Mathematicians - my...
[Closed] Mathematicians - my brain's stopped
4 Users
Was is the closest 16:10 ratio I can get to 297 x 210? The larger the better but should be 16:10
I see the ratio of 297x210 is 1:1.414 (googled). My brain simply won't let me work out what needs to be done to calculate this.
Thanks
Posted : 26/03/2017 8:10 am
Are you buying a monitor?
Do you have a fixed maximum upper width or height?
Posted : 26/03/2017 8:14 am
To get the shorter side, you take 297/16 x 10 = 185 ish. If your width is the limit, than 210 / 10 x 16 = 336.
Obviously, 336 is more than 297, so your maximum will be 297 x 185. If you need to print the whole thing on A4, then set the width to 185 and you should have a small (tiny) margin all round.
Once you've created that, it will scale up or down to A3, A5, etc as the proportions are the same.
Posted : 26/03/2017 8:28 am
Thanks all.
It wasn't for buying a monitor. I'm mocking up an online questionnaire in PS and it needs to be printed and stuck to A4 (or slightly smaller) card.
I didn't think of the obvious solution which was to make an A4 sized canvas, make a 16:10 rectangle and then scale it up keeping the aspect ratio.
Those measurements will come in useful though pyranha.
Thanks all
Posted : 26/03/2017 10:15 am
Won't most people be using 16:9 monitors though?
Posted : 26/03/2017 10:46 am
