Merkur Vs Feathers ...
[Closed] Merkur Vs Feathers - anyone tried both?
21 Users
 jwt
I realise this has been done to extinction, but has anyone used both types of razor blade and can tell me what differences they found? Currently using Merkur but a quick google suggests they may be expansive compared to other brands and TBH I fancy a change.
Cheers.
Posted : 18/11/2015 8:17 am
Tried both. I shave only once a week, and have a pretty fierce beard so I can't just put up with scraping off a shadow every morning with blunt steel.
Merkurs were bloody awful. Blunt, stiff. Did not like.
Started on feathers, liked them, tried Merkurs, Derbys, Wilkos, no-name Israeli blades, but returned to Feathers. Have stayed with them since.
Sharp and light. Sometimes one edge might be a bit better than the other, I just flip the razor. Life's too short, and blades too cheap to shave with anything but the sharpest.
Posted : 18/11/2015 8:22 am
 DrP
Ok..so I'm nearly there:
Octavia
Log burner
and now the DE razor you all suggested (23c something or other..) and a pack of 100 blades for a tenner (astra blades)
The blades are numbered 1-4..
How should i use them? will flipping a blade make it sharp again? I really only get 2-3 shaves out of a blade.
I WILL google this, but thought I'd ask here too!
DrP
Posted : 18/11/2015 8:34 am
DrP - just use them twice and chuck-em! You can get a 'shed-load' of razors for the square root of FA off of that there ebay.
Not sure on the issue with using them - put them in the razor and shave? (i'm a natural teacher, eh?)
As for merkurs V feathers - my experience:
1) Merkurs - terribly, scrapy, not-close shave
2) Wilkinson sword - much better
3) Feathers - amazing! just glides thorugh thickest stubble, but requires attention to avoid nicks
Posted : 18/11/2015 8:38 am
 DrP
That's what I thought.. at 10p per blade, I can be frivilant...
I just wasn't sure why the blade sides were numbered?
DrP
Posted : 18/11/2015 8:43 am
As above Merkur - not good.
Russian, Israeli & Feather blades - good.
Posted : 18/11/2015 8:47 am
As above, I've yet to find anything better than feathers.
Posted : 18/11/2015 8:48 am
DrP - had to google it...
http://wiki.badgerandblade.com/Numbers_on_the_DE_Blade
Posted : 18/11/2015 8:49 am
 jwt
Thanks all, Feathers it is then.
Posted : 18/11/2015 8:52 am
 sv
I find feathers too sharp sometimes, best razor for me are the Astra Greens. Tried many others but keep coming back to these, cheaper than feathers too.
Posted : 18/11/2015 9:06 am
Merkurs are horrible. Feathers by a country mile. Astra greens are good too, a step down from Feathers, less aggressive. My son uses Astras, he's not quite ready for the sharpness of the Feather.
1-4 on the blade is for QA control in the factory. Nowt to do with "flipping blades".
Posted : 18/11/2015 9:24 am
Merkurs are dreadful
Feathers for special occasions, Astra for regular.
Astra last longer but not as sharp and vice versa.
Astra very cheap!
Posted : 18/11/2015 9:41 am
 sv
The numbers are good for reminding you need to change the blade. I put it in showing 1-2 for first shave then next shave flip it 3-4, when I open the razor and 3-4 is showing I know to change it out. I don't shave every day and my memory for such things isn't great 🙂
Posted : 18/11/2015 1:34 pm
There was 1 Merkur blade in with my razor handle thing.
I wasn't that impressed with it or the whole shaving experience with my new fancy DE razor.
Stuck it out for a few shaves & then popped in an Astra Superior Platinum blade and the difference was massive.
It was equal to the difference when you forget to change blades and attempt to shave with a really old, blunt blade & then stick a new one in & marvel at how easy it is.
Can't comment on the Feathers as I still have a small box of the Astra blades to get through before buying some more - and I'll probably buy one of those trial selection packs.
Posted : 18/11/2015 3:41 pm
Im a derby fan myself
Posted : 18/11/2015 4:52 pm
Big fan of the Gillette Yellows, hear their Silver Blues are awesome but not tried those yet.
Another one I think are quite nice are Treet Platinums
Posted : 18/11/2015 6:56 pm
Tesco/Asda own brand FTW, bunch of flash tarts.
Posted : 18/11/2015 7:37 pm
buy a mixed pack and figure out what you like. a few folk have said derby, i can't stand them, too dull for me. whereas feathers are great if i have a lot of stubble. day to day sharks. but thats just my skin, you will be different.
Posted : 18/11/2015 7:44 pm
I don't really get this. A blade is [i]supposed [/i]to be sharp, any cook will tell you that a dull blade is more dangerous than a sharp one. I'd respectfully suggest that if a blade is "too sharp" then the real problem is either the wrong razor or poor technique. Try a less aggressive razor perhaps?
I've tried a bunch of different blades courtesy of kind and generous people on STW; unhelpfully perhaps but I can't remember exactly, it was either the Astra or Derby blade which tore my face to bits, dreadful things. Feathers were the best by a long way, they Just Work.
Nonetheless, buying a selection pack is a great idea.
Posted : 18/11/2015 7:59 pm
I have tried all sorts and the Gilette 7 o'clock sharpe are the blades for me
Posted : 18/11/2015 8:05 pm
Merkur are awful. Feathers are great for 1 shave only. Astra for daily use
Posted : 18/11/2015 8:10 pm
 sv
You are welcome to a pack to see if it was Astras, doubt it though they are great. I have a slim adjustable so it isn't the razor so possibly technique! Do use the feathers when I know my face can handle it and I have time to take my time. Astras just work regardless.
Posted : 18/11/2015 11:02 pm
Astra platinum most of the time. Good for 2-3 shaves.
Feathers, rarely, but expect to be leaking some claret. (must get a alum block/ styptic pencil). Only good for 1-2 saves i found.
Posted : 19/11/2015 5:04 am
Feathers in my Standard are superb, any other razor they can too readily bite you
Gillette Yellows, Silver Blues and to a lesser degree Greens. Rapieras and Vokshods also, of course YMMV
Posted : 19/11/2015 5:34 am
+1
Israeli blades are utter shite, fine if you're into blood letting I suppose. Astras have been great for me so far. Never had any issues with Merkur either from memory, they were better than the Wilkinson Sword ones anyway.
Posted : 19/11/2015 10:30 am
Don't listen to any recommendations. Buy a sample pack and make your own mind up.
And now having said that: my recommendation. Feathers are too nasty for me. Astras not nasty enough. I like Gillette 7oclocks and Sharks.
Posted : 19/11/2015 10:40 am
 jwt
Quick update, Feathers seem much sharper and give a closer shave, few little nicks but was in more of a rush that I should of been for new razors!
Thanks for the advice.
Posted : 24/11/2015 12:10 pm
