How do i get mem map to stitch two maps together? As usual the area i'm interested in crosses 2 maps how do i get it so i can scrol without having to import the next map?
Can't you load all the maps at startup, so that scrolling through them is seamless? Sure that's what I do
iirc You right click the space where the other map should be and tel it to show that map, it will put em both side by side but dont think you can scroll twixt the two of them.
Thanks Scruff, I've been wanting to do that for ages 😀
you can join maps together, go to Map -> Map List. Then in the dialogue, highlight the two maps and click "Merge"
If you double left click in the space next to your existing map the continuation map appears stitched to the existing map, and you can use it as normal.
