I've just got back from a very wet 14 miler and my ballsack is rubbed sore. At 10 miles I had to place the offending articles in a dog poo bag!
I'm wearing running tights with nothing underneath.
What's the answer? Lube? Shave? Help please 🙁
What's the answer?
I have two bricks and would be happy to help 🙂
I’m sure mrsfry could suggest a radical solution…
Veet and compression undershorts FTW
Magic powder NOT Veet 😯
+1 for UA underwear
What? Wear some kecks ffs.
Not your standard M&S ones though - base layer type ones known to us as powerpants:
Whatever your preference in terms of gender identity, they will love you.
+1 for undershorts of some description, definitely something with flat seams. To be honest you've done well to get that far, I bet that stung in the shower!
A good general chafing/rubbing solution is 'bodyglide'. It's well beloved by triathletes for stopping wetsuits from rubbing your neck.
Matt
When I was doing my half marathon training and race I wore bibshorts for running in, never had any issues after I started doing that. Before was a nightmare, couldn't do 3 miles without sore legs from chafing.
Don't wear anything else - just makes rubbing worse IME
Sudocream and/or Vaseline applied well has seem me through various ultras
edit: bodyglide has a nasty niff IMO, but was good for parting triathletes from their money on the idea that Vaseline rotted wet suits!! Hook, line and .....
Lard
It was handy that some thoughtful dog owner had left a bag for you. Personally I would have tried mud before dog shit but that's just me.
I have some Helly merino boxers. They're ace, but a little warm.
I use Assos Chamois cream where ever I get rubbing and no issues.
Just sling 'em over your shoulder.
Buy some skin360 underwear, shave the plumbs, cover liberally in talcum powder.. Go run. Works for me.
CaptainFlashheart - Member
All together now...
"Doooooo your balls hang low...."
Compression shorts are your friend! I use Under Armour ones which I picked up in a John Lewis sale but I'm sure others are available. That reminds me, it's about time I got some new ones!!
I wear some tri shorts under mine, a bit of chamois crème and its reet.
Beaten to the tri shorts suggestion - that's what I always wear for long runs and never have any discomfort down there. I've found them far preferable to normal running shorts of any variety.
Sudocreme does me fine for Ultra's.
Run up to half marathons here. Standard running shorts up to 10km, compression shorts underneath for distances over 10km to reduce chafing.
Thanks folks, I knew you wouldn't let me and my old man balls down! 🙂
😯I'm wearing running tights with nothing underneath.
Wear a pair of running shorts underneath. They should have an inner.
14 miles, I've just started running off road and can only muster a meagre 2.5 to 3 atm.
Still, enjoyable to get home and not have to deal with a shitty bike clothing.
Veet is a bad idea.
See: http://www.amazon.co.uk/Veet-Men-Hair-Removal-Cream/product-reviews/B000KKNQBK
Close fitting boxers for me.
I've just turned 45 Scandal42, its been a long and painful road to get to this point but now it's just a matter of steadily added miles and some talc/veet/Vaseline/inner shorts....
Do lots of stretching on your off days, I even had to relearn how to do that. Use a foam roller lots, treat yourself to some good trainers (I used a good running shop for advice) & do a session of squats, lunges, etc once a week.
And a heart rate strap & watch has helped me slow down and let my body warm up properly, my engine is a lot better than my chassis and I kept hurting myself!
+1 for a good pair of running under crackers.
The good'uns are worth their weight in gold and Vaseline
Nice one mugboo, sure I'll get there in the end.
Cougar - I can guarantee you that I’m absolutely sure Veet will not be as bad as having them removed with a laser… Or, indeed, electrolysis (basically, sliding a tiny needle down the side of each hair, into the skin, and then passing an electric current through it until the hair root burns)
Ow ow ow ow…
Rachel
Have run up to half mara in tri shorts - but why bother if not riding too? The mini chammy does nothing to help - so just get a pair of running lycras instead.
Had a second thought - for ultras (eg 80-100 miles) I went for sudocreme and Vaseline, plain nike lycras and plain running tights on top. For shorter stuff dispensed with the under lycras.
Scandal I think Running Fox in Loughborough is supposed to be fairly good.
That sounds uncomfortable.
My PA has just popped in to see if I am ok - cougs, that was naughty. The first review had me in stitches!! 😀
[quote=teamhurtmore ]Have run up to half mara in tri shorts - but why bother if not riding too? The mini chammy does nothing to help
Yes it does - at least IME. Softer on the skin and rubs less than lycra. I'd reckon that up to half marathon it doesn't make that much difference, but I've done far further and longer than that on my feet (I think the furthest I've done in one go is about 50 miles, but on very slow going terrain).
Most running shorts are lined, which IME are fine for anything other than the very longest runs in wet conditions (whether due to heat or rain). Slapping on a bit of vaseline is worth trying if the problem persists. Also see: jogger's nipple, though I use tape for that.
Fair do's aracer - I occasionally run in an some old orca tri shorts, so understand your point. Softer chammy I guess?
A sweet caress rather than a harsh rub 😉
Couldn't you tape them out the way?
What is it about you and restraining things?
My tights are pretty tight but I guess not once they are Soggy. I found cotton boxers got wet and uncomfy. The missus bought me some Gore running shorts with a tight liner for Xmas but its too cold and wet at the mo.
Suppose I could try my cycling shorts..
Toughen up and wear the shorts?
IMHO, cycling shorts would do more harm than good due to the amount of material between your legs.
[quote=Rubber_Buccaneer ]
I have two bricks and would be happy to help Wouldn't that hurt?What's the answer?
Update....
Under Armour shorts just moved the chaffing to a different spot, Udderly Buttery Chamois cream has worked a treat though 🙂
Harewood Half today in 1:41.44 in perfect weather.
Thread is useless without pics
[url= http://www.underarmour.co.uk/en-gb/mens-ua-original-series-15cm-boxerjock/1230364.html?dwvar_1230364_color=001&cgid=mens-bottoms-underwear ]Armour boxers[/url]
Wear every time I run as I've had similar problems in the past. They're class.
Deep heat? Pah, winter green's where its at!
I wish you could still get wintergreen in the Vaseline format.
Good run mugboo!
All together now...
Thanks Hammy for making me laugh like an 8 year old again! Nothing like a playground classic to make you not feel your age!
I Can't Believe It's Not oh I can't be bothered.
Funny I should stumble in this. Ran 10 miles today in Asics tights... Have done for a while yet today was the first time by Sac Magi? chaffed. Slapped some sudocrem on them now. Not pleasant.
