Living room audio; ...
[Closed] Living room audio; Sound bases any good?
4 Users
I've been looking for a decent-ish bluetooth speaker for the front room. It's not a big room, so it needn't be anything too flashy. Unfortunately the huge price increases in Rural/Vita means that we won't be adding to the ones we have in the kitchen and bedroom (which are brilliant).
By chance I looked at sound bars as a present for family and I happened across sound bases. Most of these have Bluetooth and some have NFC (we have OSX and android devices) and it [i]seems[/i] that it could be a double whammy in that we'll get betterer TV noise and a music player and they aren't hugely expensive.
We aren't audiophiles, but I'd like something which plays music well. Multiroom stuff is not required.
Any experiences/advice on these little blighters? Are they shit (comparatively) for music?
Posted : 03/07/2017 6:59 pm
We've got one of these: [url= https://www.johnlewis.com/panasonic-sc-hte80-speakerboard-bluetooth-sound-base/p757507 ]Panasonic Soundbase[/url]
Vastly improved the TV sound, various modes to sound like the cinema, stereo, 3D sound-a-like. Cheap as chips now. Also does NFC.
There's also a bigger one if you want to upset your neighbours neighbours. 😉
Posted : 03/07/2017 8:44 pm
That's great, thanks! What's it like for music?
Posted : 03/07/2017 8:49 pm
It's not a Hi-Fi. But it's more than acceptable. I've had to turn the sub woofer setting down to almost minimum, otherwise it gets a bit BOOM-TIZZ car audio like. But that might be the cabinet it's sat on. On an open TV bench you'd have a bit more adjustment.
It's also surprisingly loud. Movies sound like proper theatre systems, obviously not surround. So much so it's a case of telling Boy2 "TURN IT DOWN, ARE YOU DEAF?"
Posted : 03/07/2017 9:16 pm
Sonos Playbar is wifi and allows you to use for music via smartphone when tv not in use. Highly recommended but not cheap
Posted : 03/07/2017 9:27 pm
The Sonos Playbase looked pretty good on the Gadget Show a while back, I guess depends what your budget is.
I found on a couple of cheaper soundbars/docks I've had the base is just way too intrusive (I like base in music and I'm far from an audiophile but when you can't hear dialogue in a film due to what should be background sounds overwhelming it you can't help but notice it and they usually don't come with a way to balance it out).
I would say listen to it in the shop but I doubt even then you get a true sense, just make sure you buy from somewhere with a hassle-free returns policy and take care unpacking it.
Posted : 04/07/2017 6:37 am
Most of them do this, even the £60 LG we got the FiL. On that basis I couldn't justify £700 for a sonos. I'm looking at a Panasonic ALL30 as we have a Panasonic TV and it should work with the ARC HDMI. Has NFC too. I just don't know if it will be much good at music, I suppose I'll have to go see one.
Posted : 04/07/2017 11:48 am
