58 pm
Hammerite
Posted : 28/08/2018 8:03 pm
Soak with Hydrogen peroxide (such as contact lens cleaning solution)
Posted : 28/08/2018 8:13 pm
Molasses
Posted : 28/08/2018 8:16 pm
I wouldn't want to use anything corrosive as you could end up with pitting and you are more likely to get food sticking later.  I would keep going with wire wool
Posted : 28/08/2018 8:22 pm
Look up wranglerstar on the YouTube’s, think he’s just done this
Local shotblaster.
Posted : 28/08/2018 8:25 pm
Soak in Diesel for weeks 🙂
Posted : 28/08/2018 8:26 pm
Posted : 29/08/2018 4:39 am
Leave it to soak in cheap vinegar. if it has pitting get some foam aluminium oxide sanding blocks of coarse medium and fine with some water and spend an hour polishing the cookng surface super flat for an easy to clean and low stick pan.even new ones are improved by doing the second step.
Posted : 29/08/2018 9:27 am
Ketchup- works like the vinegar suggested above but in a paste form so you need less of it.
Posted : 29/08/2018 1:17 pm
Fine sand such as kids play sand and water and a small sponge you just need a steady circular motion, relax and allow your mind to wander. This method will shift most burnt on stuff as well.
Posted : 29/08/2018 1:33 pm
Another +1 for the vinegar. I used it to remove rust from some old railway sleeper nails. Just left them soaking for a week and then the rust just washed off.
Posted : 29/08/2018 1:35 pm
This method is ruddy marvelous;
http://antique-engines.com/electrol.asp
My son has got a setup and has been merrily derusting all of his grandad's old tools and vices.
Posted : 29/08/2018 1:39 pm
Caveat with electrolysis, he'll need to treat the tools afterwards with some sort of rust inhibitor (like the paint in the photo, nice job BTW) or they'll rust again like a bastard.
Posted : 29/08/2018 1:53 pm
