Mach 3 compatible b...
[Closed] Mach 3 compatible blades
15 Users
any suggestions for a non-Gillette alternative?
supermarket or ebay preferred
TIA
ps - for sentimental / lazy reasons I'm not wanting to know why I should be using a Guatemalan indigenous alternative to what I already use or letting it all grow out to empower my inner chakras
Posted : 01/06/2020 3:21 pm
ASDA used to sell them, obviously Gillette aren't going to license their brand for non-branded Blade makers so you need to do a bit of research. Oh and they're not nearly as good. Quite a rough shave but at least the performance doesn't fall off a cliff like the genuine ones do.
Personally I've switched to Harry's they're a slightly more real world 4 for £8.
They still take the piss though, Mach3 isn't a new product, it's at least 20 years old and they used to be £3.50 or so for 4, inflation corrected they should be £5 for 4 now, but it's usually double that. Not bad for a product you've long paid off the R&D for!
They don't even market it anymore, they're only keen on pushing fusion now.
Posted : 01/06/2020 3:48 pm
They seemed to try and push us to the 5 or 7 blade systems and their advertising was actually scorning their own product I thought about 3 years ago. Any way, o only tried one AM alternative, it was awful. My next action was too try DE and wish I'd done it 30 years ago.
Posted : 01/06/2020 3:56 pm
I believe the Co-Op do a Mach3 compatible blade - about a fiver for 4 I think
Posted : 01/06/2020 4:41 pm
Savers do wilkinson and bic 3 or 4 blade disposables for cheap as chips.
Posted : 01/06/2020 4:43 pm
Buy some from Amazon. They'll come branded as Gillette but they won't be the same
Posted : 01/06/2020 6:35 pm
Buy some from Amazon. They’ll come branded as Gillette but they won’t be the same
Really?!? How does that work then? And how would one go searching for such a product? Or know the difference?
Posted : 01/06/2020 10:15 pm
There are the real ones, and there are fakes which are not very good. Identifiable by the cost.
Posted : 02/06/2020 10:15 am
Bought my last ones from Amazon, not the cheapest but then the cheapest won’t be genuine.. & I can return them, if I think there fakes
Posted : 02/06/2020 10:22 am
Always worth keeping an eye on the supermarkets. Morrisons have 12 mach 3 blades + razor for £20. I find that the four and eight packs are on deals in store fairly regularly.
Posted : 02/06/2020 10:47 am
I buy bags of three Bic multiblade razors from Wilco for a couple of quid, they last ages, but then, I only shave round my neck ‘cos I has a beard. 🧔
The whole razor blade business practice is one that was taken up by the printer industry - sell the basic item cheap, then charge through the nose for the blades or ink/toner.
Then sit back and count the money.
Posted : 02/06/2020 1:18 pm
I'm on the verge of moving to DE right now. Fed up of the massive expense and 1 second clogging as soon as you use these multi bladed wotsits.
What the current 'sensibly affordable DE' package du jour?
Posted : 02/06/2020 1:28 pm
What the current ‘sensibly affordable DE’ package du jour?
i find edwin jagger to be a good affordable razor, mebbes around £20 or slightly over? and i also find a knurled handle to be better for grip if you have wet hands.
as for razor blades, just a few assorted packs from wherever you buy your razor from, everyone has their own favourites. for me, i like the gillette 7 o clocks (yellow pack) and feathers, altho feathers may be a bit sharp if youre just starting out. i always found derby blades tugged and were uncomfortable.
Posted : 02/06/2020 1:42 pm
personally I'd go here, and then [maybe] take a hit on the import tax
https://www.italianbarber.com/pages/custom-shaving-kit-builder
I've used the company - and they're very good.
There's also the usual Shave Clubs https://www.thepersonalbarber.com/products/discovery-shaving-box - which you can cancel at any time. I've not used them however. But, you know, £25 all in. Cheaper than 8 gilette blades
When you need blades, there's here https://www.razorbladesclub.com/
Posted : 02/06/2020 1:55 pm
Just so.
Posted : 02/06/2020 2:18 pm
Surely the blade is the 'business' bit of the whole blade+handle setup? The handle is just a little metal stick with a clip on the end.
If you want an alternative to genuine mach 3 blades, why does it need to fix to a mach 3 handle? If you find a blade that you like, then just use whatever handle it comes with.
Posted : 02/06/2020 2:58 pm
Surely the blade is the ‘business’ bit of the whole blade+handle setup? The handle is just a little metal stick with a clip on the end.
....or the handle (and how I come to have it) is the sentimental bit I mentioned and I'm happy with Mach3 blades but wondered if there was an alternative to getting stiffed for a couple of quid a pop
As per PJ & Teethgrinder looks like I'll treat myself to a trip to ASDA or Co-Op and see if they have something
Posted : 02/06/2020 3:54 pm
