Mechanic to the for...
[Closed] Mechanic to the forum - Speedo has mind of it's own
7 Users
So Mrs Scandal is having a car related problem, speedo has gone a bit doolally and shows far faster speeds than are actually being achieved (doing 30ish and showing 80)
This is now constant and is amongst other things probably illegal.
Any ideas what this could be, it's not like it's died entirely but is just constantly incorrect, rev counter has been that way for quite a while but never bothered her.
The car is an old 206, is it fairly common or easy to diagnose?
Any help much appreciated
Posted : 02/11/2015 10:55 am
My Transit Connect did this, used to just keep climbing and only stop when it reached the end of the dial.
I sent the console away to be repaired, cost £100 IIRC.
Posted : 02/11/2015 11:07 am
There used to be a creepy guy at our local swimming pool in the 70's with very same problem.. 😯
Posted : 02/11/2015 11:19 am
http://www.cartronix.co.uk/ by any chance?
Posted : 02/11/2015 12:26 pm
 Taff
I had the same problem on my old 306 until it completely died. Just got a second hand cluster and put it in. If it was flickering I would have said it may have been an earthing problem but with the rev counter going I would say the cluster is on it's way out. Could be worth trying the earths first. You will need to softboot the car when you reconnect the battery.
Posted : 02/11/2015 1:25 pm
How old is the car?
I've seen this before when the voltage regulator for the dash cluster is failing.
Posted : 02/11/2015 1:30 pm
scandal, yep think it was them. Worked out cheaper for me than buying a 2nd hand cluster and getting it re-programmed to the van, something to do with the way Transits store the data, it's all in the cluster, not the engine.
Posted : 02/11/2015 2:18 pm
It's 1999 or 2000
Thinking i'll try a second hand cluster off Ebay, is it easy to remove and fit?
Not able to look at youtube vids at the moment.
Posted : 02/11/2015 2:31 pm
My connect was easy, undo a few screws, release 2 clips to remove 2 wiring looms.
Posted : 02/11/2015 2:34 pm
when you say old.... do you mean nearing end of life old.....
if so - cheap fix - bung an old GPS in the window.
I did that with my frontera when the speedo started playing funny buggers after 2 years - no way i was spending money on it ....
Posted : 02/11/2015 2:38 pm
Interesting idea, I'll have a chat with her to see what she thinks, could be a pain in the arse having to remove every time she gets out the car though.
Posted : 02/11/2015 2:45 pm
If the speedo is massively overreading, would that also mean that the odometer is similarly affected? Ie, it'll read higher mileage than is actually correct?
Posted : 02/11/2015 3:27 pm
